TekniK
Posted: Thu Feb 24, 2011 1:13 pm Post subject:
Damn,thats awesome,congratulations !
It realy asks to be touched,nice design |
loydb
Joined: Feb 04, 2010 Posts: 393 Location: Providence, RI
Posted: Thu Feb 24, 2011 6:09 pm Post subject:
| jordroid wrote: | Here are some other recent things. There is an MFOS 16 step sequencer, sound lab mini-synth + and an MFOS phaser on one big panel.
I love it.
| jordroid wrote: |
-a module for bringing guitars or other instruments up to synth level, providing boosted clean signal out, squared out and octave down squared out along with gate and trigger signals, based on the MFOS sub commander mostly
Do you have a pcb and/or scheme for this that you'd share? Thanks! _________________ MFOS Ultimate Expand-o-tron Build Log: http://www.electro-music.com/forum/post-308797.html#308797
MFOS Mini-Controller Build Log [FINISHED!]: http://www.electro-music.com/forum/topic-42968.html |
jordroid
Joined: Jan 17, 2010 Posts: 193 Location: ithaca, new york
Posted: Sat Feb 26, 2011 3:06 pm Post subject:
[quote="loydb"
Do you have a pcb and/or scheme for this that you'd share? Thanks![/quote]
Well, i did it in my usual disorganized way by breadboarding Ray's circuit and then tweaking it till i liked it, and then transfering the breadboarded circuit straight to perfboard without taking proper notes. When i say based on Ray's design i mean it's mostly his exactly, with just a few changes.
If i remember correctly i added a gain potentiometer to the front and a comparator wired to light up an led when the input signal was right around +/- 5 volts so i would have a visual indication of when the signal was at the desired level.
I also messed with the values around the gate circuit to get it to trigger reliably with my guitar, i never became super happy with it, mostly because i have a hard time playing consistently enough, not because of circuit deficiencies.
As is the levels of the pulse and sub pulse were a bit lower than +/- 5 volts, i don't remember if i did anything about that or not, i know i thought about it. Changing R48 and R49 (from the sub commander schematic) should alter the level of the pulse and sub pulse if desired. As a stand alone guitar effect it's probably not necessary but i wanted it to interface nicely with modular gear.
I used the opamp calculators and comparator calculator on Ray's site a bunch, and then just breadboarded to taste. I will add that i am fairly new to this and don't know if what i've done is anywhere near "best practice", or closer to "design nightmare", but if you want anything more specific i could pretty easily pull that module out and try to figure out exactly what i did.  |
droffset
Joined: Feb 02, 2009 Posts: 515 Location: London area
TekniK
Posted: Sun Feb 27, 2011 3:06 am Post subject:
| droffset wrote: | Here's something I made for that 555 design contest. It was really fun to make and I learned a lot on the fly while doing it.
haha,awesome thing |
iorobyy
loydb
TekniK
Posted: Sun Feb 27, 2011 12:23 pm Post subject:
| wow very nice those arp panels |
dougseidel
TekniK
Posted: Mon Feb 28, 2011 10:49 am Post subject:
i like the dual lfo look  |
jordroid
Posted: Mon Feb 28, 2011 2:47 pm Post subject:
Here is a "just for fun" project. My brother gave me a literal bucket full of tiny momentary switches someone was tossing out, and i wanted to do something with them. It's a 3 octave single buss keyboard using Ray Wilson's design. The lowest octave is the bottom row, highest on top, with the two middle "C" notes appearing twice. Inside the box is just the switch/100r resistor part, it connects to the "brain" part with a TRS 1/4" cable. Ultimately i want to use it in a pre patched synth with an Acoupel CV recorder/sequencer as a remote control for programming sequences, and for directly playing in a twitchy/video game button mashing kind of way. I was a little bit worried that it would have issues with glitchy triggering, but it works great!
