Sample accurate zero latency differentiator
Page 1 of 1 [10 Posts]
Tim Kleinert
G2 patch files: 236
PostPosted: Sun Jan 17, 2010 4:05 pm    Post subject: Sample accurate zero latency differentiator Reply with quote  Mark this post and the followings unread
I needed this, so I built it ...Laughing
Contrary to the prevalent methods, this is sample-accurate, has zero latency and clocks at full 96kHz. It delivers the exact amplitude difference from sample to sample.
(You can make a controlrate-version too by disconnecting the feedbacked logic inverter and connecting it back again. Everything should turn blue.)
cheers,t
AccuDiffRNC8R_TK.pch2
 Filename:  AccuDiffRNC8R_TK.pch2
 Filesize:  1.04 KB
 Downloaded:  1736 Time(s)
dorremifasol
G2 patch files: 49
PostPosted: Tue Jan 19, 2010 10:47 am    Post subject: Reply with quote  Mark this post and the followings unread
Sorry for asking, Tim, but... what is this for? Embarassed
What are the most common uses for something like this?
Albert
Tim Kleinert
G2 patch files: 236
PostPosted: Tue Jan 19, 2010 6:00 pm    Post subject: Reply with quote  Mark this post and the followings unread
Detecting instant changes in a signal @ 96kHz. It's a low level thing. Wink I needed it for stuff I'm still working on. Sorry if it is too boring. Embarassed
t
PostPosted: Tue Jan 19, 2010 11:00 pm    Post subject: Reply with quote  Mark this post and the followings unread
Oh, back to pitch detection!?!
dorremifasol
G2 patch files: 49
PostPosted: Tue Jan 19, 2010 11:38 pm    Post subject: Reply with quote  Mark this post and the followings unread
No, it's not boring, it's cool! I just didn't know. Your circuits are very complex to me, I'm still in the "filtering saws" learning stage Smile
Albert
Tim Kleinert
G2 patch files: 236
PostPosted: Wed Jan 20, 2010 3:03 am    Post subject: Reply with quote  Mark this post and the followings unread
Pssst, don't tell anybody! Laughing
iPassenger
G2 patch files: 78
PostPosted: Wed Jan 20, 2010 7:50 am    Post subject: Reply with quote  Mark this post and the followings unread
You, me and the majority of the rest of the forum I suspect. Smile
iP (Ross)
Roland Kuit
G2 patch files: 127
PostPosted: Wed Jan 20, 2010 11:42 am    Post subject: Reply with quote  Mark this post and the followings unread
Tim, I think it is a perfect pitch for this topic, nice pch Very Happy
3phase
G2 patch files: 141
PostPosted: Fri Jan 22, 2010 9:07 pm    Post subject: Reply with quote  Mark this post and the followings unread
I dont know if this works on my 1.40 maschine... what is it supposed to do?
Is it possible that something similar like in the 128 bit ram prevents it from working correctly on os 1.4?
Tim Kleinert
G2 patch files: 236
PostPosted: Sat Jan 23, 2010 1:18 pm    Post subject: Reply with quote  Mark this post and the followings unread
It was patched on OS1.40 and works fine on my machine.
It outputs the difference between 2 consecutive samples at full audiorate. Eg., if you feed it with a triangle oscillator, you get a square wave, whose amplitude is related to the triangle oscillator pitch (as the flanks are steeper at higher pitch and thus the differences between the samples are higher).
It's a typical low-level circuit. Application example: You can use it in conjunction with a compare module set to 0, in order to sample-accurately detect signal changes.
