Diode Ladder VCF turned into a VCA
Page 1 of 1 [2 Posts]
Pantheon
PostPosted: Mon Mar 07, 2011 12:42 pm    Post subject: Diode Ladder VCF turned into a VCA Reply with quote  Mark this post and the followings unread
Last night I sketched up the Minisonic VCF in LTSpice as a learning excersise.
But after playing around for a while I decided to modify it to function as a VCA instead. The mods were quite simple realy, and it works well in LTSpice.
I have attached the schematic i came up with below, and some sound samples of it. To my ears it sounds like it has some of the character of the diode VCF.
So after thinking a little about this, my VCA seems very simmilar now to some of Rene-Schmitz vcas:
http://www.uni-bonn.de/~uzs159/vca3.png
This was unintentional, but now im curious if there is any benefit/real difference between the two designs. I was wondering if some smart person had any insight into the differences/drawbacks.
[edit]
Oops, could a mod perhaps move this topic out of 'Developers Corner' and into 'Diy Hardware and Software' please. Is that a better place to put this. Ta.
[/edit]
 Filesize:  14.68 KB
 Viewed:  502 Time(s)
 Filesize:  18.9 KB
 Viewed:  379 Time(s)
100hz_test.zip
 Filename:  100hz_test.zip
 Filesize:  1005.24 KB
 Downloaded:  371 Time(s)
the8bitpimp.wordpress.com
Pantheon
PostPosted: Mon Mar 07, 2011 3:01 pm    Post subject: Reply with quote  Mark this post and the followings unread
I will breadboard this up fairly soon I think.
Here is my plan for how to implement it fully as an AC coupled vca, I hope its clear enough.
 Filesize:  75.38 KB
 Viewed:  429 Time(s)
