Freq and Res pot for Ghost Dance filter?
Page 1 of 1 [5 Posts]
acidblue
PostPosted: Sat Jun 05, 2010 12:51 pm    Post subject: Freq and Res pot for Ghost Dance filter? Reply with quote  Mark this post and the followings unread
Hi There.
Title says it all.
Would the Resonate pot come after the 0.0015uF cap?
Not sure where to put a pot for frequency sweep, possibly
for the variable resistor?
 Filesize:  7.05 KB
 Viewed:  8369 Time(s)
Top Top
PostPosted: Sun Jun 06, 2010 10:56 am    Post subject: Reply with quote  Mark this post and the followings unread
I'll say I did try adding a resonance pot to this design, but gave up after a little bit.
You can check here for the info I was given when I asked on another board:
http://www.diystompboxes.com/smfforum/forums.html?topic=84516.0
Yes, the frequency pot is that "VR" to ground.
acidblue
PostPosted: Sun Jun 06, 2010 11:33 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks Top.
Strangely enough I did pretty much the same as you, I used a .01 cap instead of
the .0015 and used a 470 pf cap, just don't have any 680pf atm,
I added a 10k pot for the VR and a 5k one after the .01,(.0015) cap.
This seems to act like a coarse and fine tune for frequency.
But sometimes when turned low or high I think I can hear a change in Resonance.
Although I could be wrong.
Gonna experiment a little more and see.
Top Top
PostPosted: Wed Jun 09, 2010 1:37 am    Post subject: Reply with quote  Mark this post and the followings unread
acidblue wrote:
Thanks Top.
I got best/fullest sweep of the filter with a 25K pot... FYI...
Resonance, I realized I just didn't need it for what I was doing and I gave up on it, but following the advice in that thread may get you somewhere.
synthmonger
PostPosted: Fri Jun 11, 2010 8:39 pm    Post subject: Reply with quote  Mark this post and the followings unread
You could also replace the VR with a current sink using a 2n3904. This will allow voltage control and you could tune the cut off frequency range quite a bit better.
I'd suggest using two more inverters as amplifiers with a feedback path going from output to input if for your resonance control.
Youtube!
modular demos!
Whacky tunes!