1004.57 KB |
| Viewed: |
290 Time(s) |
1.5 MB |
| Viewed: |
307 Time(s) |
adambee7
Joined: Apr 04, 2009 Posts: 420 Location: united kingdom
Posted: Mon Feb 28, 2011 2:53 pm Post subject:
that would be great to add to a sequencer aswell.  |
Boogdish
Joined: Sep 21, 2009 Posts: 122 Location: Bloomington, IN
Posted: Wed Mar 02, 2011 7:49 am Post subject:
My arpeggiator prototype. Controls are (left to right, from top left):
-Reset (goes to root note and restarts clock)
-Movement (Up/down, up repeating, down repeating, pendulum, up non-repeating, down non-repeating, random)
-Chord to arpeggiate(Major, Minor, Major 7, Minor 7, Maj 7 w/o 5th, Min 7 w/o 5, 1 + 5, Octaves)
-Range (Selects between 1 and 5 octaves)
-Tempo
-PWM for the gate out
-Tempo modulator attenuator
-PWM modulator attenuator
-Tempo mod in
-PWM mod in
-Gate out
-Trigger out
-CV in
-CV out
1.04 MB |
| Viewed: |
260 Time(s) |
dougseidel
Posted: Wed Mar 02, 2011 8:09 am Post subject:
| Boogdish: I like the labels on this- do you etch right into those panels? |
emdot_ambient
Joined: Nov 22, 2009 Posts: 667 Location: Frederick, MD
Posted: Wed Mar 02, 2011 8:11 am Post subject:
| Boogdish wrote: | My arpeggiator prototype. Controls are (left to right, from top left):
-Tempo
-Tempo mod in
-PWM mod in
-Gate out
-Trigger out
-CV in
-CV out |
COOL! I'm looking forward to this one! _________________ Looking for a certain ratio since 1978 |
kupfer_m
Posted: Sun Mar 06, 2011 12:12 pm Post subject:
The first of many....
Yusynth VCO
Boogdish
mark_olson
Joined: Oct 26, 2006 Posts: 177 Location: Lawrence, Kansas
Posted: Mon Mar 07, 2011 8:49 am Post subject:
Boogdish:
Your front panels are absolutely fantastic. How are you doing the lettering?
Really really nice!
I don't have the means or even the desire to make panels that are really "pretty", mine have a decidedly DIY look, but I wish I could make ones that really have balls like yours do.
Mark Last edited by mark_olson on Mon Mar 07, 2011 1:23 pm; edited 1 time in total |
TekniK
Posted: Mon Mar 07, 2011 12:58 pm Post subject:
| kupfer_m wrote: | The first of many....
Yusynth VCO
neat,nice! |
Photon
Posted: Mon Mar 07, 2011 1:09 pm Post subject:
| an electric engraver maybe? anyway it looks cool. |
Boogdish
Posted: Mon Mar 07, 2011 3:13 pm Post subject:
Oh, I meant to respond to Doug's comment in that last post but forgot. Thanks for the kind words, gents.
I engrave with a dremel, then spray paint black and sand off the excess spray paint, which also shines up the rest of the surface a bit. I'm still working on my engraving technique, I wish I had more control than I do now.
Also, I made a little video showing the ENV-SEQ. I apologize in advance for my crap camera work.
http://www.youtube.com/watch?v=mKvlIneAobA |
mark_olson
Posted: Mon Mar 07, 2011 3:44 pm Post subject:
| Boogdish wrote: | | ...wish I had more control... |
Yeah, I hear that but I think it's the lack of control that makes them look so cool, and that will be hard to fake if you acquire more "skill". |
jordroid
Posted: Mon Mar 07, 2011 6:06 pm Post subject:
| Boogdish, super cool envelope rig, i was thinking it was a 4017 sequencer (10 steps and all) except the forward/backward capability makes me think it's not, is it done with a pic, or...? Cool idea! |
Boogdish
Posted: Tue Mar 08, 2011 2:16 pm Post subject:
It's two chips, a 16F913 PIC and a quad op amp being used as an output buffer and voltage summer/limiter of the time CV. I'm sure it could be done using standard CMOS chips, but for me, it's easier to figure it out with a PIC.
I'm thinking about starting over with it and have the PIC read the values of the pots then output with the PWM or a standalone DAC. That way the PIC could do the filtering of between step voltages and have smoother transitions. I think I'd also have try having separate time controls for A/S/R. |
emdot_ambient
