Top Top
Posted: Tue May 11, 2010 12:50 am Post subject:
Sorry... bumping this thread from long ago...
Trying to build a LPF and LFO from one 4069. Got the LPF working, tried building the LFO above (fatman LFO) can't seem to get it to work - seems I've got it all set up correctly on the breadboard.
Mine is 4069UBP which I believe means something about unbuffered or something. Could that be the issue?
Also, I was testing it by putting an LED between the output from the pot and ground... not sure if my thinking is correct there... - my hope is to light an LED with it (to eventually control a home made vactrol to sweep the filter).
Any ideas?
EDIT: to clarify, I am getting no oscillation. I measure between 2-3 volts DC at the output - varying depending on the frequency pot's setting (set low = lower voltage). It will light a LED, but no oscillating fluctuation in brightness. |
Top Top
Posted: Wed May 12, 2010 1:07 am Post subject:
Searching around the internet I found a thread on another board that referred to this 4069 LFO and someone who was having trouble with it. The suggestion there was to try lowering the resistor from pin 1 to 6. I tried it and it works.
The value that worked best for me is about 80k Ohms. The higher I go, the deeper the sweep, but at a certain point, it latches and won't oscillate anymore. Also, there is a short range at the high end (last 5% or so) of the 100k output depth knob that also causes the LFO suddenly slow down and latch high. It is annoying, but I can live with it. Filter + LFO from one 4069, sweet. I've got them linked using a LED/LDR combo.
FWIW for anyone who searches in the future and wants to troubleshoot values, I am running at +12V and ended up with a 2.2uF cap rather than the 1.3uF. It can do a really nice slow sweep on up to near audio rate. |
Technoshaman
Posted: Fri Dec 17, 2010 7:15 am Post subject:
Dear friends,
I've recently built and tried the first circuit in this thread (the one with 3 741's). It worked nicely as a Proteus simulation and also with my +/-15V supply and Thomas Henry's VCO-1. I'm attaching the screenshots and the PCB as a PDF document.
http://www.technoshamanarchist.net/pictures/LFO_PCB.pdf
Hope someone finds it useful. _________________ Enslaving machines to free mankind... |
-minus-
Posted: Fri Dec 17, 2010 1:44 pm Post subject:
I'll have a look at building this next year I think....
I just wanted to say I really like that PCB diagram!!!! Thanks for posting this. It looks so nice! I really ought to do some etching next year. |
RF
Joined: Mar 23, 2007 Posts: 1502 Location: Northern Minnesota, USA
Audio files: 28
Posted: Fri Dec 17, 2010 4:30 pm Post subject:
2011 - In which Minus embraces the op-amp. _________________ www.sdiy.org/rfeng
(Herb Deutsch to Bob Moog ~1963) |
Joined: Apr 03, 2004 Posts: 24653 Location: The Netherlands, Enschede
Audio files: 326
Posted: Fri Dec 17, 2010 5:04 pm Post subject:
| RF wrote: | | 2011 - In which Minus embraces the op-amp. |
good things happen  _________________ Jan
-minus-
Posted: Fri Dec 17, 2010 5:16 pm Post subject:
Ha ha! I've been embracing the op amp here for a while now. I have several windows open as I type regarding op amps . The main stumbling point has been powering them. |
Audio files: 326
Posted: Fri Dec 17, 2010 5:48 pm Post subject:
| -minus- wrote: | | The main stumbling point has been powering them. |
It is handy to have dual + / - power supply with regulated voltage and settable current limiting (to prevent accidents). It's not directly musical, but well worth to buy or DIY it. _________________ Jan
Technoshaman
Posted: Sat Dec 18, 2010 3:48 am Post subject:
Thank you -minus- and everyone else Happy to see someone's gonna use it "one day" I'm about to head out to get a box for this and the Jürgen Haibles WASP VCF clone. If anyone wants to see (and / or criticize) how the VCO-1 sounds, I posted a video here with pictures. Under TH designs...
Happy soldering! _________________ Enslaving machines to free mankind... |
tubeampguy
Joined: Oct 29, 2009 Posts: 12 Location: Long Beach, Ca
Posted: Mon Jan 10, 2011 8:50 pm Post subject:
Mubo
Joined: Jul 21, 2008 Posts: 16 Location: ft.lauderdale
Posted: Tue Jan 11, 2011 10:42 pm Post subject:
output jacks Subject description: how to hook up? |
@ Technoshaman
where do the grounds for the output jacks get hooked up?
thanks!
-mubo |
Technoshaman
Posted: Tue Jan 11, 2011 11:33 pm Post subject:
@ mubo: Vss  _________________ Enslaving machines to free mankind... |
Mubo
Posted: Wed Jan 12, 2011 3:48 am Post subject:
ok, thats how i have it on my breadboard, but wanted to check since i didnt see extra ground connections on your pcb....
