Behringer BCR2000 and a G2 engine
Page 1 of 2 [40 Posts]
Afro88
Audio files: 12
G2 patch files: 79
PostPosted: Thu Dec 16, 2004 5:22 am    Post subject: Behringer BCR2000 and a G2 engine Reply with quote  Mark this post and the followings unread
Well, I took the plunge and bought a BCR2000 to go with my engine. What can I say? This piece of gear has breathed new life into my G2. Nothing quite compares to having a bank of knobs in front of you to tweak your patches! I now know how the G2 key users feel, being able to tweak tens of parameters from their synth without having to look at a computer screen. It really is a completely new experience designing a patch, then turning off your computer screen and spending a good hour or so tweaking and programing variations with your hands on real knobs. It's like I'm creating completely new synths with each G2 patch, and then learning how to program them, which is what I originally wanted from my G2. Instead of the counter intuitiveness of programming variations using a mouse, playing the keyboard, going back to the mouse, playing the keyboard, it feels like I'm programming a real physical synth. I highly reccomend the BCR2000 to anyone with an engine - these two pieces of gear are really made for each other!
I have designed a patch for the BCR so that every knob and button (all 108 of them when using the encoder groups!) is assigned to usable G2 midi CC's.
The first row of buttons is programmed to change variations, the second row is split into two - four that send out cc's from 0 to 127 in 5 increments for waveform selection and the other four as normal on/off switches. The top row of encoders' switches (8 for each encoder group too) are assigned as normal on/off types too. All the knobs are assigned as normal from 0 to 127.
g2engineSetupFixed.syx
BCR2000 patch for G2 engine. Fixed 8th variation button.
 Filename:  g2engineSetupFixed.syx
 Filesize:  10.43 KB
 Downloaded:  387 Time(s)
PostPosted: Thu Dec 16, 2004 5:39 am    Post subject: Reply with quote  Mark this post and the followings unread
Hey, sounds cool!
I still have that Evolution U-Control and I was thinking about using that one with the NM1. at work I have a huge Roland plotter which also has a foil cutting knife. The U-control came with a lot of those plastic sheet overlays that matces a set of different parameter controls for several NI softsynths. Theoretically I could make my own sheets for both the NM1 and the U-Control. I could laminate the prints before I cut the holes for the pots and sliders etc. I was wondering if any of you guys have a 1:1 eps file of the NM1 frontrol surface? I can of course make my own drawing in Adobe Illustrator.
When I think of it I could probably mass produce such tepmlate sheets .. complete with text and holes and stuff.
Flickr
ffransis
PostPosted: Thu Dec 16, 2004 7:08 pm    Post subject: Reply with quote  Mark this post and the followings unread
Comments on the useability of the Evolution UC-16 would be appreciated. The Behringer BCR2000 is undoubtedly very powerful, but what I want is a simple MIDI control surface with a smaller form factor than the Behringer, which is why I'm thinking about the Evolution UC-16.
PostPosted: Fri Dec 17, 2004 2:26 am    Post subject: Reply with quote  Mark this post and the followings unread
Hmm.. I have the U-Control UC 33.
Flickr
gomidas
G2 patch files: 6
PostPosted: Fri Dec 17, 2004 4:27 am    Post subject: Re: Behringer BCR2000 and a G2 engine Reply with quote  Mark this post and the followings unread
I agree with that at 100%.
I bought the BCR2000 three weeks ago, even the knobs looks like the G2 key Razz (with more control at the same time!!)
There are many ways to manage presets, I'll send my stuff to the forum when it's completly finished...
Engine + BCR2000 = Pure Heaven Twisted Evil
PostPosted: Fri Dec 17, 2004 5:38 am    Post subject: Reply with quote  Mark this post and the followings unread
I haven´t used that one yet, but I am sure it is very good. Behringer for some reason equals Satan on many boards. I cannot really see why. A lot of what Behringer makes is of course low end budget gear, but all the Behringer stuff I have tested actually works quite well. Many of the mixers aren´t really that good, but the gear compares well with similar low end products from other vendors. That said, the popular Mackie budget mixers aren´t really that much better.
Flickr
seraph
Editor
Editor
Audio files: 33
PostPosted: Fri Dec 17, 2004 8:38 am    Post subject: Re: Behringer BCR2000 and a G2 engine Reply with quote  Mark this post and the followings unread
Afrokid wrote:
I highly reccomend the BCR2000 to anyone with an engine.
no OSX drivers Crying or Very sad
gomidas
G2 patch files: 6
PostPosted: Fri Dec 17, 2004 9:20 am    Post subject: Re: Behringer BCR2000 and a G2 engine Reply with quote  Mark this post and the followings unread
For the moment....
But I didn't use the editor at all to configure the BCR2000.
You can edit your presets without it easily Wink
Use any sysex dump program (send & receive) to backup your presets.
Until the OSX editor comes out...
