An 8 Operator FM Synthesizer Implementation (FPGA)
Page 1 of 1 [21 Posts]
JovianPyx
Audio files: 224
PostPosted: Fri Mar 12, 2010 4:18 pm    Post subject: An 8 Operator FM Synthesizer Implementation (FPGA) Reply with quote  Mark this post and the followings unread
http://home1.gte.net/res0658s/FPGA_synth/8opFM16voice.html
Time flies like a banana.
corruptio optimi pessima
JovianPyx
Audio files: 224
PostPosted: Sat Mar 20, 2010 6:49 pm    Post subject: Reply with quote  Mark this post and the followings unread
Progress!
Today I finally got sound. Seems like the ADSRs and NCAs are working, as well as the NCOs (mostly) and polyphony also seems to work. Gotta work out the bug that is causing the pitch to be the same regardless of the note-on message sent...
Dan Lavin
Audio files: 21
PostPosted: Sun Mar 21, 2010 10:18 am    Post subject: Reply with quote  Mark this post and the followings unread
That is good news. I'd be happy with a 4-voice 8-op FM synth! Good luck Scott!
Synth DIY since 1977!
JovianPyx
Audio files: 224
PostPosted: Sun Mar 28, 2010 12:52 pm    Post subject: Reply with quote  Mark this post and the followings unread
Some progress - finally.
For some reason yet to be determined, many of the RAMs that I tried to infer were being optimized away as "identical". I could see no reason for this to happen in the source code, so as a troubleshooting step, I rewrote them as forced instantiations of RAMs. All of a sudden, the freaky behavior ended and I'm getting sound now.
More testing reveals other problems, but I believe these are just "oops - why did I do that?" kind of stuff.
Once I get it working fully and correctly, I will post some sounds.
JovianPyx
Audio files: 224
PostPosted: Sun Mar 28, 2010 4:24 pm    Post subject: Reply with quote  Mark this post and the followings unread
Looks like the chaining is working. I've been playing with 3 operator sounds so far. Lots of fun screwing around with different settings. Lots of different sounds available.
Once I'm satisfied that everything is working, I think I'll just turn Audacity on and play with the patch editor and post that.
JovianPyx
Audio files: 224
PostPosted: Sun Mar 28, 2010 4:34 pm    Post subject: Reply with quote  Mark this post and the followings unread
Here's a couple of 3-op samples. More later.
8op_001.mp3
A short sample using the synth in 3 operator mode
 Filename:  8op_001.mp3
 Filesize:  487.01 KB
 Downloaded:  1439 Time(s)
8op_002.mp3
a sort of Krell music thing here...
 Filename:  8op_002.mp3
 Filesize:  454.76 KB
 Downloaded:  1448 Time(s)
PostPosted: Mon Mar 29, 2010 10:19 am    Post subject: Reply with quote  Mark this post and the followings unread
Aha! So that's where you've been Laughing
Sounds like erm .. FM Shocked some powerful sounds!
JovianPyx
Audio files: 224
PostPosted: Mon Mar 29, 2010 11:50 am    Post subject: Reply with quote  Mark this post and the followings unread
uh-oh - I've been found out! cyclops
I still need to do more testing, I haven't yet even tried 4 operators (except to get some rather un-useful noise). It seems to be basically working. I can create multiple sound generators within an 8 operator chain, I've tried four 2 operator chains and it sounds correct, so the feed-to-next-operator logic is working.
Now I need to get the operator zero self feedback working (this is a DX7 feature). This is a special case, so it will take some more thinking (and banging and swearing).
I want to, but haven't approached other sorts of odd operator connections, such as 2 operator outputs fed to an adder, the sum output modulating another operator.
And then there's the UI... Nothing about FM is intuitive, so making the UI intuitive or even just not obfuscatively confusing will be a challenge as well. cyclops
So far, this much logic is using only 55% of the slices in a Spartan-3A 400K equivalent gate FPGA. There are also 11 multipliers unused in the design, so there's more that can be done in parallel if necessary. The state machine part that computes the voices can actually be 2 clocks longer than I currently have it, so there's yet more room. The target FPGA is the smallest and least expensive one I have. The board that this is running on costs $50.
