Guitar pickup Pitch changer
Page 1 of 2 [29 Posts]
Synthrotek
PostPosted: Fri Sep 17, 2010 3:00 pm    Post subject: Guitar pickup Pitch changer
Subject description: I am looking to build a simple circuit that changes the pitch
Hey guys I want to figure out a way to change the pitch of my guitar, so in effect tuning it with out tuning the pegs. Any ideas? Sad
D.Miñoza
Audio files: 31
PostPosted: Fri Sep 17, 2010 4:05 pm    Post subject:
Subject description: pluck the twanger
http://www.digitech.com/products/Pedals/Whammy.php
i do not play one but these are fun.
soundcloud
relaxedmachinery
Synthrotek
PostPosted: Fri Sep 17, 2010 5:57 pm    Post subject: Reply with quote  Mark this post and the followings unread
I am attempting to make a synth with pickups, and I want to tune 10 pickups or more, so the price on a whammy pedal x10 would not really be in my range. I am hoping I can tune it with pots and some simple circuit for each step.
D.Miñoza
Audio files: 31
PostPosted: Fri Sep 17, 2010 6:37 pm    Post subject: Re: Guitar pickup Pitch changer
okey-dokey Cool
btw- guitar pickups dont have a pitch..they dont generate sound at all so...
Am I misreading you again?
Good luck with your project.
soundcloud
relaxedmachinery
Synthrotek
PostPosted: Fri Sep 17, 2010 7:19 pm    Post subject: Reply with quote  Mark this post and the followings unread
http://gieskes.nl/instruments/?file=cappuccino-synth
I will have some spinning metal to generate a frequency, but after that I want to alter the pitch...
D.Miñoza
Audio files: 31
PostPosted: Fri Sep 17, 2010 9:38 pm    Post subject: Reply with quote  Mark this post and the followings unread
ok, so the guitar pickup can't alter the pitch of the metal.
in this case you could manipulate the spinning metal to alter pitch.
or a DSP like the one i suggested is an alternative.
here's something else: http://www.guitarpitchshifter.com/index.html
soundcloud
relaxedmachinery
Synthrotek
PostPosted: Sat Sep 18, 2010 7:07 am    Post subject: Reply with quote  Mark this post and the followings unread
Well if it is not practical to alter the pitch after, what about before with a RLC circuit. Or a LC circuit. Will this grew be able to be picked up by a pickup? Any schematics on how to do this?
StephenGiles
PostPosted: Sat Sep 18, 2010 7:47 am    Post subject: Reply with quote  Mark this post and the followings unread
Rolling Eyes Rolling Eyes Rolling Eyes Rolling Eyes
PostPosted: Sat Sep 18, 2010 7:53 am    Post subject: Reply with quote  Mark this post and the followings unread
Nope, you can't .. physically impossible. Easiest way is to tune the strings ... or alter the rotation speed of the metal bits ... only other way is a pitch shifter. L(R)C circuits will not perform pitch shifts.
oldschool57
PostPosted: Sun Sep 19, 2010 7:08 am    Post subject: Reply with quote  Mark this post and the followings unread
You want this:
http://www.rolandus.com/products/productdetails.php?ProductId=849
Synthrotek
PostPosted: Mon Sep 20, 2010 8:20 am    Post subject: Reply with quote  Mark this post and the followings unread
Ok, no offense - thanks for the great posts, but I am looking for a way to alter and tune the sound at the pickup level, not by having a post processor. Obviously Neon lights, CRTs, cell phones etc. affect the induction? and make noise on the pickup by disturbing the magnetic field. checkout:
http://www.freesound.org/samplesViewSingle.php?id=27789
I am looking for a circuit that can add "hum" if you will but something that I can tune and ultimately make a keyboard out of it.
Any ideas here. Thanks again!
Synthrotek
PostPosted: Mon Sep 20, 2010 4:57 pm    Post subject: Reply with quote  Mark this post and the followings unread
Ok, I think I have narrowed this down... I need a circuit that will give me variable hertz. 5-100 hertz I guess, hopefully with a pot to change the frequency. Needs to be ac I believe for the pickup to pick-up.
