Have you built one?
Page 1 of 1 [10 Posts]
if837
PostPosted: Tue Feb 09, 2010 8:19 pm    Post subject: Have you built one? Reply with quote  Mark this post and the followings unread
The soundlab seems to be very popular, but how many of you have build the DIY modules on MFOS website? I´m curious since finding some parts is a real pussle, and there isn´t that many questions about for example the tantlum capacitors, replacement for Mica capacitors and the partlists in general. How accurate are the partlist?
RF
Audio files: 28
PostPosted: Tue Feb 09, 2010 10:11 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi if837!
I think I've built most of the modules from MFOS at least once - some of them several times.... I've also built the 16 step sequencer, the Keyboard controller, the Soundlab and just getting started on a Soundlab Ultimate.
I've found the parts lists to be very accurate.
Lots of people have built these - and Ray is quite good at getting them right.
Tantalums and for that matter most of the parts can be found on-line pretty easy. Personally, I use Digi-Key a lot, also Jameco and Mouser...
and I'm pretty good at scavaging parts from old electronics Smile
Good luck!
bruce
www.sdiy.org/rfeng
if837
PostPosted: Wed Feb 10, 2010 8:33 am    Post subject: Reply with quote  Mark this post and the followings unread
thankyou
could I use normal electrolytic capacitors instead of tantalums in most
cases if I can´t find the right tantalums values ?
RF
Audio files: 28
PostPosted: Wed Feb 10, 2010 10:44 am    Post subject: Reply with quote  Mark this post and the followings unread
if837 wrote:
could I use normal electrolytic capacitors instead of tantalums in most cases if I can´t find the right tantalums values ?
I think in most cases you would be fine with doing that....
bruce
www.sdiy.org/rfeng
PostPosted: Wed Feb 10, 2010 10:50 am    Post subject: Reply with quote  Mark this post and the followings unread
I'm currently building a pair of MFOS voltage quantizers. I purchased the PCB's from the MFOS website I had no problem finding all the parts at Mouser.
if837
PostPosted: Wed Feb 10, 2010 11:22 am    Post subject: Reply with quote  Mark this post and the followings unread
next time I will try and do the same, order everything from Mouser.
unfortunately I don´t have a credit card and they charge a $25 fee for using their bankaccount. But it will probably be cheaper than buying from several different ebay sellers, like I did this time.
if837
PostPosted: Wed Feb 10, 2010 7:44 pm    Post subject: 49.9K, 499K resistors Reply with quote  Mark this post and the followings unread
the 49.9K and 499K resistors stated as value 5% (carbon)
I can´t find any, shoud´nt it be 1% metal resistors ?
PostPosted: Thu Feb 11, 2010 4:42 am    Post subject: Re: 49.9K, 499K resistors Reply with quote  Mark this post and the followings unread
Yes those values don't make much sense as 5% values (and they're not E12 values), but you can always substitute a 1% metalfilm for a 5% carbon resistor if you can't find some value.
if837
PostPosted: Thu Feb 11, 2010 8:54 am    Post subject: Reply with quote  Mark this post and the followings unread
thanks for clearing this up
so I just replace it with the same value but an metal resistor instead.
I dont have to replace it with 5 metalresistors (1% x5)= matched resistors?
PostPosted: Thu Feb 11, 2010 9:29 am    Post subject: Reply with quote  Mark this post and the followings unread
Nope ... the tolerance says something about how accuratly the resistor was manufactured, with a tolorance of 5% on a 10k resistor the actual value could be 95k .. 105k. Noe that same resistor with a tolarance of 1% would be 99k .. 101k - so guaranteed to be more closely to the nominal value of 100k than the 5% case ... so it's just better.
