today> Twyndyllyngs Chez Mosc
Simple Quantizer Boards + Chips rev4 avaialable now.
Page 2 of 8 [179 Posts]
Taylor
PostPosted: Sun Oct 10, 2010 2:17 pm    Post subject: Reply with quote  Mark this post and the followings unread
D'oh! Indeed. Being new to modulars I forgot about retuning the VCO's initial pitch.
Boogdish
PostPosted: Sun Oct 10, 2010 3:16 pm    Post subject: Reply with quote  Mark this post and the followings unread
tommi wrote:
I am curious to see how it feels choosing smoothly between modes with a pot instead of a more 'traditional' rotary switch (wow, that's feticism i guess...)
If one takes the time to measure the values of the pot for the needed positions it should be quite easy to use a rotary switch instead w/ the correct resistors in line to switch through the modes.
Yes, this is possible. I used a pot in the design to keep costs down. I thought it was easy to get used to using the pot to select modes though. Your ear should be able to quickly discern between the major and minor modes.
CV mode selection is definitely possible, and could be kludged onto these boards without too much difficulty. You could even bend the center pin of the pot back, run it to the switch of a switching mode cv input jack and then the tip of the jack could go through a zener shunting voltages above 5 and another diode for polarity protection then run down to where the center pin of the mode selection pot would normally go. That way when not using cv mode selection it would work normally. I should draw this up.
Taylor, slacker has the right idea. The easiest way to tune it would be to set your input voltage to zero, and then adjust the tune on your vco until you get whatever root you're desiring. I would like to experiment with having root voltage be user adjustable in the future.
[/quote]
Peake
PostPosted: Mon Oct 11, 2010 8:57 pm    Post subject: Reply with quote  Mark this post and the followings unread
Oops, sent an email order before reading the entire thread...I'll happily pay extra to have an "octave" scale, to allow something like the Buchla/Wogglebug slow random modulator to shift octaves at the destination... Cheers, what a great project/offering!
Taylor
PostPosted: Mon Oct 11, 2010 9:22 pm    Post subject: Reply with quote  Mark this post and the followings unread
I like this idea, too.
Peake
PostPosted: Tue Oct 12, 2010 1:45 pm    Post subject: Reply with quote  Mark this post and the followings unread
It should be fun to send to filters too, or to control panning, etc.
Dego
PostPosted: Tue Oct 12, 2010 2:24 pm    Post subject: Reply with quote  Mark this post and the followings unread
+1
Is the latest code available if you want to add this random modulation?
Boogdish
PostPosted: Tue Oct 12, 2010 7:46 pm    Post subject: Reply with quote  Mark this post and the followings unread
First off, BOARDS ARE IN! I built one up this afternoon and it's working. I have a bunch of boards/pics left. If you preordered one, you should be getting an invoice from me very soon.
Since the octave looks like it will be popular, I think I might just start offering the chip in two flavors. The current version (Bypass, Maj, Min, Maj Pen, Min Pen, Blues, Whole, Chrom) and one with notes more spread out for modulation purposes (Bypass, Maj, Maj Pen, Octave, Roots and Fifths, Tri-tone, Whole, Chromatic). I'll be informing people about this when I send them their invoices. If people don't indicate I'll be sending the standard version.
Also, I've updated the documentation PDF about this, which is on my very bare looking website: bartonmusicalcircuits.com
emdot_ambient
PostPosted: Wed Oct 13, 2010 10:18 am    Post subject: Reply with quote  Mark this post and the followings unread
Boogdish wrote:
...I've updated the documentation PDF about this, which is on my very bare looking website: bartonmusicalcircuits.com
Took a look at the web site...so what's going to be in the Deluxe CV Quantizer? cyclops
Peake
PostPosted: Wed Oct 13, 2010 11:25 am    Post subject: Reply with quote  Mark this post and the followings unread
Great idea (sorry to complicate things!).. Is Maj Pen a Major Pentatonic? And there's still a chromatic/whole tone for sequencers? Brilliant, I'll take the second version!
Cheers.
TekniK
PostPosted: Wed Oct 13, 2010 12:27 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi,is there any risk to damage the circuit if input voltages goes higher then 5v ?
Is it possible to buy only programmed pics?
