CGS VCO - replacement for the lm394/MAT-02
Page 2 of 2 [47 Posts]
Goto page: Previous 1, 2
mark_olson
PostPosted: Sun Jan 10, 2010 12:23 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for the comments.
And thanks too for the schematic for that VCA.
But the most thanks for nudging me toward using the other pair!
Mark
stewpye
PostPosted: Fri Jan 29, 2010 2:01 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi Mark,
You could also use the other pair as a sine wave shaper (diff amp style).
Stew.
mark_olson
PostPosted: Sat Jan 30, 2010 9:08 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for pointing this out.
Sadly, at the rate I'm building even the THAT pair will be obsolete by the time I get to this. Embarassed
Mark
Rykhaard
PostPosted: Wed Mar 17, 2010 2:23 pm    Post subject: Reply with quote  Mark this post and the followings unread
We only have to match the trannies to within 5mV of each other? (Don Tillman - seems confirmed by one other replier). Back when I were matching them for my KStone VCAs as well as my 2 x Thomas Henry 1V/oct. tranny VCOs, I was matching them to within ONE mV! Laughing (Both of those VCOs BTW, track wonderfully with matched 2N3904s; no tempco - over about 5 octaves. They're now my 'standard' LFO choice. Smile )
"Welcome back Rich!"
Thanks! It's been WAY too dang bloody long! Surprised
PostPosted: Wed Mar 17, 2010 2:27 pm    Post subject: Reply with quote  Mark this post and the followings unread
That was my line Laughing good to see you round.
iopop3
PostPosted: Tue Jun 01, 2010 11:38 am    Post subject: Re: CGS VCO - replacement for the lm394/MAT-02 Reply with quote  Mark this post and the followings unread
TonnieWiegman wrote:
Last August I bought 20 pcs of the LM394 for $0.60 each at UTSOURCE: www.utsource.net.
Was quoted $4 each for 10 lm394 DIP8 this week. Talk about investment, anyone know a stock rasing 666% since august last year? Also got 5 ssm2210z for $5, Just to compare with my local price starting at $11.
Some heads up though, using their site on *nix plus Firefox is quite an experience. Was notified about the quote at work, of course I had to check it out. Tested to place an order and got interrupted in the middle of the processes, had to close that window, some hour later I got an "order confirmation" email.. opps. Luckily it was stuff I really needed. Now its just wait and see if I managed to write down the address correctly.
sonicwarrior
PostPosted: Wed Oct 20, 2010 3:19 am    Post subject: Reply with quote  Mark this post and the followings unread
andrewF wrote:
The AD page for it is here.
Looks like the SSM2210 has been replaced by the SSM2212 which is SOIC-only (SMD).
kjackman
PostPosted: Sun Oct 24, 2010 9:28 pm    Post subject: Reply with quote  Mark this post and the followings unread
I can't seem to find SSM2212's in stock anywhere in the U.S. either Sad It really is getting tiresome, looking for these matched transistor ICs.
If I use discrete components instead, hand-matching transistors, would I also need to include the diodes shown between base and emitter on the SSM2210/2212 datasheet? If so, would those diodes need to be "matched" somehow as well, or could I just grab a couple of random 1N4148's from the ol' parts drawer and it'd work just as well?
bod
PostPosted: Mon Oct 25, 2010 6:55 am    Post subject: Reply with quote  Mark this post and the followings unread
What about the LM/CA3086?
a i seem to remember someone (possibly Yves) saying the connected pair were as good as any hand matched pair, but if you used it with a tempco resistor it would save having to use the heater circuits like the moog rogue. i've seent the 3086 for as little as 1euro if you hunt about a bit.
or am i just talking mince?
adambee7
PostPosted: Mon Oct 25, 2010 7:25 am    Post subject: Reply with quote  Mark this post and the followings unread
It would be cool if the THAT series of matched pairs were used. i know Oakley have moved over to these for their vcos. brand new and available from mouser. Its getting too hard now to find most npn pairs. i can get ca 3046/86 but its not going to be long until they're scarce. Very Happy Very Happy
adambee7
PostPosted: Mon Oct 25, 2010 7:41 am    Post subject: Reply with quote  Mark this post and the followings unread
oh yeah the japanese 2SC1583 matched pair is another choice. Never tried them but there must be loads of them about. Very Happy Very Happy
sonicwarrior
PostPosted: Mon Oct 25, 2010 10:32 am    Post subject: Reply with quote  Mark this post and the followings unread
They are not a direct replacement (DIP 14) and also discontinued.
