emergencyofstate
Joined: May 15, 2009 Posts: 2 Location: San Diego, California
Posted: Tue Nov 10, 2009 11:18 am Post subject:
Looking for a Klee Builder |
Hi all! I frequent the muff wiggler forum but I figured elctro-music would be a wise place to post this request.
I'm purchasing a klee kit from a fellow muff wiggler forum member (seen here > http://www.muffwiggler.com/forum/topic-9612.html)
I need someone to build for me. I can provide references if needed. Thanks!!
neandrewthal
Posted: Tue Nov 10, 2009 10:06 pm Post subject:
Have you seen droolmasters post on this topic over at muffs? I can't remember the name of the builder dude. _________________ " I went through quite a few trannies til I found one I liked" - Wild Zebra |
sduck
Posted: Wed Nov 11, 2009 8:58 pm Post subject:
| Don't worry, I sent him a name |
Posted: Mon Dec 14, 2009 10:07 am Post subject:
Any resolution here ? .... Perhaps I can help ??? PM with your needs. Maybe an arrangement can be worked out.
Bill
sMs Audio Electronics |
jachinboaz
Posted: Sun Jan 30, 2011 11:39 am Post subject:
Re: Looking for a Klee Builder |
can anyone post the links to the Klee thread on Muffwigglers ? and if anyone fancies posting info on possible builders please do - looking to have one built myself.Feel free to mail me direct also.
[/quote] |
Posted: Sun Jan 30, 2011 1:29 pm Post subject:
| Quote: | can anyone post the links to the Klee thread on Muffwigglers ? and if anyone fancies posting info on possible builders please do - looking to have one built myself.Feel free to mail me direct also.
I need someone to build for me. I can provide references if needed. Thanks!! |
I have built 3 of these for folks. The panel I utilize of the One from Bridechamber which is a MOTM form factor. The pictures are a sample of two I built for a client in the Midwest. PM your needs and maybe we can strike a deal. I have references for my work as well.
Bill
2.41 MB |
| Viewed: |
593 Time(s) |
1.64 MB |
| Viewed: |
607 Time(s) |
loydb
Joined: Feb 04, 2010 Posts: 393 Location: Providence, RI
KEYKEYEYEKIT
Posted: Wed Feb 09, 2011 7:17 pm Post subject:
| What is the third board in your build? |
Posted: Thu Feb 10, 2011 5:34 am Post subject:
| Quote: | | What is the third board in your build? |
The third board is a feature to add a synchronous manual load function. Normally when you press the MANUAL LOAD pushbutton, the pattern loads immediately, asynchronously to any incoming clock. This circuit adds the option to manually load a pattern synchronous with the CLOCK input.
Bill |
KEYKEYEYEKIT
Posted: Thu Feb 10, 2011 10:57 pm Post subject:
That sounds fun. Did you get the boards made? I can't seem to find anything on EM. Would this be something easily breadboarded? Like to give it a shot. Also, your wiring is amazing.  |
Posted: Fri Feb 11, 2011 6:23 pm Post subject:
| Quote: | | That sounds fun. Did you get the boards made? I can't seem to find anything on EM. Would this be something easily breadboarded? Like to give it a shot. Also, your wiring is amazing. |
Thanks !! I have attached a document that I wrote explaining the mod in detail. I have also attached the HEX file for the small PIC chip.
If you don;t have a means of programming the IC, I can send you one if you would like to try the mod for yourself.
Bill
 Download (listen) |
| Filename: |
sync_load_mod_description.pdf |
5.06 MB |
| Downloaded: |
699 Time(s) |
 Download (listen) |
| Filename: |
SyncLoad.HEX |
677 Bytes |
| Downloaded: |
509 Time(s) |
KEYKEYEYEKIT
Posted: Tue Feb 15, 2011 10:37 am Post subject:
Thanks Bill! I will add this to the pile of projects. |
sneakthief
Posted: Tue Feb 15, 2011 11:12 am Post subject:
Why not attach an optical or mechanical relay in series with the load button and trigger it by a pulse from clock-divided signal? That way it could load every 2nd, 3rd, 4th, etc. division of the clock? _________________ Sneak-Thief - raw electrofunk |
marmad
Posted: Tue Apr 12, 2011 6:20 am Post subject:
What is strange is that the topic - "Add a Synchronous Manual Load to the Klee" - has been deleted from the forum. In that thread, Bill explained how his synchronous load mod worked, and I posted another possible method of doing it using one chip of discrete logic (CD4053) - less complex (or programmable) than Bill's - but more modding intensive.
Since it's gone, I'll post it again now - including the altered schematic and photos of the added circuitry, the modded digital board, and the added toggle (and LEDs) on the front panel.
Mark
| Changed schematic for synchronous load. |
90.67 KB |
| Viewed: |
577 Time(s) |
| Daughterboard that plugs into U5 socket. |
3.57 MB |
| Viewed: |
513 Time(s) |
| Klee digital board w/daughterboard plugged-in. |
4.59 MB |
| Viewed: |
512 Time(s) |
| Extra toggle on front panel for Sync/Async loading with bi-color LED indicator. |
3.71 MB |
| Viewed: |
534 Time(s) |
DaLuke
Posted: Tue Nov 15, 2011 6:33 am Post subject:
Klee Sequencer Subject description: building the sequencer |
| State Machine wrote: | | Quote: | can anyone post the links to the Klee thread on Muffwigglers ? and if anyone fancies posting info on possible builders please do - looking to have one built myself.Feel free to mail me direct also.
Bill |
I would like to have one of these sequencers built by someone...I have the 2 boards but that is all, please let me know if you will...I will send the money for parts, etc. |