Wink
Rob
G2 patch files: 109
PostPosted: Fri Dec 17, 2004 7:39 pm    Post subject: Re: Behringer BCR2000 and a G2 engine Reply with quote  Mark this post and the followings unread
gomidas wrote:
For the moment....
Wink
Yeah, I use a BCF2000 and it is faster to program on the box than to use the PC edit utility, that btw is a drag to use.
It is true that they are a bit bulky, but they sit nice on the table and there is a nice spacing between the controls, so its easy to grab the right one in 'hectic moments'. I think both the BCR and the BCF are really nice companions for an Engine and quite a bargain for what they do.
cebec
G2 patch files: 31
PostPosted: Mon Dec 20, 2004 7:56 am    Post subject: Reply with quote  Mark this post and the followings unread
i used the sysex preset for my bcr2000 and G2 key and it worked great! thank you very much for this!
wavesinspace
PostPosted: Sun Dec 26, 2004 7:09 am    Post subject: g2 + bcr2000 knob position feedback Reply with quote  Mark this post and the followings unread
Hi I went out and bought the bcr2000 + g2 after I saw this post... are you guys getting knob position feedback from the g2 to the bcr2000? for instance I have 1 knob assigned to osc pitch on variation 1... when I switch to variation 2, that knob is in a different position on the g2... yet my bcr2000 still reflects the old value... i assumed I would get two way communication with the bcr2000 as I thought that was the point of the leds.
I have my bcr2000 connected through logic 7 via usb and I have midi in and out connected to the g2 via my amt8.
am I asking for too much here?
thanks
Paul
Rob
G2 patch files: 109
PostPosted: Sun Dec 26, 2004 9:39 am    Post subject: Re: g2 + bcr2000 knob position feedback Reply with quote  Mark this post and the followings unread
thanks
Paul
No, check in the synth settings if "Send MIDI controller" values is enabled for the G2.
There is also the Dump MIDI controllers command from on the G2 frontpanel, e.g. after you have loaded a new patch/performance.
Anyway, read the MIDI section of the manual.
Success
wavesinspace
PostPosted: Sun Jan 16, 2005 10:36 am    Post subject: Reply with quote  Mark this post and the followings unread
ok
I read the midi implimentation of the g2 manual but hasnt really gotten me very far...
so when I switch from variation 1 to varaiaton 2, I have to manually press "apple-m" on my laptop to send the bcr2000 all the controller values.. is there any way to automate this? is there a midi message for this "request all controller values" and somehow combine that message with the variation change buttons on the bcr2000?
it would be nice if there was 2 checkboxes on the g2 editor:
1. send all controller values when changing variations
2. send all controller values when changing patches
these two options would seal the deal.
has anyone else ran into this limitation? if so, how are you dealing with it?
wavesinspace
PostPosted: Sun Jan 16, 2005 6:21 pm    Post subject: Reply with quote  Mark this post and the followings unread
I think i just answered my question.... turrns out I have an old manual (g2 software v.1.1) - there are no sysex commands in the old manual..
I just looked online and found on page 133 of the new manual (1.2x) there is a sysex command to request all controler values...
now I just have to figure out how to combine this message with the variation change and patch change buttons and I am golden.
Audio files: 228
PostPosted: Sun Jan 16, 2005 8:32 pm    Post subject: Reply with quote  Mark this post and the followings unread
I just ordered a Behringer BCR2000 to use with my G2 and other gear. I'll be working with this same problem.
egw
G2 patch files: 8
PostPosted: Mon Jan 17, 2005 8:27 am    Post subject: Reply with quote  Mark this post and the followings unread
Can the BCR2000 send sysex commands?
Since I don't use a laptop/editor when playing, I would have to be able
to trigger an update to the knob values, either from the synth or from the BCR. Is this possible?
seraph
Editor
Editor
Audio files: 33
PostPosted: Mon Jan 17, 2005 10:45 am    Post subject: Reply with quote  Mark this post and the followings unread
afaik no, it can't Crying or Very sad
Audio files: 228
PostPosted: Mon Jan 17, 2005 11:25 am    Post subject: Reply with quote  Mark this post and the followings unread
You can send out an update MIDI from the front panel; Click System and then the > button.
There seems to be a problem with this in that you have to do this everytime you change a patch, or performance, and everytime you change a variation.
It would be nice if Clavia gave us a system option to do this automatically.
diskonext
PostPosted: Tue Jan 18, 2005 12:54 am    Post subject: Reply with quote  Mark this post and the followings unread
The BCR2000 should be able to send (short) sysex-commands.
I think you can only have the BCR2000 'learn' them, so you'll have to expose it to the sysex you need.
-diskonext
:wq
Fozzie
G2 patch files: 49
PostPosted: Tue Jan 18, 2005 1:48 am    Post subject: Reply with quote  Mark this post and the followings unread
I am also lusting for a BCR2000. This is what I found in the manual; shouldn't be too hard to send a midi controller snapshot request:
(Quote:) Data request: current value settings of the midi device connected to your B-control can be transmitted to your B-control using the data request function (provided that the midi device supports this function, and a request command was defined using the editor software). In this case, the midi device doesn't send data; the B-control requests them instead.
