Filter design using the LTC1562-2
Page 1 of 1 [4 Posts]
metacohl
PostPosted: Thu Jul 29, 2010 12:41 pm    Post subject: Filter design using the LTC1562-2 Reply with quote  Mark this post and the followings unread
Does anyone have experience using this chip for audio?
here is the datasheet http://cds.linear.com/docs/Datasheet/15622fa.pdf
Its marketed for radio frequencies, but I am trying to figure out if it can be adapted for audio. The data sheet provides diagrams for chebyshev, butterworth, and other filter types.
metacohl
PostPosted: Thu Jul 29, 2010 12:57 pm    Post subject: Reply with quote  Mark this post and the followings unread
looking at the data sheet it says that
f0=200khz(sqrt((7958Ohm)/R2)) for one of the filter arrangements
sooo... f0=20khz R2= 795800 Ohms?
So maybe a trimming resistor and a POT in series if you wanted to have a usable f0 range under 20khz?
Audio files: 321
PostPosted: Thu Jul 29, 2010 1:17 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yes, or, 0.8 Meg ... so 80 Meg for 2 kHz .. Resistance that large will mean that when you breathe over the circuit f0 will go all the way ... not very usable for the audio range.
I see tho that the internal capacitor is between INV and V1 being both accessible from the outside - maybe you could add some extra capacitance there to help f0 down .. stability may be an issue then or it may blow up under certain conditions.
metacohl
PostPosted: Thu Jul 29, 2010 1:26 pm    Post subject: Reply with quote  Mark this post and the followings unread
Ahh yes, I did not really think about what a absurdly high resistance that is. You might be right about adding more capacitance between INV and V1. I'd have to do some math to figure out the implementation of that and, like you said, any possible issues that might arise from that implementation.
Maybe someone else can confirm this?