The SSM2212 is quite new. I guess it takes some time to arrive at the distributors.
sonicwarrior
PostPosted: Mon Oct 25, 2010 10:35 am    Post subject: Reply with quote  Mark this post and the followings unread
Might be a chance to make a dual VCO for not wasting the second matched pair. Idea
andrewF
PostPosted: Mon Oct 25, 2010 4:28 pm    Post subject: Reply with quote  Mark this post and the followings unread
they are good but also out of production and have been rare for a while now.
None of the regular suppliers have them anymore.
andrewF
PostPosted: Mon Oct 25, 2010 8:26 pm    Post subject: Reply with quote  Mark this post and the followings unread
Unless you want to spend lost of $$, may as well learn how to match transistors. There have been a few threads discussing techniques recently.
Once you have some matched pairs, try a few in your VCO to find the pair that have the best log tracking over the greatest number of octaves.
Looking at datasheets most matched pairs have similar tolerances to what you will obtain with a good matching circuit, plus few address the log tracking parameter (from memory only the LM394 app notes discuss this).
Basically tune your VCO to 440Hz (for example) at 0V on CV input. put 1V on CV observe 880Hz on output, 2V on CV...etc. If the VCO goes out after just a couple of octaves, try another pair.
Except for pedants, the results should be good enough for synth use.
just for fun:
here's four C1583s and tempcos glued to a block for a Quad VCO circuit built by masa921
fluxmonkey
PostPosted: Tue Oct 26, 2010 4:40 pm    Post subject: Reply with quote  Mark this post and the followings unread
Ray Wilson has posted pretty complete instructions over on MusicFromOuterSpace.com, including both a simple and fancy-schmancy circuits.... http://www.musicfromouterspace.com/analogsynth/TRANSISTORMATCHER/TRANSISTORMATCHER.php
www.fluxmonkey.com
active
PostPosted: Tue Feb 08, 2011 10:40 am    Post subject: Reply with quote  Mark this post and the followings unread
so has anyone found an available replacement? it is one of the few parts i am missing from my build right now and this thread has made me kind of sad about the hopes of finding something. can you order a small amount of chips from THAT?
cassiddidy
PostPosted: Tue Mar 01, 2011 2:48 pm    Post subject: found! Reply with quote  Mark this post and the followings unread
They've got some available at avnet
https://avnetexpress.avnet.com
If you go to analog's page for the chip and click on check inventory and purchase they will give you a listing of what vendors have it. Avnet is the only one at the moment.
http://www.analog.com/en/other-products/matched-transistors/ssm2212/products/product.html
cassiddidy
PostPosted: Tue Mar 01, 2011 2:52 pm    Post subject: Reply with quote  Mark this post and the followings unread
Sorry, that's for the SSM2212, replacement for the SSM2210
kjackman
PostPosted: Fri Mar 04, 2011 8:35 am    Post subject: Reply with quote  Mark this post and the followings unread
Note that this is a surface-mount SOIC package. You'll probably need a SOIC to DIP adapter to use it.
adhdboy
PostPosted: Mon Apr 23, 2012 9:23 am    Post subject: Matched pairs at MFOS
Subject description: MFOS Sells matched discrete pairs with tempco for $12.00
Hi guys. I share your pain regarding AD deciding people don't need no "stinkin" matched pairs anymore. Here is some info on matching your own and/or buying pre-matched pairs from me.
Match your own...
http://www.musicfromouterspace.com/forums.html?MAINTAB=SYNTHDIY&PROJARG=TRANSISTORMATCHER/TRANSISTORMATCHER.html&CATPARTNO=
Buy them...
http://www.musicfromouterspace.com/forums.html?MAINTAB=CATALOG&PROJARG=ELECTRONIC_PARTS/Matched2N3904_MFTempco.php&CATPARTNO=MATCHEDPAIRANDMFTEMPCO
Cheers all
Ray
There 10 kinds of people in this world that understand binary those that do and those that don't.
LFLab
PostPosted: Tue Jul 17, 2012 1:09 pm    Post subject: Reply with quote  Mark this post and the followings unread
Well, it seems making duals still makes sense businesswise for NXP. Not sure if they are a direct drop in for LM394 or SSM2210 (although I do intend to use them as such), but there are matched duals available for 2n3904 (type number eludes me) and there's BC847BS from NXP, they also have a PNP dual BC857BS, and....... they also a variant which is matched, these are the BCM847BS and BCM857BS. I did a layout for them and posted it on muffs: http://www.muffwiggler.com/forum/topic-55387.html
Of course these are all smt parts and small ones at that, found out today that there's a variant in a ever so slightly bigger package which is called BCM847DS, it's only half a millimeter, but at this scale......
The board also has room for up to two smt tempco resistors (because the Panasonic ones are not available in 2k, but are in 1k).