--> Press the LEARN key while the EDIT key is kept pressed.......(end of quote)
blabla and it should be done.
So, according to the manual, the BCR can send sysex messages, and these can either be programmed via the midi Learn function (elsewhere in the manual) or via the software editor. On page 133 of the G2 manual you can find the sysex string needed for a controller snapshot request, so I guess and hope that this functionality is present and working.
Does anyone know whether the G2 sends controller values at a variation change, when in synth settings 'controller send' is turned ON? If so, one would not have to request a controller snapshot after every variation change.
For us engine owners, there are no convenient front panel knobs that invoke a controller send (from G2 to BCR), so it will be critical that a controller snapshot request can be requested from the BCR2000.
Audio files: 228
PostPosted: Tue Jan 18, 2005 7:46 am    Post subject: Reply with quote  Mark this post and the followings unread
I put my G2 on a MIDI analyzer (MIDIOX) and it does not send controller updates when you change variations, even when Send Controllers is ON. Crying or Very sad
Rob
G2 patch files: 109
PostPosted: Tue Jan 18, 2005 10:57 am    Post subject: Reply with quote  Mark this post and the followings unread
-diskonext
That's what I did on the BCF2000, I assembled some sysex strings on the computer and I sent them to the BCF2000 while it was in learn mode by using an applet named MIDI-OX.
Audio files: 228
PostPosted: Tue Jan 18, 2005 4:00 pm    Post subject: Reply with quote  Mark this post and the followings unread
Welcome back. Long time no see.
So what do you do? Set up a button to push that sends a SYSX message to the G2 and gets all the knobs updated?
Do you think there's any chance Clavia would put an option into the G2 to send MIDI updates when a patch, performance, or variation is changed?
Rob
G2 patch files: 109
PostPosted: Wed Jan 19, 2005 8:01 am    Post subject: Reply with quote  Mark this post and the followings unread
Its picking up the pieces.
I got the BCF2000 for its ability to send 10bit resolution NRPN commands from the motorfaders. I figured out to receive these hires NRPNs in sets of eight on the G2, but as yet cannot send them back to the BCF2000. So, right now I make patches that only use the CC#s that can be send from the four groups of eight rotary encoders and buttons on the BCF and the BCF hires fader defaults are stored in the BCF2000 and not in the G2 patch. E.g. I can use a fader to set the delay time of a 1 sec delay module in 1 msec increments by patching the hires NRPN to the delaytime modulation input.
Like you, I would like the automatic sending of CC#s after patchload or var change as an option to be enabled or disabled in the Synth settings. I have no idea why it isn't already there, should be easy to program, me thinks. Maybe Clavia is so fixed on marketing the keyboard models that they simply forgot about engine users. But that seems unlikely to me.
On the BCF2000 I programmed four presets, each for one of the slots. On one of the four programmable buttons on the lower right of the BCF2000 I programmed the 'all controllers request' sysex strings for the slot the preset belongs to. A second button sends CC#80 on the global channel. The third and fourth have no use yet.
I must press this CC# request button after a patchload or var change. Which is not really a nuisance in practice.
Why the BCF2000:
I have two engines permanently hooked up by an ADAT I/O converter to my digital desk and the BCF2000 is meant to control them. Perhaps I should get another BCF to permanently control the other engine. This setup connects eight separate G2 inputs and outputs to the desk. So, the link is the ADAT lightpipe from the desk to an eight mono-channel converter that connects to the eight inputs and outputs of the two engines to the desk. As the desk connects by another ADAT lightpipe to the PC that does the recording I can e.g. route from a PC audiotrack to an engine and back again to another PC audio track to be recorded, without much latency. The only latency in the chain is from the AD and DA converters and is always exactly the same, a total of 2.3 msec. And if I use the channels for parallel processing it is sample accurate between the channels. My bet is that this is much more reliable than an USB link like on the new Virus, hèhè. And eight send/receive channels. Twisted Evil
Anyway the link sounds pretty much ok to me. Needless to say I use this config for external effects purposes mainly. It is an incredible powerful setup, I plan to use it for at least the next five years.
Imho Clavia is missing the boat by not marketing the engine as a studio processor tool. It is especially the possibility of patching crossover filters that allows to apply effects on certain ranges of the audio spectrum only. To me this is proving to be extremely effective in a mix. I hardly patch keyboard patches or noodles, but mostly effects patches, and it is very rewarding. Its like I stepped into a whole new and pretty shining world, waiting to be discovered. My guess is that it will keep me happy for quite a long time to come. Smile
cebec
G2 patch files: 31
PostPosted: Wed Jan 19, 2005 8:31 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi Rob! Glad to see you back, too...
If you don't mind, could we see some examples of these effects that you've been using your Engines for? Or at least, basic templates or examples of these effects? What you said really sparked my curiosity! Do you have an example of a patch that allows effecting of specific frequency bands?
