Connectors: 1/4" vs 1/8" vs banana vs other
Page 1 of 1 [5 Posts]
sonic
PostPosted: Tue Dec 14, 2010 6:29 pm    Post subject: Connectors: 1/4" vs 1/8" vs banana vs other
Subject description: A discussion of the pros and cons of various connectors
I'm designing some DIY analogue synth modules. I'm sorely tempted to use 1/4" connectors. Is this foolish? I have just never been fond of 1/8". Any suggestions about the pros and cons? Are there any other alternatives I have missed? Apologies if this is old ground - maybe I just didn't find the right search terms.
mark_olson
PostPosted: Tue Dec 14, 2010 7:56 pm    Post subject: Reply with quote  Mark this post and the followings unread
It's true, the pros-and-cons of 1/4", 1/8", and banana connectors have been discussed endlessly here. I think it can be boiled down to panel space in the case of 1/4" or 1/8". Bananas are, to use a theological analogy, representative of a whole different belief system in which the absence of a ground and stackability are revered.
I use 1/4" but some of my best friends are 1/8" or even banana users Smile
Mark
PostPosted: Wed Dec 15, 2010 9:41 am    Post subject: Reply with quote  Mark this post and the followings unread
I use 1/8" simply because the Aries synthesizer utilizes 1/8" and I want my new modules to be compatable with the old.
Some people report reliability problems with the 1/8" components but I've never had such problems. I've had no problems even with the oldest and most heavily used jacks.
emdot_ambient
PostPosted: Wed Dec 15, 2010 10:19 am    Post subject: Reply with quote  Mark this post and the followings unread
I've had more reliability issues with both 1/8" (3.5mm) jacks and plugs/cords than with 1/4". Some older miniature jacks are also not really completely compatible with what's normally available today. The tip size and diameter may be different enough to cause improper connection...but that's really only a problem on some vintage gear. As long as you stick to modern (typically 3.5mm even if they're called 1/8") jacks you shouldn't have that problem.
1/4" jacks have been used since the 1800s, as they were first used in telephone switching applications. They're very vintage, and therefore better....right? Wink
cbm
PostPosted: Wed Dec 15, 2010 2:05 pm    Post subject: Reply with quote  Mark this post and the followings unread
There is so much confusion about "Mini" 1/8" and 3.5mm jacks. The older jacks mentioned above were probably Switchcraft's .141" Tini-Jax line. These were used by Arp, Buchla and most other 1970's era manufacturers who used smaller jacks. Buchla still uses them. The open-frame version of these jacks are quite robust. Arp used the enclosed version on many 2600s, but eventually went to the open frame Switchcraft 42a jack, which has really stood the test of time.
Currently the 3.5mm jack is used almost everywhere. They is just enough smaller to not make reliable contact when a 3.5mm plug is used in a .141" Tini-Jax. The .141" plugs are just enough bigger to make insertion in some 3.5mm jacks problematic, and they might stretch the jack's contact.
Some Eurorack manufacturers had problems with Cliff 3.5mm jacks, and Cliff ended up doing some sort of redesign, I think. I don't know about the general reliability of 3.5mm jacks.
The Switchcraft .141" jacks and plugs that Buchla uses are reliable, and very nice, although they are expensive and require hand wiring. My Eardrill modules for the Buchla system also use the .141" Tini-Jax.
Chris Muir
http://www.eardrill.com <– My jobby (more than a hobby, less than a job)
