SSM2210 Vs LM394
Page 1 of 1 [21 Posts]
The Bad Producer
PostPosted: Mon May 18, 2009 7:50 am    Post subject: SSM2210 Vs LM394
Subject description: ?
Hello,
I was wondering if these are substitutable for each other? I was about to buy some LM394's from Bridechamber, but I see he no longer (never did?!) stocks them, though he does have the SSM2210.
I've done a bit of research, but nothing to say "Yes, go ahead and swap",
any help would be most appreciated,
Thanks,
Charlie
softfin
PostPosted: Mon May 18, 2009 8:37 am    Post subject: Reply with quote  Mark this post and the followings unread
It's an equivalent to lm394 and will work fine.
The Bad Producer
PostPosted: Mon May 18, 2009 9:44 am    Post subject: Reply with quote  Mark this post and the followings unread
Thank you Softfin,
I thought they might be, and I'd looked at the datasheets, but it helps to be sure!
Thank you,
Charlie
ultrashock
PostPosted: Wed Sep 22, 2010 8:29 am    Post subject: Reply with quote  Mark this post and the followings unread
the time goes on... and now on the analog.com site the SSM2210 are NO LONGER available.
The nearest solution from AD is the full substitute SSM2212 (I observed it more expensive by my local dealer's prices. at the same time the ssm2210 are out of stock but there are some at $9 price per unit in another dealer (which is actually, afwul).
the ssm2210 are also out of stock at digikey as well as BCM847
p.s.: are there any other matched pairs alternatives today?
marctims
PostPosted: Wed Sep 22, 2010 8:39 am    Post subject: Reply with quote  Mark this post and the followings unread
two hand matched 2N3904 NPNs will work.
softfin
PostPosted: Wed Sep 22, 2010 11:14 am    Post subject: Reply with quote  Mark this post and the followings unread
Or any general purpose NPNs for that matter. Smile
But... those LM394s and SSM2210s etc. are not only hfe matched but also vbe matched if I remember right. So, depending on application lm394s might work better, for example in a differential pair based mic preamp.
For most synth related applications simply hfe matched will be enough as far as I know.
Sebo
PostPosted: Wed Sep 22, 2010 4:40 pm    Post subject: Reply with quote  Mark this post and the followings unread
For VCOs exponential converters the transistor pair have to be Vbe matched.
Sebo
My Music:
softfin
PostPosted: Thu Sep 23, 2010 2:35 am    Post subject: Reply with quote  Mark this post and the followings unread
You're right. So Vbe matching is more important than hfe matching in most cases after all. Smile
gwaidan
PostPosted: Fri Sep 24, 2010 4:03 am    Post subject: Re: SSM2210 Vs LM394
The Bad Producer wrote:
Hello,
from what I know, you should be fine to sub the ssm2210. Strife tends to come in the opposite direction, as the LM394 wasn't designed to drive high currents and as a result can cause expo conversion circuits that need to drive more than 1mA to go flat at the high end- Ray Wilson recommends using the SSM2210 over the LM394 in the MFOS VCO for this reason
frijitz
Audio files: 54
PostPosted: Fri Sep 24, 2010 4:34 am    Post subject: Reply with quote  Mark this post and the followings unread
Actually, for expo converters matching is not all that critical. Matching just provides part of the needed temperature compensation by cancelling the prefactor of the exponent. Log conformance is more important, which is why 2N3904 pairs aren't all that great (depending on how much you care about tracking).
Matching is crucial for differential pairs -- just try making a discrete OTA!
Ian
The Bad Producer
PostPosted: Fri Sep 24, 2010 5:18 am    Post subject: Reply with quote  Mark this post and the followings unread
Obviously I'm not super learned on all this, but the high cost and (slight) difficulty in sourcing matched transistor packages, has led me to think about trying Ray Wilsons matching circuit,
here
I'll have to do a bit of reading to understand what you are saying Ian (and even then would probably fall short of totally getting it!), but are you suggesting that hand matching transistors is not a good idea, or just not good for certain applications?
Charlie
frijitz
Audio files: 54
PostPosted: Fri Sep 24, 2010 7:41 am    Post subject: Reply with quote  Mark this post and the followings unread
...has led me to think about trying Ray Wilsons matching circuit...