JovianPyx
Audio files: 224
PostPosted: Thu Apr 01, 2010 7:04 am    Post subject: Reply with quote  Mark this post and the followings unread
Yesterday I finished the operator zero feedback path. I have never heard a DX7, at least not that I know of, I'm sure some commercial pieces of music have used them, but I am not aware of any good examples - especially examples which use this DX7 feature. So I am at a disadvantage in determining what it should do and what it should sound like.
What I hear while testing is not what I expected, and I'm not sure of my expectations. For the settings of feedback amount that I've played with, I hear what I can best describe as portamento on very low notes and almost no effect on high notes with stronger portamento as I play lower and lower - to the point where it sounds rather silly.
After cogitating about the circuit, I can see why the effect might be more intense at lower frequencies - this is because the amount of feedback is not scaled by the "base" frequency setting of the operator. This reminds me of trying to use a linear pitch CV with pitch modulation where the bass notes have a wild effect and the treble notes have little to no effect.
Does anyone here know if the DX7 scaled the feedback amount to track the note's base frequency?
JovianPyx
Audio files: 224
PostPosted: Tue May 11, 2010 4:10 pm    Post subject: Reply with quote  Mark this post and the followings unread
Well, I've done a lot of work on this to troubleshoot a set of problems. The detuning of low notes turned out to be a shortcut I tried to take that didn't work as I thought it should. I found this by simplifying the design such that each voice was a single self feedback operator.
I want to play with other algorithms to create the feedback path for this, currently the synth can do morphs between near-sawtooth and sine wave with simple feedback. This is probably going to evolve into a new synth design.
JovianPyx
Audio files: 224
PostPosted: Wed May 12, 2010 1:59 pm    Post subject: Reply with quote  Mark this post and the followings unread
This little experiment seems to be sprouting the beginnings of a new synth, I added some ADSRs to control amplitude and modulation and I can get some interesting sounds. "Brass" would be my description.
Still haven't experimented with other feedback algorithms, that's next. I wanted to first determine if it was worth my time at all.
Rykhaard
PostPosted: Wed May 12, 2010 3:56 pm    Post subject: Reply with quote  Mark this post and the followings unread
Whhhhaaat?? I can't hear anything! Wink Wink
JovianPyx
Audio files: 224
PostPosted: Wed May 12, 2010 5:41 pm    Post subject: Reply with quote  Mark this post and the followings unread
Ok, here's a small sample of the patch I'm messing with right now.
This synth has only an oscillator and waveshaper with EG per voice. There is no filter in this design.
Feedback_FM_Brass_Sound_001.mp3
Feedback FM Brassy Sound
 Filename:  Feedback_FM_Brass_Sound_001.mp3
 Filesize:  309.88 KB
 Downloaded:  1403 Time(s)
Rykhaard
PostPosted: Wed May 12, 2010 6:00 pm    Post subject: Reply with quote  Mark this post and the followings unread
Surprised Whoa. By chance - have you any higher octaves available for play? That, having been created from your mind - wow. Surprised
If coming - I can't wait to hear more'n 1 oscillator doing it. Surprised Smile
JovianPyx
Audio files: 224
PostPosted: Wed May 12, 2010 6:09 pm    Post subject: Reply with quote  Mark this post and the followings unread
Higher octaves - yes, I used only the lower two because they sounded more brassy on this patch...
Further development will depend on whether I can come up with other feedback algorithms that sound different.
Even a fairly small FPGA could probably do 16 voices with 4 of these oscillator feedback FM things per voice, so yeah, probably really fat brass is possible.
JovianPyx
Audio files: 224
PostPosted: Thu May 13, 2010 10:37 am    Post subject: Reply with quote  Mark this post and the followings unread
EDITING: This post has been edited.
I should note that this technique doesn't produce confoundingly new sounds. This project started as a troubleshooting device which thankfully worked. It will, however allow high polyphony and/or multiple oscillators per voice even in a small FPGA (400K equivalent gates).
