today> Twyndyllyngs Chez Mosc
ChucK Skool
Page 1 of 1 [6 Posts]
Inventor
Audio files: 267
PostPosted: Fri May 21, 2010 12:21 am    Post subject: ChucK Skool
Subject description: A class for newbie ChucKists
The topic of where to begin learning ChucK comes up so much that I thought we might have a bit of fun making a ChucK Skool. I'll begin with Lesson 1: The SinOsc. Here is the code:
Code:
SinOsc s => dac;
440 => s.freq;
day => now;
Which is posted as an attached file. Here we have a SinOsc Ugen going straight out the dac and therefore into your ears. It is set for a 440 Hz oscillation by the second line and we wait a day before the program ends to allow things to play basically indefinitely until we stop them.
I invite you to create other lessons for newbies and post them to this thread if you think it is worth doing. I will try to add more later.
Les
Lesson1.ck
ChucK Skool Lesson 1
 Filename:  Lesson1.ck
 Filesize:  43 Bytes
 Downloaded:  330 Time(s)
Inventor
Audio files: 267
PostPosted: Fri May 21, 2010 1:43 am    Post subject: Reply with quote  Mark this post and the followings unread
This program makes a demonic vocoder applied to your voice. Here is the code:
Code:
adc => PitShift ps => dac;
ps => Gain fb => ps;
0.8 => ps.shift;
0.9 => fb.gain;
day => now;
Here the adc is the mic which goes into a pitch shifter ad out to the dac. A gain UGen provides feedback and the shift and gain parameters define the effect. A very simple program with a lot of potential for fun.
Les
Lesson2.ck
Lesson 2 of ChucK Skool
 Filename:  Lesson2.ck
 Filesize:  92 Bytes
 Downloaded:  311 Time(s)
PostPosted: Fri May 21, 2010 4:01 am    Post subject: Reply with quote  Mark this post and the followings unread
Les
Excuse my nitpicking, but I'd call that a demonic pitch shifter. Wink You might argue that this might be seen as a vocoder in a very broad sense of the word, but usually it refers to something that sets the pitch (rather than shift it) using an array of band-pass filters. I might be wrong, in which case you're free to squeeze my nose.
In any skool, it's very important to get the definitions right.
Anyway, cool idea for a thread!
/Stefan
Inventor
Audio files: 267
PostPosted: Fri May 21, 2010 10:36 am    Post subject: Reply with quote  Mark this post and the followings unread
Oh, well then I stand corrected, Stefan. I was not aware of that definition specifically.
Les
PostPosted: Fri May 21, 2010 11:45 am    Post subject: Reply with quote  Mark this post and the followings unread
Les
NP Les! I'd like to emphasize again that I think this is a really cool thread. :)
I should contribute something instead of just being annoying... one of my favourite ChucK things is sporking and Events:
Code:
Event bell;
fun void waiter1() {
   <<< "Waiter1 stands up" >>>;
   bell => now;
   <<< "Good evening, sir." >>>;
fun void waiter2() {
   <<< "Waiter2 stands up" >>>;
   bell => now;
   <<< "Can I get you anything?" >>>;
fun void waiter3() {
   <<< "Waiter3 stands up" >>>;
   bell => now;
   <<< "Shall I get your coat?" >>>;
spork ~ waiter1();
spork ~ waiter2();
spork ~ waiter3();
1::second => now;
bell.signal();
1::second => now;
bell.broadcast();
1::second => now;
spork ~ waiter2();
spork ~ waiter2();
1::second => now;
bell.broadcast();
1::second => now;
Note how signal() wakes one waiter and broadcast() wakes all who are waiting. The spork ~ lines starts the functions, causing the sporked waiters to wait for the bell. When the waiter functions reach their end, they finish and will not do anything more before being sporked again, which I do with waiter2 at the end. Note also that you can spork a method more than once.
A bit long, maybe...
/Stefan
Inventor
Audio files: 267
PostPosted: Fri May 21, 2010 12:00 pm    Post subject: Reply with quote  Mark this post and the followings unread
OK, Stefan, I've saved your code and tested it working fine. nice use of events and notice the different types of broadcasting. No sound out of this one, only text, and more of an intermediate lesson than a beginner one but that's all good. File posted below, who's up for Lesson 4?
Les
Lesson3.ck
ChucK Skool Lesson 3
 Filename:  Lesson3.ck
 Filesize:  611 Bytes
