 Forum index » Clavia Nord Modular » G2 Performances - Noodles
Obnoxicon
Page 1 of 1 [5 Posts]
ian-s
Audio files: 42
G2 patch files: 626
PostPosted: Sat Jan 15, 2005 1:43 pm    Post subject: Obnoxicon Reply with quote  Mark this post and the followings unread
This one started out as a simple, over-modulated PM noise generator. I made 8 variations then duplicated into 4 VA’s. The noise is enveloped and variation changes are triggered at random bar intervals, so not all 4 noise generators are heard at once, well, maybe sometimes. The variations also have a S&H module selecting random values on each load so that the same variation will sound different each time it is selected.
Because the basic patch is quite small (DSP wise), I have put some carefully chosen sub patches in the four FX areas. This illustrates the difference between an expanded G2. In this prf, the total DSP and MEM for each slot (add the VA and FX figures together) does not exceed 100%. On an expanded G2, you could get twice as complicated with up to (but not exceeding)100% in each area.
Enjoy (or not)
obnoxicon.prf2
G2 Performance
 Filename:  obnoxicon.prf2
 Filesize:  13.25 KB
 Downloaded:  2213 Time(s)
obnoxicon-Edit.mp3
Audio sample 1:14
 Filename:  obnoxicon-Edit.mp3
 Filesize:  946.45 KB
 Downloaded:  1785 Time(s)
Dadooronron Ron
G2 patch files: 21
PostPosted: Sat Jan 15, 2005 2:16 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hmmm... nice beat, nice twists, it even runs on my minimalistic G2 engine...
Yep, I enjoyed it!
cebec
G2 patch files: 31
PostPosted: Sat Jan 15, 2005 9:59 pm    Post subject: Reply with quote  Mark this post and the followings unread
wow, lots of cool ideas to study. and above all, it's inspiring work.
Roland Kuit
G2 patch files: 127
PostPosted: Sun Jan 16, 2005 6:41 am    Post subject: Obnoxicon Reply with quote  Mark this post and the followings unread
Nice work Ian,
sorta Kraftwerk in space Smile
Audio files: 235
PostPosted: Sun Jan 16, 2005 11:17 am    Post subject: Reply with quote  Mark this post and the followings unread
Cool