Ideas?
Taylor
PostPosted: Mon Sep 20, 2010 11:00 pm    Post subject: Reply with quote  Mark this post and the followings unread
The pitch of something like this is defined by the speed of the motor. If you use a DC motor running on a 9v battery, you can change the speed by changing the voltage going to the motor.
Synthrotek
PostPosted: Tue Sep 21, 2010 1:25 am    Post subject: Reply with quote  Mark this post and the followings unread
Taylor, thx but I don't want to use a motor.
Taylor
PostPosted: Tue Sep 21, 2010 1:39 am    Post subject: Reply with quote  Mark this post and the followings unread
Confused
Well then how do you plan to make this thing? Have you read up at all on how it actually works?
slacker
PostPosted: Tue Sep 21, 2010 4:28 am    Post subject: Reply with quote  Mark this post and the followings unread
Sounds like what he wants is a circuit that will spray out RF that the pickup can then dedect.
You can possibly just build a simple CMOS based oscillator, if you wave the pickup round that you should pick something up. I've done something similar just using a metal plate as a "pickup".
Have a look in the Lunetta forum here for examples.
Synthrotek
PostPosted: Tue Sep 21, 2010 9:14 am    Post subject: Reply with quote  Mark this post and the followings unread
Slacker- thx. Do you have a schematic for any of the projects that you worked on? Also, I can't see that link, do you mind re posting that? Thx
slacker
PostPosted: Tue Sep 21, 2010 11:05 am    Post subject: Reply with quote  Mark this post and the followings unread
There wasn't a link I meant the Lunetta forum further up the page.
Here's a link to a simple oscillator http://www.electro-music.com/forum/topic-23878.html first post in that thread. All you need is the bits round round IC1A, where is says Osc1 is the output, if you just connect a length of wire to the output that will make a transmitter and holding your pickup near it will hopefully pick up the signal.
Taylor
PostPosted: Tue Sep 21, 2010 11:14 am    Post subject: Reply with quote  Mark this post and the followings unread
But he says above:
So the pitch is created by how fast the metal spins, as in the video he posted, so in this case the pitch is, as I said above, determined by how fasts the metal spins, which is controlled by the motor. Am I crazy or missing a piece of the puzzle here?
slacker
PostPosted: Tue Sep 21, 2010 11:33 am    Post subject: Reply with quote  Mark this post and the followings unread
I don't know mate, maybe I've completely misunderstood, I was just going by what he wrote here.
Which I took to mean he didn't actually want spinning bits of metal, just something that would generate noise a pickup could detect.
Synthrotek
PostPosted: Tue Sep 21, 2010 11:38 am    Post subject: Reply with quote  Mark this post and the followings unread
Sorry for the miscommunication, I dont really want to use spinning metal
Taylor
PostPosted: Tue Sep 21, 2010 12:19 pm    Post subject: Reply with quote  Mark this post and the followings unread
Ah, well then I guess Slacker's got you covered.
So what function does the metal pickup serve when the sound generation is electronic?
Synthrotek
PostPosted: Tue Sep 21, 2010 1:54 pm    Post subject: Reply with quote  Mark this post and the followings unread
I believe if it is an ac oscillation I should be able to pick it up with a pickup. I don't think a timer by itself will do it.
Synthrotek
PostPosted: Tue Sep 21, 2010 3:58 pm    Post subject: Reply with quote  Mark this post and the followings unread
Some dude sent me this:
http://www.free-circuit.com/wp-content/uploads/2010/05/DC-to-AC-with-IC.gif
Do I need the transformer, or can my pickup "hear" the freq from the Inductor L1?
Thanks in advance
ian-s
Audio files: 42
G2 patch files: 626
PostPosted: Tue Sep 21, 2010 6:43 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks in advance
That circuit generates high voltage AC, I suggest you not build it.
Perhaps you could explain why you want to generate an electrical signal, then make that signal produce a signal in a pickup, which then produces an electrical signal at the output of the pickup.
The signal at the output of the pickup will just be a very low voltage copy (perhaps phase shifted) of your original signal. Do you imagine this will be useful somehow?
