Nord midi output again
Page 1 of 1 [9 Posts]
joggle
PostPosted: Mon Dec 07, 2009 3:49 pm    Post subject:  Nord midi output again Reply with quote  Mark this post and the followings unread
Good evening,
I have a (noobish) Question. As far as I understood the NM can only send out the CC of his own Knobs. But is there a way to send out the note´s which my rack recieves via midi in? Or in other words what comes out the Midi out? 1. Clock 2. Knob CC 3.. anything else?
thanx for your attention and please forgive me my bad english..
Greetings
egw
G2 patch files: 8
PostPosted: Tue Dec 08, 2009 7:23 am    Post subject: Reply with quote  Mark this post and the followings unread
Midi Out only includes data generated by the instrument. To send incoming notes (or other incoming midi data) out, you need a midi Thru port. This applies to most all midi devices, except some sequencers or devices that have a built-in "merge" function. You can do what you want with an external midi merger or thru box, depending on your configuration.
www.gregwaltzer.com
joggle
PostPosted: Tue Dec 08, 2009 10:41 am    Post subject: Reply with quote  Mark this post and the followings unread
Okay. But I can assign a CC value and a knob to a parameter, so when I now change the CC value it will be transmitted via midi out, won´t it? And that means If I have an extra slot free, I could design a patch to let 18 Midi CC "thru the synth" ( and I don´t have to pay 30 euro for a Mergebox)?
thanks or the answer and may coming answers.
Moody33
G2 patch files: 16
PostPosted: Tue Dec 08, 2009 11:29 am    Post subject: Reply with quote  Mark this post and the followings unread
Open a slot, put 18 "constant level" each one assign to the same CC# as your external midi controllers. Should work.
Audio files: 279
PostPosted: Tue Dec 08, 2009 2:33 pm    Post subject: Reply with quote  Mark this post and the followings unread
If you want to merge note information from another synth with controllers generated by the nord modular you will need a midi merger to merge the out with the thru
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Wed Dec 09, 2009 1:16 am    Post subject: Reply with quote  Mark this post and the followings unread
Have you tried it? Very Happy It's the Knob which generates MidiOut, not the Midi In.
Wout
Moody33
G2 patch files: 16
PostPosted: Wed Dec 09, 2009 8:58 am    Post subject: Reply with quote  Mark this post and the followings unread
I'm sure it works. I've already use this feature with my DAW. It's logical : this is a feature for those who used external sequencer. So if you want to record NM knob mouvement in your DAW , you also need the possibility to send those mouvement to the NM itself when you push PLAY...
Sorry for my bad english.
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Wed Dec 09, 2009 11:06 am    Post subject: Reply with quote  Mark this post and the followings unread
Sure, but that's not what joggle wants to do, I think. As I understand from this
That is not the knob!
joggle expects the CC to change the knob too, not only the parameter. If so, he could use the CC Midi out to be used as a Midi Through set up.
Only the knob isn't controlled by the incoming Midi CC, only the parameter is. And the knob is the one who sends the CC out...
In short: the knob can control the Midi CC, but the Midi CC can't control the knob. Both can control the parameter.
Wout
PS The NordLead 3 can and the G2 (That one can do even much more), but both have a Midi Through already Smile
joggle
PostPosted: Thu Dec 10, 2009 2:57 pm    Post subject:   Reply with quote  Mark this post and the followings unread
Good evening,
Wout gets the point. Thanks for all the answers. So i have to buy a Midi Mergebox...
Lg joggle
