Tron, Drum pattern Sequencer
Page 1 of 1 [4 Posts]
lordavon
PostPosted: Thu Jan 13, 2011 2:53 pm    Post subject: Tron, Drum pattern Sequencer Reply with quote  Mark this post and the followings unread
Just for those who don't know, I've made a small drum pattern programmer. It's called tron and measures 100mm by 80mm.
* 8 parts,
* 16 steps with two velocities (think TR909 style programming).
* You can chain two patterns and each pattern has a number of repeats, so you can have pattern 1 play 7 times, then pattern 2 play once, then it goes back to pattern 1.
* Midi note outs can be set by the user, the "low" velocity is adjustable, the step length (so you can go to 32 beats per bar if you really want).
* Last step is adjustable from 1 to 16, so you can have a 7 beat bar (again, if you really want).
* performance mode that let's you "mute" parts
Details here -
http://www.vacoloco.net/synths/tron/
Videos here -
http://www.vacoloco.net/synths/tron/gallery.shtml
Paul
rosch
PostPosted: Thu Jan 13, 2011 4:07 pm    Post subject: Reply with quote  Mark this post and the followings unread
cool projects on your page!
are you going to do a kit or pcb?
lordavon
PostPosted: Fri Jan 14, 2011 12:39 am    Post subject: Reply with quote  Mark this post and the followings unread
Sorry, I forgot to say Smile
Kits, are available, I have a complete kit of parts (PCB, Micro and all components) for 95.50GBP + postage.
I also have one remaining PCB+MICRO only kit for 21.50GBP + Postage.
details here - http://blog.vacoloco.com/?p=350
The Bad Producer
PostPosted: Fri Jan 14, 2011 7:15 am    Post subject: Reply with quote  Mark this post and the followings unread
That is indeed very cool! neat as you like!
