Replacement for MCP4822 DAC
Page 1 of 1 [7 Posts]
joshco
PostPosted: Sat Nov 21, 2009 12:37 pm    Post subject: Replacement for MCP4822 DAC Reply with quote  Mark this post and the followings unread
Hello,
Is it possible to replace a DAC MCP4822 by an other DAC.
MAX 517, for instance...
Its the analog/digital converter of a Midi/CV interface.
What are the main characteristics to look for, to find a replacement?
Thanks
Best regards
T.
Narbotic
PostPosted: Tue Nov 24, 2009 7:37 am    Post subject: Reply with quote  Mark this post and the followings unread
Looks like you can "request a sample" or just order one straight from Microchip's site - http://www.microchipdirect.com/ProductSearch.aspx?Keywords=MCP4822
I use the MCP4921 a lot - love 'em
- Collin Mel
joshco
PostPosted: Wed Nov 25, 2009 5:34 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks! definitely worth to check out. In the meantime I have read lot of stuff about d/a conversion in general, but not enough. If somebody has some useful links about resistor asessment for dac´s,
I´m also interested...
Narbotic
PostPosted: Wed Nov 25, 2009 6:09 am    Post subject: Reply with quote  Mark this post and the followings unread
not sure I follow you, do you mean an R2R DAC / Resistor Ladder?
 Filesize:  38.98 KB
 Viewed:  12631 Time(s)
- Collin Mel
joshco
PostPosted: Wed Nov 25, 2009 12:02 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yes the R2R Ladder. As longterm Project a have some ideas around the PIC microcontroller, I´m quite at the beginning of programming and µC´s.
At the moment I try to understand DAC´s, in general. If I have a 12Bit ladder it would be easy to quantize CV´s to the appropriate Voltage Steps of 0,0833V. But without an IC-DAC it would need 12 pins for the R2R Ladder. Whereas the IC only needs 3 lines.
I think to experiment with some DAC´s is the next thing do.
As i see, its also possible to convert CV´s with PWM, don´t know about the resolution since it only delivers less than 12Bit, unless I´m mistaken....
daverj
PostPosted: Fri Nov 27, 2009 8:39 am    Post subject: Reply with quote  Mark this post and the followings unread
remember that an R2R ladder is only as good as the tolerance of the resistors. 1% resistors will give you about 7 bits of accuracy. 0.1% resistors will be good to about 10 bits. For 12 bits you'll need to buy tighter tolerance resistors.
joshco
PostPosted: Sun Nov 29, 2009 11:24 am    Post subject: Reply with quote  Mark this post and the followings unread
yes, 0.1% resistors will do the job for experimenting with this ciruit. For a stable Midi CV interface, i´ll take the mcp dac.
