How to Switch Power with a Jack Switch?
Page 1 of 1 [9 Posts]
Inventor
Audio files: 267
PostPosted: Tue Nov 17, 2009 10:31 pm    Post subject: How to Switch Power with a Jack Switch?
Subject description: What a turn-on!
I want to build some thingies that turn on automatically when you plug in an audio cable, and turn off when you unplug the jack. They will run from 9V batteries, in some cases one battery and in other cases two (+/- 9V supply). I'm told that this is commonly done, yet I'm at a loss as to exactly how to do it. Any suggestions? Thanks.
Les
spippoli
PostPosted: Wed Nov 18, 2009 3:24 am    Post subject: Reply with quote  Mark this post and the followings unread
I used switched stereo jacks a couple of times for this. They're jacks with the 3 pins for audio signal plus a DPDT switch activated when you plug it
Inventor
Audio files: 267
PostPosted: Wed Nov 18, 2009 3:43 am    Post subject: Reply with quote  Mark this post and the followings unread
That is so good, spippoli, I didn't anyone made such a thing! I knew about jacks that had switches, but these switches get grounded by the plug, so no good for power. A separate isolated switch is a godsend for this application, thanks.
Les
spippoli
PostPosted: Wed Nov 18, 2009 5:41 am    Post subject: Reply with quote  Mark this post and the followings unread
exactly,
the DPDT pins are isolated from the jack.
Unfortunately I buy them from my local supply store and have no reference to online shops.
Anyway the jack is this one:
Inventor
Audio files: 267
PostPosted: Wed Nov 18, 2009 5:54 am    Post subject: Reply with quote  Mark this post and the followings unread
Wow, that jack is perfect, I will see if DigiKey sells them...
Les
numbertalk
PostPosted: Mon Nov 23, 2009 7:04 am    Post subject: Reply with quote  Mark this post and the followings unread
You don't need a switched jack for this - you can use a normal TRS jack. Connect the '-' post of the battery to the ring lug of the jack and the common of the circuit to the ground lug. Then when you insert a TS plug (make sure it's TS and not a TRS plug!) the circuit for the power will be closed and your circuit will power up. This is the way it's done with stompboxes.
Inventor
Audio files: 267
PostPosted: Mon Nov 23, 2009 1:22 pm    Post subject: Reply with quote  Mark this post and the followings unread
That will work for single supply, but i have +/- 9V supply.
Les
numbertalk
PostPosted: Mon Nov 23, 2009 7:02 pm    Post subject: Reply with quote  Mark this post and the followings unread
Oops missed that
Les
Inventor
Audio files: 267
PostPosted: Mon Nov 23, 2009 7:10 pm    Post subject: Reply with quote  Mark this post and the followings unread
numbertalk wrote:
Oops missed that
Les
Still, I recall seeing a jack that had two switches unless i'm really confused. Maybe that's what that switch is for...
Les
