6PDT CMOS or Relay Switching
Page 1 of 1 [11 Posts]
emdot_ambient
PostPosted: Fri Jul 16, 2010 10:00 am    Post subject: 6PDT CMOS or Relay Switching
Subject description: For a Control Bus design
I'm toying with the idea of adding a Control Bus section on a 19" panel I'm designing.
There would be 2 bus lines each with CV, Gate and Trigger. The feature I'd like to add is a "flip-flop" switch that would swtich all of Bus 1 to Bus 2 and visa versa via one switch. I'm really only interested in manually triggering this, not using an gate input, though a gate input would be cool in some situations.
Here's the layout as I see it, represented with 2 3PDT switchs. What I don't really know how to do is to add one switch to trigger what is essentially a 6PDT action. All the 6PDT switches I've seen are either too expensive (like over $300), or are PCB mounted push-push switches and I'm not very keen to do PCB mounted panel components and don't like the lack of visual feedback on push-push buttons.
So, I was thinking that CMOS or relays would be the answer. Relays would probably be simpler to implement, but I'm not sure if I'd get glitches in the CV lines when the filp-flop is triggered. I'm a noob when it comes to designing circuits, though, and can't readily figure out how to implement a CMOS solution.... thinking
 Filesize:  13.92 KB
 Viewed:  8750 Time(s)
emdot_ambient
PostPosted: Fri Jul 16, 2010 10:09 am    Post subject: Reply with quote  Mark this post and the followings unread
Oh, and what I'm wanting to use this for is essentially to provide a partial preset ability to the panel.
The panel will contain 2 VCO, 2 VCF, 2 VCEG and 2 VCA. All of which will be normalized to each other and will also have switches to connect them to either of the 2 Control Bus lines.
But if I put all of them on Bus 1 and had a sequencer plugged into Bus 1, and then a different sequencer on Bus 2 playing an alternate pattern and/or key, I could switch all the modules to Bus 2 instantly with the flip-flop switch. Instant new pattern/key. Very Happy M.HAPPY!
andrewF
PostPosted: Fri Jul 16, 2010 8:20 pm    Post subject: Reply with quote  Mark this post and the followings unread
maybe a 6 pole, 2 position rotary switch is the cheapest and easiest option
like this one
tjookum
Audio files: 26
PostPosted: Sat Jul 17, 2010 2:03 am    Post subject: Reply with quote  Mark this post and the followings unread
Im not really sure if I understand you correctly, but if you're looking for a cmos analog switch I can highly recommend the 4066.
It switches when 2/3 of Vdd is achieved and is very bulletproof to wire up.
Hunter S. Thompson
movies
noise
andrewF
PostPosted: Sat Jul 17, 2010 9:05 am    Post subject: Reply with quote  Mark this post and the followings unread
4066/4016 will certainly work but you will need 3 of them.
Rykhaard
PostPosted: Sat Jul 17, 2010 9:46 am    Post subject: Reply with quote  Mark this post and the followings unread
That's very true as the 4016 / 4066 have only 4 separate swtiches that will switch 1 input each, on/off.
Another chip based way to go, would be the CD4053, which is a triple, SPDT switch. With 2 of them, you'd have your 2 switches for switching between 2 input items.
The easiest method still though, would be the 6 pole double through rotary switch. Since they're built basically on the multi pole / 12 connectors standard, they shouldn't be expensive at all.
emdot_ambient
PostPosted: Sun Jul 18, 2010 8:55 pm    Post subject: Reply with quote  Mark this post and the followings unread
like this one
That's pretty much what I had been looking for but couldn't find. thumb up
None of my searches was finding anything close to that. Hmm...of course it's out of stock.
emdot_ambient
PostPosted: Sun Jul 18, 2010 9:00 pm    Post subject: Reply with quote  Mark this post and the followings unread
You'd think, but damned if I can find any that are in stock anywhere.
emdot_ambient
PostPosted: Sun Jul 18, 2010 9:04 pm    Post subject: Reply with quote  Mark this post and the followings unread
The simple answer is I need a solution that provides a 6PDT action...one switch that switches 6 inputs between 2 different outputs.
And I think break before make would be best so that the two signals aren't ever going to the output bus at the same time. Make before break might give me CV spikes...though I'd be willing to risk it if I could find the part.
andrewF
PostPosted: Sun Jul 18, 2010 10:04 pm    Post subject: Reply with quote  Mark this post and the followings unread
how about 24 pole 2 pos ($4.95), 6 pole 5 pos or 6 pole 3 position
from Electronic Surplus?
emdot_ambient
PostPosted: Mon Jul 19, 2010 10:37 am    Post subject: Reply with quote  Mark this post and the followings unread
andrewF wrote:
how about [url=http://www.electronicsurplus.com/Item/1883/]24 pole 2 pos ($4.95)
That's just crazy!
