Nord Rack 2x with Novation SLMK2 midi?
Page 1 of 1 [5 Posts]
EricDeluxe
PostPosted: Fri Apr 16, 2010 2:43 am    Post subject: Nord Rack 2x with Novation SLMK2 midi?
Subject description: Any midi templates available or need to set up manually?
Hey
Nord rAck 2x is a fantastic synth. Just bought one in mint condition the other day:) I use a novation SLMK2 as midi keyboard. I tried to just set up these via midi and a my laptop, didn´t use DAW.
It worked out well, and I could use the midikeyboard. But some small issues/questions.
1. It seem like the knobs of the 2x is not working, when using the SLMK2 controls? Any ideas?
2. Is there a midi template available for 2x to use with Novation SKMK2? Or do I need to set it up via template editor?
Thanks for now:)
Novation SLMK2
 Filesize:  38.16 KB
 Viewed:  4288 Time(s)
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Fri Apr 16, 2010 2:51 am    Post subject: Reply with quote  Mark this post and the followings unread
Most of the time people use the knobs of the NR2X and on the controller only the Keys, Bend and ModWheel. So I think you have to construct it yourself. In the Manual is a list of CC and which parameter.
If you were able to do it, I invite you to publish it also here for commun ity use.
Wout
EricDeluxe
PostPosted: Fri Apr 16, 2010 3:17 am    Post subject: Reply with quote  Mark this post and the followings unread
Wout
Yes, I guess that you are right, and this is the normal way. However, as the MK2 has a pitch bend, drum pads and more controllers, it could be handy. Thanks anyway.
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Fri Apr 16, 2010 4:29 am    Post subject: Reply with quote  Mark this post and the followings unread
The drum pads could be hany to use in Percussion mode, but you have to assing them to a Midi Note out (Key?)
In NordLead terms the Rack - controller combination is always limited. The Key version can do much more, special in Performance mode (single Programs)/Layers.
Wout
EricDeluxe
PostPosted: Fri Apr 16, 2010 5:14 am    Post subject: Reply with quote  Mark this post and the followings unread
Wout
Yeah, guess you´r right. I only use the rack it in the studion any way, so thats cool I believe:)
