Inventor
Audio files: 267
Posted: Tue Jan 04, 2011 11:50 pm Post subject:
What guitar sound do you prefer? Subject description: from a signal analysis perspective |
I've just downloaded the demo version of Electroacoustic Toolbox, which is basically a spectrum analyzer, scope, and other stuff for your soundcard. I measured some signals from the OYT guitar invention in both factory and invention switch position, and was rather surprised at what I saw.
In particular there was no additional harmonic content with the invention. I also noted that a super-sharp initial transient occurs with the factory setup that is not there for the invention (attack i guess you'd call it), and a greater content at discordant frequencies, i.e. frequencies not at harmonic multiples.
Much to my surprise one guitarist on another forum said that he prefers the factory pickups because he likes the "richer harmonic content". Maybe guitarists like a little bit of dissonance, maybe a lot? This got me thinking about ways to make the invention more acceptable to the guitarist community. I could purposely create more discord if that's desired. I could add circuitry that increases the same stuff.
Backing up a bit, I guess I should just ask: what do you want in your guitar spectrum / waveform?
BobTheDog
Posted: Wed Jan 05, 2011 12:55 am Post subject:
Hi Les,
Can you post some images of the frequency graphs?
Andy |
Inventor
Audio files: 267
Posted: Wed Jan 05, 2011 2:46 am Post subject:
Sure Andy,
In this example I have placed the magnets near the bridge for the invention, and used the bridge pickup for the factory position. Pluck was done at middle pickup location of low E string, open (unfretted).
The spectrum in this case is very similar so it makes a good frame of reference for future comparison i suppose.
Les
| Spectrum of Invention Low E STring |
101.75 KB |
| Viewed: |
931 Time(s) |
| Spectrum of Factory pickups low E String |
104.88 KB |
| Viewed: |
958 Time(s) |
Inventor
Audio files: 267
BobTheDog
Posted: Wed Jan 05, 2011 4:11 am Post subject:
Hi Les,
I bet if you tried other different mag pickups you would notice similar differences.
Different pickups sound very different, even combinations of different string types with different pickups produce very different sound.
My bet is also the attack changes as well but I must admit I have never thought of this before but it makes sense.
Andy |
Inventor
Audio files: 267
Posted: Wed Jan 05, 2011 10:52 am Post subject:
As requested by woody monk, the next measurement is with the high E string. Magnets slightly adjusted also.
Les
| Spectrum with Factory pickups when high e string is plucked |
124.79 KB |
| Viewed: |
1076 Time(s) |
| Spectrum with invention, high e string plucked |
128.09 KB |
| Viewed: |
976 Time(s) |
GovernorSilver
Joined: Apr 26, 2004 Posts: 1349 Location: Washington DC Metro
Inventor
Audio files: 267
Posted: Mon Jan 17, 2011 11:36 am Post subject:
Well thanks for your comments, though I still do not have a feel for what subset of the market will be best for these pickups. I'm actually starting to think of piano and violin and lute or other instruments (maybe banjo) that people actually want to hear what the instrument itself sounds like.
What I've learned from playing with the measurement software is four things.
1. there is NOT more harmonic content with the new pickup. It is about the same.
2. there is much lower dissonance with the new pickup (see above 1khz on low E string plots above)
3. the attack is much lower with the new pickup
4. the bass is less enhanced with the new pickup (a known flaw of coil wound pickups).
I'm wondering what part of the market is best suited for this pickup given those four observations.
GovernorSilver
Posted: Mon Jan 24, 2011 3:10 pm Post subject:
| Inventor wrote: |
Les |
My guess is the metal guitar market. They are the ones who are enthusiastic unusual pickups such as Q-Tuners, Lace Alumitones, etc. _________________ Current and recent work on Soundcloud
Some old stuff on VIRB |