I've added one additional feedback algorithm to the design. I can select "linear feedback" which is the original, simple feedback system and "squared feedback" which is the linear feedback squared before applying to modulate the phase increment.
Here is a sample with notes through 5 octaves, first a run of notes with linear feedback and then a similar run of notes with squared feedback. (Note that the synth is capable of more than 5 octaves, but that's as wide as my keyboard is).
The difference is more than subtle, so I will try some other things too. The linear feedback results in a near sawtooth wave (at max modulation) and the squared feedback results in what looks like a lowpass filtered square wave.
Feedback_FM_002.mp3
Feedback FM Sample with Linear and Squared Feedback
 Filename:  Feedback_FM_002.mp3
 Filesize:  699.65 KB
 Downloaded:  1325 Time(s)
ian-s
Audio files: 42
G2 patch files: 626
PostPosted: Thu May 13, 2010 12:47 pm    Post subject: Reply with quote  Mark this post and the followings unread
If you square the modulator, you get a sine with twice the frequency (and a dc offset and half the level). So you are effectively changing the MC Ratio to 2:1.
Nice feature.
JovianPyx
Audio files: 224
PostPosted: Thu May 13, 2010 1:29 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yeah, I was just thinking sine squared identity too, and it seems that the technique bolsters the second harmonic.
I've now thought that since I have sawtooth, triangle and square waves readily available, there's no reason I couldn't try substituting those waveforms for the modulation signal. The audio output would still be taken from the sine table, but modulation could come from any of saw, tri and square or summed combos of more than one waveform. Whatever the modulation waveform, the system will always allow morphing to a sine wave which gives an effect similar to a lowpass filter.
Rykhaard
PostPosted: Thu May 13, 2010 2:07 pm    Post subject: Reply with quote  Mark this post and the followings unread
It took me a while to ply my ears up off of the floor, for BOTH patches! I know part of it's the envelope over time in the structure of the tonality, but both of them especially in the higher pitches were BEAUTIFUL sounding patches! Surprised
The 2nd one especially caught me ears as it almost immediately reminded me of the ancient Kawai K1 (additive) synth patch 'Jazz Harp' which to this day is STILL, one of my most favourite synth sounds, ever. Very percussive and beautifully melodic. The only mild difference with your 2nd patch, is just a tad longer time in Release. Otherwise very close in sounding ... very beautiful.
Wow! Hail the Master
JovianPyx
Audio files: 224
PostPosted: Thu May 13, 2010 3:47 pm    Post subject: Reply with quote  Mark this post and the followings unread
Why thank you Rich. Heh, I'm cheating a little because this thing is polyphonic and I like to set the ADSRs to let it ring out - and the ADSRs I use now all have selectable linear or exponentially decaying release.
I just tested the new modulation waveforms. Mixed results... Triangle modulation sounds similar to sine modulation, nice sound. Sawtooth modulation is raucus sounding until set to very low modulation level, square is "buzzy". Phase will make a difference here I think. If I allow changing the phase relationship between the output sine function and the modulator function... I am imagining modulating with a square wave pi/2 out of phase with the sine function.
And another sample, some fiddling using sawtooth modulation, you will likely note the modulation effects...
Feedback_FM_saw_modulation_003.mp3
sawtooth modulation sample
 Filename:  Feedback_FM_saw_modulation_003.mp3
 Filesize:  1.76 MB
 Downloaded:  1294 Time(s)
Rykhaard
PostPosted: Thu May 13, 2010 6:01 pm    Post subject: Reply with quote  Mark this post and the followings unread
Cheating or not - I were dang well impressed! Surprised
Uh oh ... stepping out beyond my 4 basic functions of math (having forgotten almost everything else, from almost 30 yrs. ago. Surprised )
Jaw dropping! Some wondeful melodies themselves coming from what almost appeared to be, something close to a Harpsichord (my most favourite instrument, period, since 1981) with extra release time, through a mild phase shifter.
All together a wonderful combination! Surprised Providing a wonderful almost 'warmth' to the digital world. Surprised Smile Very Happy
