Joined: Mar 28, 2006 Posts: 1430 Location: Kansas City, Mo USA
Posted: Mon Oct 04, 2010 10:56 pm Post subject:
Mysterious Bells Subject description: Improvised on the Aries Synthesizer |
I enjoy working with clock-based music and the Aries' gate/trigger logic supports this well.
The problem is, that each trigger (clock tick) retriggers the notes -- producing a reiterative effect (like the repitition of a mallet instrument). I built some new logic circuits (by modifying a Yusynth Logic Board) to pass the first trigger pulse after applying a gate and to pass no more triggers until the gate is released and restarted.
This track then, is my exploration of a musical idea that prompted me to build the new circuitry.
I like the idea of order emerging slowly from randomness and I had this idea to build a work with nothing more than a few disconnected notes. As the work progresses, and more notes are added, the density increases. At some point, the randomness morphs into a rhythmic pulse -- slowly enough that one may not identify an exact moment when this happens.
The tone is very simple -- two sine waves combined in a balanced-modulator, filtered through my recently-completed Yusynth Fixed Filter Bank, and shaped with a bell-like envelope.
Also, as a result of Darrell Burgan's excellent workshop on impulse responses I was able to intelligently use the Impulse processor that is included in Cubase 5 (Reverence). Nothing fancy -- just adds a nice spaciousness to the track.
The track is a little on the long side (13:39) -- then again, this approach to building a piece of music takes time.
Hope you enjoy this!
Description: |
Mysterious Bells: an improvisation on the Aries Synthesizer. |
 Download (listen) |
Filename: |
MysteriousBells.mp3 |
Filesize: |
18.75 MB |
Downloaded: |
2297 Time(s) |
_________________ -- Kevin
http://kevinkissinger.com |
nobody
Posted: Tue Oct 05, 2010 5:15 pm Post subject:
Beautiful and wonderful.  |
stolenfat
Joined: Apr 17, 2008 Posts: 476 Location: Sunny Oakland California
Posted: Wed Oct 06, 2010 12:16 am Post subject:
woah, sounds like an Iannis Xenakis composition, i dug it! _________________ home made noise and electronic ill-logic |
Posted: Thu Oct 21, 2010 9:09 am Post subject:
Thank you, guys! Appreciate your words of encouragement. _________________ -- Kevin
