Vco for 303
Page 1 of 1 [15 Posts]
jackdamery
PostPosted: Mon May 03, 2010 1:34 pm    Post subject: Vco for 303 Reply with quote  Mark this post and the followings unread
I found this schematic for the 303
http://machines.hyperreal.org/manufacturers/Roland/TB-303/schematics/roland.TB-303.schem-5.gif
It appears to show the vco area but I was wondering
does anyone have a schematic for just the vco of the 303 with the CV input, and output labelled?
LektroiD
PostPosted: Mon May 03, 2010 4:12 pm    Post subject: Re: Vco for 303 Reply with quote  Mark this post and the followings unread
The CV is labelled, follow the track back from the CV jack. That said, any basic Square/Saw oscillators will do the job. It's only the filter and sequencer that makes this machine interesting.
LektroiD
joshco
PostPosted: Tue May 04, 2010 1:05 am    Post subject: Reply with quote  Mark this post and the followings unread
Rene Schmitz has a simple cmos 4069 VCO which has a very rich sqare wave. I dont own a TB but this VCO sounds pretty close to it.
http://www.uni-bonn.de/~uzs159/vco4069.html
Lorenzo
PostPosted: Tue May 04, 2010 1:47 am    Post subject: Reply with quote  Mark this post and the followings unread
It seems to be interesting Wink
anyway the VCO is not he most interesting thing about tb ;D
Yes!
Oh Yeah!
Wow!
joshco
PostPosted: Tue May 04, 2010 5:30 am    Post subject: Reply with quote  Mark this post and the followings unread
the fact that it doesnt use tempcos was the most intresting for me Very Happy
Yves has already a Diode Ladder VCF which should go in the direction, but a clone of the Original TB VCF would be really nice. Dont know if the parts are that rare, for the VCF
iorobyy
PostPosted: Sun May 09, 2010 1:44 am    Post subject: Reply with quote  Mark this post and the followings unread
if you're interested for a good tb303 clone look in http://www.tb303.at/
vco2.
is a modifications for the xoxbox but can work stand alone without problems.
jackdamery
PostPosted: Mon May 17, 2010 5:02 am    Post subject: Reply with quote  Mark this post and the followings unread
vco2.
I had a look at that site, but there doesn't seem to be any schematic for the vco2?
iorobyy
PostPosted: Mon May 17, 2010 11:55 am    Post subject: Reply with quote  Mark this post and the followings unread
sorry i was not clear...is a kit of the 303vco clone as per xoxbox schematic http://www.ladyada.net/media/x0xb0x/mainboard_beta.png that is very similar to tb303 vco structure
jackdamery
PostPosted: Sun May 30, 2010 7:48 am    Post subject: Reply with quote  Mark this post and the followings unread
Is there a schematic for the vco2 though without any of the surrounding 303 electronics?
iorobyy
PostPosted: Sun May 30, 2010 8:54 am    Post subject: Reply with quote  Mark this post and the followings unread
The schematic of the vco2 is exactly the same as the circuitery of xoxbox vco that is very similar (again almost exactly the same) of the original tb303 vco
print xoxbox schematic + print original tb303 schematic from the links posted.
Studying both vco's circuiteries (check the similar parts) you must to found all you need.
If you are in difficult to read schematics maybe try to ask the original vco2 schematic from the .au site.
iorobyy
PostPosted: Sun May 30, 2010 8:58 am    Post subject: Reply with quote  Mark this post and the followings unread
try also the oriental guru mr.takeda
http://www.aleph.co.jp/~takeda/radio/harvest/img/schem/DualTBVCO3a-schem.gif
furio
PostPosted: Tue Jun 01, 2010 2:43 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi iorobyy!
I have build this weekend a vco2 and sounds great.
But this dual version is very interesting for the sync feature.
Is it possible to have some help to choose the unlabelled transistors?
jackdamery
PostPosted: Tue Jun 01, 2010 4:20 pm    Post subject: Reply with quote  Mark this post and the followings unread
furio have you got a schematic for the vco2?
furio
PostPosted: Wed Jun 02, 2010 1:12 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi jackdamery,
The schematic should be like or te same in the x0xb0x:
The KIT for one vco2 with all components inclusive one alpha pot and switch is cheap.
In a modular system it is required to serve +12V and +5.33V to +5.333V
The author from vco2 wrote to me, about the VCF:
"Is it better to look for the x0xb0x schematic, because the original Roland schematic is published with some errors".
jackdamery
PostPosted: Wed Jun 02, 2010 2:35 am    Post subject: Reply with quote  Mark this post and the followings unread
Where can you buy them from? I can't find anywhere on their site to buy stuff.
