Nord Rack 2 Potentiometer Replacement
Page 1 of 1 [9 Posts]
Caveman672
PostPosted: Tue Nov 09, 2010 3:28 am    Post subject: Nord Rack 2 Potentiometer Replacement Reply with quote  Mark this post and the followings unread
Does anyone know where I can find a replacement potentiometer for a Nord Rack 2? I am very confident I can install it myself but for the life of me , I can't find the part.
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Tue Nov 09, 2010 9:09 am    Post subject: Reply with quote  Mark this post and the followings unread
welcome Caveman672
It's a [10kA Lin] 3mm shaft and you have to file the tip to get the knob on. This has to be done at the right place (or angle), otherwise the knob will indicate wrongly. Solder and remove the broken one and study how long the shaft has to be and file the flat side exactly as the old one.
Wout
Caveman672
PostPosted: Tue Nov 09, 2010 11:04 am    Post subject: Reply with quote  Mark this post and the followings unread
I opened the Nord to take a look and the potentiometer reads on the back: B10K 9939. No brand name .
Caveman672
PostPosted: Wed Nov 10, 2010 4:05 pm    Post subject: Reply with quote  Mark this post and the followings unread
Wout, it sounds like you have done this before. I think I found the 10k pot at Mouser. Will report when the part comes in an repair is done . Thanks for the help.
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Wed Nov 10, 2010 4:18 pm    Post subject: Reply with quote  Mark this post and the followings unread
Not exactly...
I was there when Jan (Blue Hell) and Rob (Hordijk) performed these tricks. We build some joy sticks into the Nord Modular, which is a relartive to the Lead...
Anyway, be carefull!
Wout
Caveman672
PostPosted: Fri Nov 12, 2010 1:09 pm    Post subject: Reply with quote  Mark this post and the followings unread
Seems like it is impossible to find the 10k linear 3mm potentiometer here in the US. Mouser does not have it , neither does Digikey. Two days worth of Google searches and no luck. Anyone know where I can find it? I wrote to Clavia's distributor here in the US and got no response.
3rse
PostPosted: Sat Apr 23, 2011 6:24 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi guys !
A month ago, I bought a nl2, and I'm horrified to understand that 13 of the potentiometers are dead, they continuously transmit
wrong midi data Sad
10k linear 3 mm is the correct potentiometer for NL2 too ?
& I read on gearslutz that the right size was 4mm for a nord rack : Shocked
http://www.gearslutz.com/board/electronic-music-instruments-electronic-music-production/548636-nord-rack-2-potentiometer-replacement.html
Otherwise, for 3mm, I found this:
http://uk.rs-online.com/web/6928651.html#header
What do you think for Nord Lead 2 model ?
Thx & sorry for english ^^
pablomastodon
PostPosted: Sat Apr 30, 2011 9:47 pm    Post subject: NORD POT REPLACEMENTS
Subject description: always available through distributor in your nation
Contact the Nord distributor in your country to obtain replacement pots.
In the USA, contact me:
nordtechsupport@americanmusicandsound.com
Bless,
Pablo Mastodon
pablomastodon
PostPosted: Sat Apr 30, 2011 9:50 pm    Post subject: Nord replacement pots Reply with quote  Mark this post and the followings unread
P.S. -- Although early Nords used a different squared-body pot, the current version will retrofit to ANY NORD -- that 10k pot is the only one they use in ALL MODELS.
Pablo