Thanks |
Technoshaman
Posted: Wed Jan 12, 2011 4:05 am Post subject:
Sorry, I thought it would be obvious in the schematic. And IMHO, This LFO is not the best. I'm not very happy with the sine output, and the speed won't go up as much (I think modifying C1 should help, haven't tried that yet, since, as a digital designer, I'm more into a MOS6581 based synth now) to create a Theremin like vibrato Good luck  _________________ Enslaving machines to free mankind... |
qzzk_
Posted: Thu Feb 24, 2011 2:58 pm Post subject:
hI guys
Technoshaman, i builded in a bradboard and its working but there is a dramatic diference in volume between the square wave (so far the most loud) and the triagle and sine waves.
Any idea why?
thanks |
Technoshaman
Posted: Thu Feb 24, 2011 3:04 pm Post subject:
| qzzk_ wrote: | hI guys
Any idea why?
thanks |
As far as I know, that's usually how it is due to the structure of the waves. _________________ Enslaving machines to free mankind... |
Ajax
Joined: Apr 05, 2010 Posts: 63 Location: San Francisco
Posted: Thu Feb 24, 2011 4:32 pm Post subject:
| Technoshaman wrote: | | qzzk_ wrote: | hI guys
Any idea why?
thanks |
As far as I know, that's usually how it is due to the structure of the waves. |
Yep, that's right. Square waves have way more harmonic content than sine or triangle waves. |
tubeampguy
Posted: Thu Feb 24, 2011 10:12 pm Post subject:
| tubeampguy wrote: | Has anyone here used a LM348 for a multi-LFO (squarwave only) circuit for Eurorack?
I'm wondering if the 12v rail in my Monorocket can handle the draw
Any suggestions is apprenticed! thanks! |
bump!  |
qzzk_
Posted: Fri Feb 25, 2011 4:21 pm Post subject:
Ok, thanks
But, there is not a way or technic to equilibrate the volumes of the waves?? any sugention? sorry if the question is so obvius or basic, but i am new building this kind of staff.
thanks guys |
qzzk_
Posted: Fri Feb 25, 2011 5:40 pm Post subject:
Another question, will be possible to add an CV to this simple LFO?? i am thinking in control it from another simple module.
thanks! |
Psyingo
Posted: Mon Feb 28, 2011 7:45 am Post subject:
| qzzk_ wrote: | Another question, will be possible to add an CV to this simple LFO?? i am thinking in control it from another simple module.
thanks! |
vactrols |
Rolbista
Posted: Wed Dec 05, 2012 2:57 pm Post subject:
| OK, I know it's a terrible sin to necropost, but I'm having some problems with the 4069 LFO. Works, I put both waveforms on a switch, but I get pretty loud ticking, as if it bled through to the signal. I put together a simple tremolo based on a single transistor boost circuit with a vactrol on the input. The LED is connected only to the output of the lfo, with separate ground , the boost is powered from a battery, the LFO from an adapter, but there still is audiblo LFO noise, especially when the fuzz before the tremolo is engaged, then, the noise becomes unbearable. I put a 100uF cap from a 6V voltage regulator to pin 8 of the 4069, in parallel with a 180ohm resistor as i read on the net, but that doesn't help the noise at all... Maybe it's because the fuzz before the tremolo is powered from the same adapter as the LFO? |
JingleJoe
Joined: Nov 10, 2011 Posts: 878 Location: Lancashire, England
Posted: Thu Dec 06, 2012 1:27 am Post subject:
| Rolbista wrote: | | OK, I know it's a terrible sin to necropost, |
where the hell did you get that idea?
I don't know why you have a resistor in series with the power supply filter cap, just put a nice big cap between +V and Ground. That will probably help. Also you may have mis-connected something like a missing ground connection. _________________ As a mad scientist I am ruled by the dictum of science: "I could be wrong about this but lets find out"
Green Dungeon Alchemist Laboratories |
Posted: Thu Dec 06, 2012 4:35 am Post subject:
I love necroposts!
They bring up really great ideas which I missed the first time round.  _________________ What makes a space ours, is what we put there, and what we do there. |
Rolbista
Posted: Thu Dec 06, 2012 2:10 pm Post subject:
| says here: https://sites.google.com/site/flofxdiy/deticking-lfo that I should put a cap to ground from the power supply and a 100ohm resistor from V+ to power pin on the chip to let the cap accumulate some "spare current". I also read that power ripples from sudden current demands of the LFO cause some RF noise, could they get through to the audio path from a power rail running beside it inside the enclosure? |
