WP-20 VCF Stripboard Layout (tested and working)
Page 1 of 1 [10 Posts]
Juno60
PostPosted: Tue Sep 21, 2010 3:20 am    Post subject: WP-20 VCF Stripboard Layout (tested and working) Reply with quote  Mark this post and the followings unread
Hello @ all!
I finally finished my stripboard layout for Rays simple WP-20 VCF. I built it last weekend and it's working fine. It can be powered by 9V to 12V. Maybe you have to experiment with the value of the resonance pot at 12V 'cause there is still some bleedthrough when the filter is fully closed.
It's not as powerful as a Moog-Ladder-Filter, but it's fun if you need a simple, dirty and quick-to-build low-pass-filter.
Chris
 Filesize:  68.91 KB
 Viewed:  595 Time(s)
 Filesize:  84.04 KB
 Viewed:  445 Time(s)
Greetings from Germany,
Chris
Silesius
PostPosted: Mon Oct 04, 2010 10:50 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for the layout Juno60!
And one question: does it work with a single power supply? Because I thought the WP-20 used a bipolar power supply.
Juno60
PostPosted: Mon Oct 04, 2010 11:10 pm    Post subject: Reply with quote  Mark this post and the followings unread
The WP-20 uses no bipolar power supply. It's powered by +9V, +18V and 0V. The junction of the two 9V-batteries is just to generate the +18V for the noise-generator. All other modules (VCO, VCF, EG & LFO) are running on +9V & 0V.
Therefore any unipolar power supply from 9V to 12V should work fine with the VCF. I run mine only using the +12V & 0V rails of my power-bus. While testing it I only used a 9V battery and it worked fine. Smile
Chris
Pehr
PostPosted: Tue Oct 05, 2010 5:31 am    Post subject: Reply with quote  Mark this post and the followings unread
Are there any good replacements for the 3900?
YouTube channel
flickr photostream
http://loxodrom.blogspot.com
BobTheDog
Audio files: 32
PostPosted: Tue Oct 05, 2010 7:59 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi Pehr,
TI still do a 3900
http://uk.farnell.com/jsp/search/browse.jsp;jsessionid=IXLMCKGJVQUAECQLCIPZK0Q?N=0&Ntk=gensearch_001&Ntt=lm3900&Ntx=mode+matchallpartial&suggestions=false&ref=globalsearch&_requestid=302906
Andy
Captain Biscuits
PostPosted: Tue Oct 05, 2010 9:44 am    Post subject: Reply with quote  Mark this post and the followings unread
Also a few people selling 3900s on ebay in the UK anywhere from £1.20 to £4.00
Ian
Alienforce
PostPosted: Fri Feb 11, 2011 7:38 am    Post subject: Reply with quote  Mark this post and the followings unread
I built it... but i cant get filter to work..
I am using a 9V battery..
Is it only to connect + and - ?
I dont understand the _|_ in the middle of the + and - .. is that the gnd ?
or shall hook the - on the battery to _|_
Embarassed
Juno60
PostPosted: Fri Feb 11, 2011 1:00 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi Alienforce,
you need to connect the positive rail (red) of the 9V battery to the "+" on the schematics. The negative rail of the battery is the ground which has to be connected to the ground sign ( _|_ ) on the scheme. The also shown negative connection (-) is not used.
Chris
Chris
Alienforce
PostPosted: Sun Feb 13, 2011 6:23 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks Chris!
Going to do some testing later today.
Snaper
PostPosted: Fri Aug 01, 2014 12:48 am    Post subject: Reply with quote  Mark this post and the followings unread
How to add the resosnance pot?
200 k pot maybe, lug 1 to gnd, lug 2 & 3 replace the on-off reso switch?
