THAT2180 VCA-Based Phaser All-Pass Section
Page 1 of 1 [7 Posts]
mediatechnology
PostPosted: Mon Jul 26, 2010 10:11 am    Post subject: THAT2180 VCA-Based Phaser All-Pass Section Reply with quote  Mark this post and the followings unread
I've been looking for phaser designs using THAT VCAs and didn't find any. I wanted to use VCAs for fast response and headroom. Google led me to Sam Hoshuyama's very clever design using the SSM2164. I began my experiments using a bootstrapped shunt R approach but the Hoshuyama design was superior. So with the help and support of both Sam and Gary Hebert of THAT I came up with this all-pass section. The THAT VCA, unlike the SSM2164, is non-inverting overall. (The SSM2164 is non inverting but the I-V converter flips polarity.) The following transforms the original design to use a non-inverting VCA teamed up with a THAT1240 to provide a precision all-pass section.
There are sound file demos posted here and throughout the thread:
http://www.proaudiodesignforum.com/forum/php/viewtopic.php?f=6&t=368&start=36
The original discussion starts here:
I don't post here very often but thought you guys might find it interesting.
Best;
Wayne
emdot_ambient
PostPosted: Mon Jul 26, 2010 12:36 pm    Post subject: Reply with quote  Mark this post and the followings unread
So...the schematic above is 1 pole and then you'd just string together N number of them?
mediatechnology
PostPosted: Mon Jul 26, 2010 1:20 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yes, string them in series with the Ec bused.
A few notes:
Ec should be driven by a bipolar op amp to maintain low Ec bus impedance over frequency.
Bifets are needed in the integrator(s) due to the need for low bias current.
emdot_ambient
PostPosted: Mon Jul 26, 2010 1:44 pm    Post subject: Reply with quote  Mark this post and the followings unread
The slow noise sweep sounded quite good. In stereo with some delay added would be even better Very Happy
mediatechnology
PostPosted: Thu Jul 29, 2010 3:27 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks! There are some A+B A-B stereo demos of the earlier topology earlier in the proaudiodesignforum thread. The new topo essentially sounds the same but has wider range. I hope to get some time to build up four more poles and do a stereo demo of this one.
frijitz
Audio files: 54
PostPosted: Thu Jul 29, 2010 4:56 pm    Post subject: Reply with quote  Mark this post and the followings unread
Just out of curiosity, have you considered using higher-order structures (eg, second order Bessel)?
Ian
mediatechnology
PostPosted: Fri Jul 30, 2010 12:30 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks Ian. I haven't tried higher-order structures other than 8X cascaded single pole sections.
