4 Octave Expo Converter Question
Page 1 of 1 [5 Posts]
Inventor
Audio files: 267
PostPosted: Wed Mar 03, 2010 12:40 pm    Post subject: 4 Octave Expo Converter Question
Subject description: What is a minimal circuit?
Hi, I'm working on a Karplus Strong string synthesis analog board and I need an expo converter for the VCO. The situation is that the board only operates over a four octave range due to the range of the bucket brigade device that I am using for the delay line. For this reason I believe that I can do the job with a really simplified expo converter circuit.
Now I realize that I will need tempco for proper tracking, however if at all possible I'd like to make do without the matched pair of transistors. This will save cost, complexity, board space, and prevent me from having to add another supplier. I don't mind having a trimpot since that may help deal with the fact that I'd like to use a single transistor for the expo conversion.
The output of the circuit is a current referenced to the negative supply rail since it will be driving the current into an LM13700 OTA, so what is needed is a special circuit topology that takes a voltage input from 0V to 4V (or 4.8V depending on the system in which it resides), and an output current flowing down into the negative rail (or close to it).
So my question is: "What are your recommendations for such a circuit?"
Les
frijitz
Audio files: 54
PostPosted: Wed Mar 03, 2010 4:15 pm    Post subject: Re: 4 Octave Expo Converter Question
Inventor wrote:
Now I realize that I will need tempco for proper tracking, however ...
The tempco is for, um, temperature compensation. It has nothing whatever to do with tracking.
Ian
Inventor
Audio files: 267
PostPosted: Wed Mar 03, 2010 4:23 pm    Post subject: Re: 4 Octave Expo Converter Question
Ian
Yes, I guess I used the wrong term. I was referring to frequency tracking over temperature ranges. Shows my ignorance of expo converters and terminology I suppose. I'm learning a lot of things in creating this board, but expo converters are still a bit of a mystery to me...
Les
Dan Lavin
Audio files: 21
PostPosted: Wed Mar 03, 2010 4:52 pm    Post subject: Reply with quote  Mark this post and the followings unread
Les,
I think Thomas Henry has some nice simple designs from his Making Music With the 3080 OTA book. Pls check your PM for some notes I sent.
Synth DIY since 1977!
Inventor
Audio files: 267
PostPosted: Wed Mar 03, 2010 5:23 pm    Post subject: Reply with quote  Mark this post and the followings unread
Dan Lavin wrote:
Les,
Thanks a lot Dan!
Les
