How to run TL072s on a single supply?
Page 1 of 1 [9 Posts]
j.dilisio
PostPosted: Mon Apr 19, 2010 3:57 pm    Post subject:  How to run TL072s on a single supply?
Subject description: Buffering my tr-606 trigger outs.
I need to buffer the trigger outputs on my tr-606 and I've got a bunch of TL072s I'd like to use but they need a bipolar supply.
The 606 runs on 6v dc.
I came across this bit of info in another forum..
"Audio amps are not single supply. You will need to split the supply
(+/- 4.5V) or invert it (+/- 9V) to create a signal ground."
So my questions are:
What is the easiest way to invert or split a dc supply?
Is there an easier/better way to buffer the outputs?
Thanks,
J
DRONEGOAT
Sound
PostPosted: Mon Apr 19, 2010 4:17 pm    Post subject: Reply with quote  Mark this post and the followings unread
If you put two same value resistors in series from +6 to Ground, in its node you will create a virtual ground at 3V.
j.dilisio
PostPosted: Mon Apr 19, 2010 4:21 pm    Post subject: Reply with quote  Mark this post and the followings unread
Oh, cool.
I'll give it a try. Very Happy
DRONEGOAT
Sound
PostPosted: Mon Apr 19, 2010 4:48 pm    Post subject: Reply with quote  Mark this post and the followings unread
j.dilisio also you could buffer the trigg with a logic chip. But I don't know which one its the appropriate. Does anyone know?
j.dilisio
PostPosted: Mon Apr 19, 2010 9:27 pm    Post subject: Reply with quote  Mark this post and the followings unread
Wait a sec,. when you wire these up as buffers nothing gets hooked up to ground. So without a ground or virtual ground to reference, what's the difference between a bipolar and single supply?
Also, it doesn't say in anywhere in the datasheet what the minimum supply voltage or range is. Does anyone know if +-3v is enough?
DRONEGOAT
numbertalk
PostPosted: Tue Apr 20, 2010 6:22 am    Post subject: Reply with quote  Mark this post and the followings unread
Take a look at how stompboxes do it. Here's a buffer circuit that runs off of a single 9V supply with a TL071 used as a voltage follower/buffer run with ground and the +9V supply - maybe wiring up your TL072 something like this would work for you?
http://www.generalguitargadgets.com/pdf/ggg_icbuf_sc.pdf
PostPosted: Tue Apr 20, 2010 11:18 am    Post subject: creating virtual GND Reply with quote  Mark this post and the followings unread
Here are 2 methods I use. Usually the first one will suffice, but If I have a circuit with a couple of opamps that need GND, I go for the second one which is more stable.
virtual GND from single power supply
 Filesize:  4.79 KB
 Viewed:  181 Time(s)
nicolas3141
PostPosted: Thu Apr 22, 2010 1:49 am    Post subject: Reply with quote  Mark this post and the followings unread
Using a spare opamp to do it the second way is good. But really needs 9V or 12V or more for most opamps. On 6V you are only getting +/-3V and TL07x opamps can't do input/output voltages that are anywhere close to the rail voltages. They like to stay at least 2 or 3 volts away from both rails. Which means on +/-3V you can really only handle signals of a few millivolts before things start to deteriorate.
There are some opamps designed for low voltage operation that can handle signals close to their rail voltages. Better to use one of them.
Nicolas
j.dilisio
PostPosted: Thu Apr 22, 2010 9:37 am    Post subject: Reply with quote  Mark this post and the followings unread
This is what I ended up doing..
There's a slight loss in signal but otherwise it works fine. I can plug the trigger outputs into each other without them affecting one another.
The opamps were giving me a constant 2v output at all times.
It also says in the datasheet that the input voltage should not exceed +V or 15v, whichever is less.
DRONEGOAT
