Problem sending midiclock from Cubase to NM1
Page 1 of 1 [5 Posts]
razo
PostPosted: Sat Dec 26, 2009 3:24 pm    Post subject: Problem sending midiclock from Cubase to NM1 Reply with quote  Mark this post and the followings unread
I am having problem with getting my NM1 Keyboard synth to receive midi clock signals from my Cubase 5.0. I have set the Synchronize option in Cubase to transmit midi clock to the NM and I have set the NM to 'External' midi clock and I am using the MidiGlobal module. What could be the problem here?
(I am on a mac G4 running os 9.2.2)
Razo
Are we artists or technicians?
Stomper
PostPosted: Sat Jan 02, 2010 1:14 am    Post subject: Reply with quote  Mark this post and the followings unread
Can you post a print screen of cubase sync menu?
I did it with other instruments on windows, so i might be able to help.
Stomper.
razo
PostPosted: Sat Jan 02, 2010 5:40 am    Post subject: Reply with quote  Mark this post and the followings unread
Here's the screenshot from my Cubase..
It seems that the NM is not receiving midiclock from Cubase (it is responding to the internal rate in the ClkGen1 module, when I turn this control, eventhough Cubase is running and supposedly should transmit on midi).
(The patch is supposed to create a 'midi-clocked' sound when a key is pressed.) Why am I not getting midi sync in this patch?
Screenshot of NM Patch
 Filesize:  187.88 KB
 Viewed:  241 Time(s)
Stomper
PostPosted: Sat Jan 02, 2010 3:34 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thats the Nomad editor, not cubase sync menu.
razo
PostPosted: Sun Jan 03, 2010 5:07 am    Post subject: Reply with quote  Mark this post and the followings unread
It's solved.
(No prizes for guessing the right answer)
