Can't stop Megaphone/Lo-fi patch from feeding back
Page 1 of 1 [4 Posts]
SamAndrew
PostPosted: Thu Dec 23, 2010 1:35 pm    Post subject:  Can't stop Megaphone/Lo-fi patch from feeding back
Subject description: Need help with a lo-fi voice patch
Hello,
I am trying to make a lo-fi or "megaphone" sounding patch stop feeding back. I have added a little overdrive and filtered out the low and hi frequencies. The patch sounds good. Problem is, I cannot for the life of me use it at a show without feedback being a huge problem Sad Too much gain maybe?? I set the noise gate to almost as high as if will go (highest threshold, I mean) and that helps a *little* but the patch is still really unusable at my live show. I will upload the patch here once I get home. Thank you.
SamAndrew
PostPosted: Thu Dec 23, 2010 3:40 pm    Post subject: Re: Can't stop Megaphone/Lo-fi patch from feeding back
SamAndrew wrote:
Hello,
...Here is the patch (attached):
Telephone Voice w-Gate.pch
 Filename:  Telephone Voice w-Gate.pch
 Filesize:  1.01 KB
 Downloaded:  373 Time(s)
Moody33
G2 patch files: 16
PostPosted: Fri Dec 24, 2010 2:42 pm    Post subject: Reply with quote  Mark this post and the followings unread
Put the noise gate before the compressor like in the attached patch.
You can also try to find the frequency band which generate feedback. Here at home, with my hardware, this frequency is near 1,75 khz. It's probably different for you. Just try.
telephone_voice.pch
 Filename:  telephone_voice.pch
 Filesize:  1.07 KB
 Downloaded:  363 Time(s)
SamAndrew
PostPosted: Fri Dec 24, 2010 3:49 pm    Post subject: Reply with quote  Mark this post and the followings unread
Excellent, I will try that. Thank you!