Boogdish
PostPosted: Wed Oct 13, 2010 5:57 pm    Post subject: Reply with quote  Mark this post and the followings unread
Teknik, unless I've misunderstood the datasheet, the PIC has internal diodes that will shunt voltages to the power rails if it gets too high or too low on the ADC inputs. As far as I know the chip itself has no overvoltage protection though, so connecting pin 1 to a high voltage could fry it.
I'd be happy to do chips by themselves. Does $6 plus shipping sound reasonable?
Peake, "Maj Pen" is shorthand for Major Pentatonic. The octave/fifths version still has Major, Major Pentatonic, Whole Tone, and Chromatic. The Minor/Minor Pen/Blues scales are the ones being replaced.
Emdot, The "Deluxe" version will have user editable modes, it'll use a bunch of switches and have leds thus require more panel space and be less simple. There are a couple other things I want to add, but haven't figured them out yet, so I won't mention them yet. It should be the bloated, inelegant version of this.
Peake
PostPosted: Thu Oct 14, 2010 12:56 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks, I really look forward to this Very Happy
Peake
PostPosted: Mon Oct 18, 2010 10:38 am    Post subject: Reply with quote  Mark this post and the followings unread
Received! Thanks for the great, much-needed project, and best luck on your further endeavours. This is exactly what digital is for!
Boogdish
PostPosted: Mon Oct 18, 2010 6:40 pm    Post subject: Reply with quote  Mark this post and the followings unread
I just updated the original post.
I was waaaay off on shipping prices (misplaced a decimal on the scale) for international orders. Everything is shipping USPS First Class. Overseas guys who've already paid, you should be receiving refunds for the difference.
Also, I changed the pricing for future domestic orders. Instead of $16ppd, it will be $14 per set plus a $2 shipping fee. This is more fair to people ordering in quantity.
Thanks everybody. Boards are still available.
andrewF
PostPosted: Mon Oct 18, 2010 7:54 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for that
much appreciated
Looking forward to some quantizers.....or rather the missus is, she hopes I might actually play in tune for once Wink
Dego
PostPosted: Mon Oct 18, 2010 11:47 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for refund. Really looking forward to try this out Very Happy
funkyfarm
PostPosted: Tue Oct 26, 2010 1:49 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yep !
i've been waiting for this project for months.
We'd take 4 pcb and 4 Octave/Fifth version Chips.
Thank you.
Boogdish
PostPosted: Tue Oct 26, 2010 5:03 pm    Post subject: Reply with quote  Mark this post and the followings unread
I am now SOLD OUT of the first run. A big thanks to everyone whose ordered. I just finished ordering the second run of boards; they should hopefully be here by the end of next week.
Also if anyone has completed the project, I would love to get your feedback about this.
adambee7
PostPosted: Tue Oct 26, 2010 6:09 pm    Post subject: Reply with quote  Mark this post and the followings unread
is it possiblr to purchase just 2 of the pics without pcb? Very Happy Very Happy
Boogdish
PostPosted: Tue Oct 26, 2010 7:23 pm    Post subject: Reply with quote  Mark this post and the followings unread
Sure, $6 each + $2 postage. PM me your e-mail address and I'll send you a paypal invoice.
LektroiD
PostPosted: Wed Oct 27, 2010 12:06 am    Post subject: Reply with quote  Mark this post and the followings unread
I'm in for a board + PIC, if there's any left?
LektroiD
adambee7
PostPosted: Wed Oct 27, 2010 2:08 pm    Post subject: Reply with quote  Mark this post and the followings unread
thanks man. i've pm'ed. these will go nicely in 3 sequencers i'm building on protoboards. Very Happy Very Happy
janvanvolt
PostPosted: Wed Oct 27, 2010 3:27 pm    Post subject: Reply with quote  Mark this post and the followings unread
i'd like to get 3 of them please to germany.
cheers
jan
My dIY - http://diy.czmok.de
Film/Music - http://gfm.me
Terrafractyl
PostPosted: Wed Oct 27, 2010 10:04 pm    Post subject: Reply with quote  Mark this post and the followings unread
I'd be keen for 2 of these Cool
awesome project, thanks a million
Dego
PostPosted: Thu Oct 28, 2010 12:06 pm    Post subject: Reply with quote  Mark this post and the followings unread
Got mine today! thanks Smile
The pcbs are really small and easy to handle.