Oh my, I hadn't seen that before. I wonder why he went to the trouble of making those 10V supplies. It only takes a change of one resistor to adapt the Moog circuit to 12V. Also, I noted that he reproduced the (well-known) error in in the Moog schematic.
Here's the bridge circuit I use for matching NPN pairs. The 100k resistors need to be well matched, and two measurement should be taken with the devices switched. Half the difference of the two readings automatically takes out any remaining small imbalance in the measurement.
It's a good idea, but less critical for expo converters than for differential amps, current mirrors, etc.
Ian
 Filesize:  24.63 KB
 Viewed:  25086 Time(s)
The Bad Producer
PostPosted: Fri Sep 24, 2010 8:08 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for posting that Ian - the clarification too.
I guess the 12V needs to be pretty accurate? also the diode, could I use a 4148 there? Looks really nice and simple!
I also noticed dingebre is producing a transistor matching board along with the other Steiner Synthasystem modules:
http://www.xmission.com/~dingebre/Trans_Match.html
Have you seen that one?
Charlie
frijitz
Audio files: 54
PostPosted: Fri Sep 24, 2010 8:51 am    Post subject: Reply with quote  Mark this post and the followings unread
No, that's not critical at all.
Yes, any ole Si signal diode. It holds the collectors at about .65V, just to keep the devices out of saturation. I like to match at a small collector voltage, because I usually use the opamp integrator method in my Saw VCOs, where the collector is at virtual ground.
Right. That is the original Moog circuit (with the obvious error corrected). He just goes ahead and runs it at 12V instead of 10V. This merely sets the test current at 120uA instead of 100uA. dunno
You don't need fancy circuits for any of this. You are just matching the transistors, not making laboratory-accuracy measurements of anything.
Ian
The Bad Producer
PostPosted: Fri Sep 24, 2010 9:03 am    Post subject: Reply with quote  Mark this post and the followings unread
frijitz wrote:
.......You don't need fancy circuits for any of this. You are just matching the transistors, not making laboratory-accuracy measurements of anything.
Ian
Ha ha, that's good to know! For some reason I'd regarded it as a complex and arcane art, that is why I'd avoided it - or rather not 'dealt' with it yet...
Thanks again Ian...
Charlie
piedwagtail
PostPosted: Fri Sep 24, 2010 10:40 am    Post subject: Reply with quote  Mark this post and the followings unread
I found the SSM2210/2220s failed easily.
I just jammed 2n390xs into the dil sockets when I'd read Arp never matched anything.
Arp 4072 filter/Thomas Henry triangle core vco.
Robert.
SSM2017s fail easily too!
dugernaut
PostPosted: Sun Dec 12, 2010 6:46 pm    Post subject: Reply with quote  Mark this post and the followings unread
What about the old CA3046? 5 transistors on a single chip. They're still available and fairly cheap.
adambee7
PostPosted: Sun Dec 12, 2010 7:00 pm    Post subject: Reply with quote  Mark this post and the followings unread
or the "THAT300" series? Very Happy Very Happy
adambee7
PostPosted: Sun Dec 12, 2010 7:16 pm    Post subject: Reply with quote  Mark this post and the followings unread
But the THAT300 and CA3046 are 14DIP. so if your building a vco from scratch id use these. But for a direct replacement for LM394 or SSM2210 I would match some genereal NPNs. With a decent Digital Meter and Ians matching circuit you could match Vbe of +/-500uV. I normally do 1mV ish Very Happy Very Happy
dugernaut
PostPosted: Wed Dec 15, 2010 4:37 pm    Post subject: Reply with quote  Mark this post and the followings unread
I just looked at Digikey's catalog and there are several surface mount SMT matched pairs for under $0.25 !!! If someone is making a new design and don't mind a little SMT work, that's probably a great option. It should also be possible to make a little adapter board to make it fit in a 394 / 2210 PCB layout.
Does anyone know if there's anything else that makes the 2210 / 394 special that would keep these SMT guys from working? Ian?
frijitz
Audio files: 54
PostPosted: Wed Dec 15, 2010 5:53 pm    Post subject: Reply with quote  Mark this post and the followings unread
Folks have been concerned that those pairs are not monolithic (on the same substrate). But i've been told they work OK. Their log conformance and noise figure aren't as good as those of the supertransistors, so it depends on how concerned you are with accurate tracking.
Ian
