today> Twyndyllyngs Chez Mosc
USB-CV Interface Project
Page 1 of 2 [42 Posts]
surgesg
PostPosted: Sat Aug 28, 2010 7:53 am    Post subject: USB-CV Interface Project Reply with quote  Mark this post and the followings unread
Here's a project that I've been working on - finally nearing completion. It's an OSC-receiving USB to CV generator.
http://gregsurges.com/circuitry/usb-octomod/
http://gregsurges.com/programming/osc-processing-microcontroller-connect-maxmsp-dac-ic/
At this point, I would appreciate any and all feedback on the project. I'm also considering doing a small run of PCBs in a few weeks, if there's any interest.
Best,
- G
oootini
PostPosted: Mon Aug 30, 2010 7:51 am    Post subject: Reply with quote  Mark this post and the followings unread
sounds very interesting!
oootini
PostPosted: Mon Aug 30, 2010 7:52 am    Post subject: Reply with quote  Mark this post and the followings unread
is this mac only?
surgesg
PostPosted: Mon Aug 30, 2010 8:09 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for checking it out.
Although I'm developing on a Mac, I've chosen Processing as the language for the host app specifically because it's so cross-platform. I have to do some testing, but it should work on Windows and Linux as well.
oootini
PostPosted: Mon Aug 30, 2010 8:40 am    Post subject: Reply with quote  Mark this post and the followings unread
you should post on the muff wigglers forum. you'll get a lot of interest there...
surgesg
PostPosted: Mon Aug 30, 2010 8:44 am    Post subject: Reply with quote  Mark this post and the followings unread
will do, thanks.
BobTheDog
Audio files: 32
PostPosted: Mon Aug 30, 2010 8:47 am    Post subject: Reply with quote  Mark this post and the followings unread
Looks great!
If you do a pcb run then put me down for one.
Andy
surgesg
PostPosted: Wed Sep 01, 2010 7:57 am    Post subject: Reply with quote  Mark this post and the followings unread
To update, I just placed an order for a small run of PCBs. A limited number of kits will be available as well.
- Greg
Danno Gee Ray
PostPosted: Wed Sep 01, 2010 7:58 pm    Post subject: Reply with quote  Mark this post and the followings unread
What would your prices be?
surgesg
PostPosted: Thu Sep 02, 2010 9:37 am    Post subject: Reply with quote  Mark this post and the followings unread
Thinking $16 and shipping for the PCB, not sure about kits yet.
TekniK
PostPosted: Thu Sep 02, 2010 9:54 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi,am interested in a 'kit',but how do you program this thing etc?
surgesg
PostPosted: Thu Sep 02, 2010 10:27 am    Post subject: Reply with quote  Mark this post and the followings unread
Teknik,
Well, I'm considering provided pre-programmed chips if desired, but you can also program your own using the Arduino environment.
I'll be posting the source code soon, but I'm just wrapping things up to make sure it works cross-platform.
I did a little tutorial here: http://gregsurges.com/programming/osc-processing-microcontroller-connect-maxmsp-dac-ic/
If this seems too complex, don't let it scare you. I've done all of the hard serial coding, and all the user really needs to do is generate OSC data from whatever method they like. This tutorial is really just to show what goes on behind the scenes, and to document my process.
Does that help?
- Greg
TekniK
PostPosted: Fri Sep 03, 2010 4:47 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi Greg,thanks for reply.
i don't think its something for me.
am just after a cv/gate interface i can built into module form wich match my module format and can directly communicate via midi trough usb.
very handy just hooking a laptop to my modular via usb
surgesg
PostPosted: Sat Sep 04, 2010 5:40 am    Post subject: Reply with quote  Mark this post and the followings unread
I've made a mailing list to let people know when PCBs are ready.
http://www.gregsurges.com/circuitry/usb-octomod/
- Greg
PostPosted: Sat Sep 04, 2010 8:36 am    Post subject: Reply with quote  Mark this post and the followings unread
Cool project! I would be interested in buying a kit or PCB as well. Smile
/Stefan
surgesg
PostPosted: Thu Sep 09, 2010 9:50 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi everyone,
I'm excited to announce that the first run of PCBs for the USB-Octomod has arrived! There are 20, and it seems like they will go fast.
You can check out the project page here: http://www.gregsurges.com/circuitry/usb-octomod/
There is also a link to order the PCB on that page.
Boards will be $16 + shipping, and I'm set up for Paypal and Google Checkout.
I've also posted the source for both the Teensy microcontroller and the Processing Host app on that page.
Thanks for your interest in the project!
- Greg
surgesg
PostPosted: Tue Sep 14, 2010 7:49 pm    Post subject: Reply with quote  Mark this post and the followings unread
Well, they did go fast, only a few left. I've got mine working with an Arduino instead of Teensy too. Seems to work equally well, actually.
Posted some code for that here: http://www.gregsurges.com/circuitry/usb-octomod.
max92
PostPosted: Wed Sep 15, 2010 4:22 pm    Post subject: Reply with quote  Mark this post and the followings unread
I could be interested! do I need to program any IC myself? cause i've never done anything like that. only soldering and setting analog modules up...
surgesg
PostPosted: Wed Sep 15, 2010 4:41 pm    Post subject: Reply with quote  Mark this post and the followings unread
I will soon have kits or pre-populated boards, no programming necessary.
max92
PostPosted: Thu Sep 16, 2010 12:31 am    Post subject: Reply with quote  Mark this post and the followings unread
Great!
surgesg
PostPosted: Wed Sep 22, 2010 10:33 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi all,
The 2nd batch of USB-Octomod PCBs has arrived. Some of these are going to be set aside for pre-populated boards or kits, but there are about 14 more. If you're interested, you can check them out at http://www.gregsurges.com/circuitry/store/ and http://www.gregsurges.com/circuitry/usb-octomod/.
More soon,
- Greg
max92
PostPosted: Wed Sep 22, 2010 3:08 pm    Post subject: Reply with quote  Mark this post and the followings unread
I'd very much like a kit Smile
max92
PostPosted: Wed Sep 22, 2010 3:49 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hm... Can I controll it thru anything else than Max/MSP? i am only using Live without Max for Live. Can I still send OSC?
surgesg
PostPosted: Wed Sep 22, 2010 4:02 pm    Post subject: Reply with quote  Mark this post and the followings unread
You can use any software that transmits OSC. Lots of open-source stuff out there, PD, ChucK, etc.
The osc interface is /dac chan1 chan2 chan3 chan4 chan5 chan6 chan7 chan8
surgesg
PostPosted: Mon Oct 04, 2010 3:52 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hello everyone,
I've finally got some full sets of components available. I've got five sets, which can be shipped either as pre-assembled, tested boards, or as component kits w/ a pre-programmed Teensy 2.0.
You can check them out at http://www.gregsurges.com/circuitry/store/
Enjoy!
- Greg
