Korg NX5R
Page 1 of 1 [3 Posts]
salvo8984
PostPosted: Thu Jan 28, 2010 5:07 pm    Post subject: Korg NX5R
Subject description: Blown fuse in NX5R
Hi there,
I need some assistance about my NX5R its really important because I have a gig this saturday.
I have bought it in US. When I came back to London UK without think about the difference of voltage between the two countries, I have plugged in straight into the power... Flash!!! Sad(((
I opened it and there is a fuse inside burned.... I also sow there is switch where i can change from 110V to 240V
Could I save my Korg just changing the fuse or its a bigger problem and I have to take to assistance?
Please help me ...
 Filesize:  283.86 KB
 Viewed:  261 Time(s)
 Filesize:  312.68 KB
 Viewed:  273 Time(s)
 Filesize:  241.61 KB
 Viewed:  430 Time(s)
EdisonRex
Audio files: 172
PostPosted: Fri Jan 29, 2010 1:38 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for posting the pictures.
First of all, you change the mains voltage input setting by changing that connector where it says 117V over to the connector that says 230V. Then replace the fuse with one half the value (I think in the chat we said 250mA).
Then we pray that nothing was damaged. If something is damaged, we'll probably have to look closer. I think there might be a thermistor in between those capacitors, if anything, that is gone and will have to be replaced.
Garret: It's so retro.
EdisonRex
Audio files: 172
PostPosted: Fri Jan 29, 2010 1:40 am    Post subject: Reply with quote  Mark this post and the followings unread
Also it's a good sign that the other fuse (FU1, that 1.5A fuse from the secondary) was not blown. Do not mess with that one for now.
