Dynaudio82
Posted: Wed Jun 23, 2010 4:59 pm Post subject:
| Wout Blommers wrote: | | temptation_07 wrote: | | ... About your question of the menu, you mean this? | Yes, that's what I mean
Are those 'Yoke' ports special Midi ports? I would select [828mk2] in both menu's. If you check it again, they will probably have been changed. That's a bug in NordGen. Select at MidiIn the [828mk2].
Is the Midi In on the Motu connected with the Midi Out of the synth?
If so, perform [Shift+DumpOne] see if the parameters (knobs) in NordGen has changed...
I forgot to tell you to open [Sysex] and select in the menu [receive]!!!
Wout
(fingers crossed) |
Yes the Midi in of Motu connected in Midi Out of synth... Sorry for the delay i get internet problem but im back...
Well about the Midi Yokes dont have any function for the moment because are not completly installed, in theory they creates internal MIDI devices for standalone Software Musical Instruments...
This is the site: http://midiox.com
and my unresolved problem of why i dont finish yet his configuration:
http://www.midiox.com/cgi/yabb/YaBB.pl?board=MOXInstall;action=display;num=1277332439
About the NordGen, i follow step by step your words but, not works yet
exactly what i will see in the NordGen when this star working correctly?  |
Wout Blommers
Audio files: 123
G2 patch files: 12
Posted: Thu Jun 24, 2010 12:55 am Post subject:
[quote="temptation_07"]... Sorry for the delay i get internet problem but im back...[/quote0Well, I'm on the other side of the pond, so I went to bed  | Quote: | ... exactly what i will see in the NordGen when this star working correctly?  | No flags nor horns As soon as you send the synth command [Shift+DumpOne] the knobs in NordGen will change, if you selected [Sysex > receive]. When the drivers aren't installed mostly NodGen won't recognize the Midi ports. If you want to make sure download the drivers from the Archive page I send you before and copy&paste this in the Windows system folders.
Wout |
Dynaudio82
Posted: Thu Jun 24, 2010 3:15 pm Post subject:
| Wout Blommers wrote: | I'm on the other side of the pond, so I went to bed |
hehe ok perfect
| Wout Blommers wrote: | No flags nor horns As soon as you send the synth command [Shift+DumpOne] the knobs in NordGen will change, if you selected [Sysex > receive]. When the drivers aren't installed mostly NodGen won't recognize the Midi ports. If you want to make sure download the drivers from the Archive page I send you before and copy&paste this in the Windows system folders.
Wout |
what means DumpOne? where is it?
about the Midi Yokes i will back here when i resolve it
by the way... exist some manual in spanish of Nord Lead 2x?
and also Thank you very much for all the help than you give me and the time than you take  |
Wout Blommers
Audio files: 123
G2 patch files: 12
Posted: Thu Jun 24, 2010 3:24 pm Post subject:
| temptation_07 wrote: | | ... what means DumpOne? where is it? | The button next to the PitchStick. It's the OctaveUp button which function as 'DumpOne' when holding Shift too.
Wout
(BTW out of sync again, so off to bed  |
Wout Blommers
Audio files: 123
G2 patch files: 12
Posted: Thu Jun 24, 2010 3:28 pm Post subject:
If there is a Spanish version of the Manual, this address should know...
Hermes Music
Naranjo #76
Col. Sta. María la Ribera
D.F. c.p. 06400
Mexico
mailto: dcarranza@hermes-music.com.mx
Wout |
Wout Blommers
Audio files: 123
G2 patch files: 12
Posted: Mon Jun 28, 2010 1:08 am Post subject:
And when this isn't working either, try switching the Global Midi channel to channel 16.
Wout |
Dynaudio82
Wout Blommers
Audio files: 123
G2 patch files: 12
Dynaudio82
Posted: Sat Jul 31, 2010 7:36 pm Post subject:
ahhhh the octaves! sorry i need new glasses hehe
than you very much again Wout! i will tell you what happen soon, when i get my new computer...
greetings! |
