Buchla 208 Random PCB
Page 3 of 5 [125 Posts]
julian
PostPosted: Mon Nov 30, 2009 4:02 pm    Post subject: Reply with quote  Mark this post and the followings unread
Its not pretty, but...
I wanted to make the board self supporting, so i messed about making it into a euro module. Its not glamorous, or particularly well thought out, but i think itll work (its populated now, but i dont have all the ics at present)
Julian
My euro-hack : /
 Filesize:  631.9 KB
 Viewed:  2544 Time(s)
For custom cnc engraved panels see - http://www.thebeast.co.uk/cnc/
Coriolis
PostPosted: Tue Dec 01, 2009 1:56 am    Post subject: Reply with quote  Mark this post and the followings unread
Hey that's cool! Looks good I think...
C
Tasmanian Alkaloid
PostPosted: Wed Dec 02, 2009 2:55 pm    Post subject: Reply with quote  Mark this post and the followings unread
I made a video of my 208 module. I haven't made a panel for it yet, but i put a CGS LED driver on each of the outputs.
The video title is a bit of a misnomer- the blue flashing LED is from a CGS Utility LFO, & the 4 LED's of the 208 are at the back.
It's a really fun module for firing off parameters like delay time cv, or for mixing to a single (summed) signal.
In the video, the 208 triggers delay parameters, a 258 VCO, Teezer & VCS.
The VCS triggers the 208 & the Utility LFO & VCS modulate the oscillators.
Thanks Romeo & to Luka
RF
Audio files: 28
PostPosted: Fri Jan 22, 2010 6:38 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for the PCB run guys -well done!
I shoulda bought more of them than I did... If anyone has a couple they want to part with, PM me Smile
I finished the build on the first one of mine late last night. I added an internal clock, ext clock input, votage range adjust for each output and clock/trigger outputs.
I enjoyed experimenting with it last night and look forward to using it more. Among other things, I know I'll be using it often as a CV for various filters - I have sometimes tied up a sequencer doing that duty and this is a much better solution.
bruce
 Filesize:  70.73 KB
 Viewed:  2516 Time(s)
www.sdiy.org/rfeng
mono-poly
PostPosted: Mon Jan 25, 2010 12:11 pm    Post subject: Reply with quote  Mark this post and the followings unread
Still waiting for my pcbs to arrive Mad
fluxmonkey
PostPosted: Mon Jan 25, 2010 7:32 pm    Post subject: Reply with quote  Mark this post and the followings unread
problem solved (they showed up shortly after this was posted). hope you like 'em!
b
www.fluxmonkey.com
mono-poly
PostPosted: Tue Jan 26, 2010 3:18 am    Post subject: Reply with quote  Mark this post and the followings unread
I guess i will!
Thank you!
ricoloverde
PostPosted: Fri Aug 27, 2010 8:27 pm    Post subject: 208 thanx Reply with quote  Mark this post and the followings unread
Hi got a pcb for this off muffwiggler and built it today. Really enjoying it. Thank you so much for this one, cant wait to play with it more...
rico
Quad
PostPosted: Sat Sep 11, 2010 4:39 am    Post subject: Reply with quote  Mark this post and the followings unread
I finally sat down and finished one of these, it works great. A lot of fun. Thank you Now I'm thinking I should build in a voltage controlled clock, is this something I could rip out of the 266 design (I am thinking the FRV 555 driver might work) or should I look for a VC-lfo, which is simplest to build? What have you guys used?
fluxmonkey
PostPosted: Sat Sep 11, 2010 4:16 pm    Post subject: Reply with quote  Mark this post and the followings unread
you might look at the 4046-based vco that's part of ken stone's digital noise...
www.fluxmonkey.com
Peake
PostPosted: Wed Sep 15, 2010 11:33 am    Post subject: Reply with quote  Mark this post and the followings unread
If anyone has one or more of these PCBs they'd like to part with, please contact me.
electang
PostPosted: Thu Sep 16, 2010 10:40 am    Post subject: Reply with quote  Mark this post and the followings unread
I would be interested in one PCB too
Please contact me
Thanks
LektroiD
PostPosted: Fri Sep 17, 2010 6:56 am    Post subject: Reply with quote  Mark this post and the followings unread
If there are any PCBs left, please let me know, as I'd like one.
Many thanks Smile
LektroiD
krisp14u
PostPosted: Fri Sep 17, 2010 11:45 am    Post subject: Reply with quote  Mark this post and the followings unread
also be in for 2 PCB if there is a rerun I just dont feel like etching no more Razz
Paul Darlow
www.krisp1.com
Peake
PostPosted: Fri Sep 17, 2010 12:08 pm    Post subject: Reply with quote  Mark this post and the followings unread
I almost have 1000 posts, and I'm pretty sure that EM sends out free PCBs to you when you pass 1000, so I'll forward them as they come in.
(hides)
RSFC
PostPosted: Fri Sep 17, 2010 5:29 pm    Post subject: Reply with quote  Mark this post and the followings unread
I'll take 1 or 2 if there is another go.
synthi
PostPosted: Mon Sep 27, 2010 4:39 am    Post subject: Reply with quote  Mark this post and the followings unread
same here: 2 pcbs if the rerun is done Cool
fluxmonkey
PostPosted: Mon Sep 27, 2010 4:51 am    Post subject: Reply with quote  Mark this post and the followings unread
i don't have permission to do a second run of the original design; but i might consider a run of a modified layout to include an onboard clocking vco and some (optional) output level trimmers. please continue to post so i can gauge interest.
b
www.fluxmonkey.com
/mr
PostPosted: Mon Sep 27, 2010 6:09 am    Post subject: Reply with quote  Mark this post and the followings unread
I could use a PCB or two if it's done.
A clocking oscillator would be a good thing to include (I would add one if I'd build one myself), but output level trimmers feel unnecessary. Decent synths have level pots on their inputs. Smile
fluxmonkey
PostPosted: Mon Sep 27, 2010 7:11 am    Post subject: Reply with quote  Mark this post and the followings unread
as designed, these outputs swing almost rail-to-rail, so i usually put at least some fixed dividers to bring 'em down to +/-5 or 10 v. of course, they'd be entirely optional.
www.fluxmonkey.com
/mr
PostPosted: Mon Sep 27, 2010 7:45 am    Post subject: Reply with quote  Mark this post and the followings unread
That's a good idea. Smile
The Bad Producer
PostPosted: Mon Sep 27, 2010 11:10 am    Post subject: Reply with quote  Mark this post and the followings unread
b
I'd probably go for a few (4 maybe?) if this happens..
Charlie
Quad
PostPosted: Mon Sep 27, 2010 11:44 am    Post subject: Reply with quote  Mark this post and the followings unread
A variable lag processor that could be coupled with the clock could be an interesting add-on...
rosch
PostPosted: Tue Sep 28, 2010 4:09 am    Post subject: Reply with quote  Mark this post and the followings unread
i'd be interested too. at least 2 please-
thank you!
Photon
PostPosted: Tue Sep 28, 2010 6:50 am    Post subject: Reply with quote  Mark this post and the followings unread
Sounds great, bbob. I'm interested in a board or two. The output trimmers and clock would be very nice additions.
