seraph
Editor
Audio files: 33
Joined: Apr 03, 2004 Posts: 24625 Location: The Netherlands, Enschede
Audio files: 317
Posted: Tue Mar 30, 2010 2:37 am Post subject:
If its not a patch doing the noise it's no good I say, and nothing like USB noise I've been having. _________________ Jan
seraph
Editor
Audio files: 33
Posted: Tue Mar 30, 2010 6:55 am Post subject:
no Jan, it's not a patch  _________________ homepage - blog - forum - youtube
| Quote: | | Don't die with your music still in you - Wayne Dyer |
varice
Audio files: 29
G2 patch files: 54
Posted: Tue Mar 30, 2010 7:59 am Post subject:
From the clip, it sounds like the noise is coming out of only one output. Is that correct?
Do you also hear this noise from the headphone output?
I had a problem where I noticed that one output was intermittently dropping in volume. It turned out to be just a bad connection between the cable plug and the output jack. After I removed and plugged the cable a couple of times, the problem went away. _________________ varice |
pOisK
Posted: Tue Mar 30, 2010 10:00 am Post subject:
Hello Seraph,
I've exactly the same problem here !
I've mailed the Clavia Support but they didn't help me at all, just told me to go my local repair man ...
I've tested everything I think:
The noise comes, disappears et comes back again, it's really annoying..
I'have checked all the cables, tried the G2 alone on the power supply, even with nothing connected, just the headphones I can hear the noise on the right ear.
A friend of mine checked and rebuild the welds on the power card. The noise is still there.
The noise can disappear for an instant when I touch the synth and press it (on the red parts).
I've uploaded the recorded noise so you can hear it:
http://soundcloud.com/synth33
I don't have time to bring my G2 to repair, I hope it won't cost a lot to repair it .... |
seraph
Editor
Audio files: 33
Posted: Thu Apr 01, 2010 3:50 am Post subject:
| varice wrote: | From the clip, it sounds like the noise is coming out of only one output. Is that correct?
Do you also hear this noise from the headphone output?1
yes, that's correct, noise on one side only.
I'll try with headphones and report
thanks  _________________ homepage - blog - forum - youtube
pOisK
Posted: Thu Apr 01, 2010 4:19 am Post subject:
Hello,
As I said before, it's the same on the headphones out. the noise remains in the right ear. |
seraph
Editor
Audio files: 33
Posted: Fri Apr 02, 2010 7:56 am Post subject:
| pOisK wrote: |
same here  _________________ homepage - blog - forum - youtube
varice
Audio files: 29
G2 patch files: 54
Posted: Sun Apr 04, 2010 12:00 am Post subject:
Oh no, that’s not so good. That means that the problem is not just localized to the G2 output jack… it might be just something as simple as a cold solder joint somewhere between the DAC and the headphone amp/audio output jack… or worse, a circuit component is failing…  _________________ varice |
pOisK
Posted: Mon May 03, 2010 12:56 pm Post subject:
Hello !
Good news !!
I took my G2 to get it repaired: apparently, it was just a bad contact between the motherboard and the dsp optional card.
the guy has just correctly put the card on the slots and the noise has gone
And it cost me 0€
Hope it will solve your problem too.
Cheers |
seraph
Editor
Audio files: 33
Posted: Mon May 03, 2010 3:07 pm Post subject:
| pOisK wrote: | | Hope it will solve your problem too. |
No, unfortunately. It was a defective DAC in my case
translation: 150 euro to get it fixed  _________________ homepage - blog - forum - youtube
