Buchla Style Euro Case DIY
Page 1 of 1 [23 Posts]
mighty mouse
PostPosted: Thu Mar 10, 2011 7:24 am    Post subject: Buchla Style Euro Case DIY Reply with quote  Mark this post and the followings unread
Hello there,
this is my first post in here so hello at all hello welcome
I am inspired by somebody who already built and Buchla-Style-Folding-Case in Eurorack format my mission is now to build a case like this on my own.
See how it looks like and works:
http://www.spacecase.ltd.uk/products/space-case-baby/
For a lager picture: http://www.muffwiggler.com/forum/userpix/845_img_0581_1.jpg
I found threads in this forum about people building and construct cases like this but only in frac or 4U format.
But I wanna go Euro!
So now I wanna collect information, links, construction plans, dimensions,ideas...etc everything you need to build this awesome case.
Maybe anyone has already built such a case?
My first idea is to take some cardboard and cut out the dimensions of a side profile build of the case. You can then use these brass paper fasteners for the pivot points:
Once I figure out what's going to work for a size.. I can then apply the side profile dimensions to my real plans and I'll at least know how much spacing I'll have when the case is closed.
I need your guys help, experience and skills.
Let's put together a thread for building a folding-buchla cabinet for euro rack such as doepfer, cwejman, tip top, livewire..etc
Looking forward to chellenge this
best regards and thank you
F.
mighty mouse
PostPosted: Thu Mar 10, 2011 7:26 am    Post subject: Reply with quote  Mark this post and the followings unread
Added some pictures:
http://postmodular.co.uk/space-case-ltd/space-case-baby
macumbista
PostPosted: Thu Mar 10, 2011 1:08 pm    Post subject: Reply with quote  Mark this post and the followings unread
Some other inspirational images of new 2011 Tip Top Audio Modular Case. Actually, I don't really like the way they finished this case. Branding and decorations make it look like a cheap pinball machine!!!
macumbista.net
mighty mouse
PostPosted: Thu Mar 10, 2011 2:41 pm    Post subject: Reply with quote  Mark this post and the followings unread
Anyone who can figure out measures for the boats?
Could figured it out somehow.. goin nuts! Twisted Evil
PostPosted: Fri Mar 11, 2011 9:21 am    Post subject: Reply with quote  Mark this post and the followings unread
Well done. Smile
I designed exactly the same Eurorack Buchla case in Solidworks only a couple of years back, then decided I was really trying to clone the genius of Don Buchla, and that didn't seem right (as you know, it's a brilliant design- just like everything else Don does). So I never published it. (despite having almost death threats from some dude in America Shocked )
ACHTUNG!
PostPosted: Fri Mar 11, 2011 9:42 am    Post subject: Reply with quote  Mark this post and the followings unread
Laughing Laughing Laughing
Good luck with that! You'll need it!! Laughing Wink
ACHTUNG!
mighty mouse
PostPosted: Fri Mar 11, 2011 10:15 am    Post subject: Reply with quote  Mark this post and the followings unread
Why ? Wink
PostPosted: Fri Mar 11, 2011 10:23 am    Post subject: Reply with quote  Mark this post and the followings unread
Why? Because the original design was really designed for the small flat module that Buchla intended, NOT a Frac- which is far too deep. As you can see by the tiptop case, the compromise is that it doesn't look very sleek (although they've done a very good job- and you (or at least I can), can see why tiptop charges $1100 for the case. The Buchla one isn't cheap either- and for very good reason!
Just by changing one tiny litle thing, and you must start all over again. It's what they call in the trade, a "headfuck"! Laughing
ACHTUNG!
mighty mouse
PostPosted: Fri Mar 11, 2011 10:29 am    Post subject: Reply with quote  Mark this post and the followings unread
That's not my problem! Modules I use and gonna use (Doepfer, Make Noise, Livewire, Cwejman..etc) all have their PCB's parallel to the front panel.
So that's not the issue dude
PostPosted: Fri Mar 11, 2011 1:38 pm    Post subject: Reply with quote  Mark this post and the followings unread
The issue I take it then is that you've spent far too much money on the modules, and now intend to save money on a DIY case? It's a classic mistake to make. By the time you've finished designing, sourcing materials as well as building, not to mention all the drilling and CNC'ing, you may as well have just bought a case from one of the above mentioned people. And the quicker you have a case, the quicker it's going to be that you'll actually going to get on and make some noise!
(honestly! Very Happy )
PS welcome to electro-music.com Frederic! Very Happy
ACHTUNG!
mighty mouse
PostPosted: Fri Mar 11, 2011 2:11 pm    Post subject: Reply with quote  Mark this post and the followings unread
You are completely wrong. I don't wanna do this DIY Case to save money.
I want it because it is my ideal case and there is something inside my that says I got to do this.
Anyway, nobody belives in me, you try to prevent me from this..
I am going my way now..
Cheers and goodbye
PostPosted: Fri Mar 11, 2011 2:38 pm    Post subject: Reply with quote  Mark this post and the followings unread
I just found the Solidworks model I made.
If enough people really want the plans to build one, I could do a 'group buy' for the plans? It would bring the price down a bit? Very Happy
 Filesize:  126.87 KB
 Viewed:  417 Time(s)
ACHTUNG!
mighty mouse
PostPosted: Sat Mar 12, 2011 5:41 am    Post subject: Reply with quote  Mark this post and the followings unread
Common guys Wink Very Happy GROUPBUY
and do you think in the end it is cheaper for me to buy a case like this from here : http://postmodular.co.uk/space-case-ltd/space-case-baby than build it myself?
mighty mouse
PostPosted: Sun Mar 13, 2011 1:46 pm    Post subject: Reply with quote  Mark this post and the followings unread
To everyone who is interested:
20€ for a copy of v-un-v's plans..!
PM me if interested
droffset
PostPosted: Sun Mar 13, 2011 2:15 pm    Post subject: Reply with quote  Mark this post and the followings unread
This is also an interesting option for getting the parts cut to order. Cool idea.
http://www.ponoko.com/
Edit: Spelling mistakes.
mighty mouse
PostPosted: Mon Mar 14, 2011 6:09 am    Post subject: Reply with quote  Mark this post and the followings unread
indeed a great idea.. thanks for the link.. will check that Cool
PostPosted: Mon Mar 14, 2011 10:15 am    Post subject: Reply with quote  Mark this post and the followings unread
That is a good idea! Smile
But be careful with 3D printing- especially that size, otherwise it will cost you an arm and a leg! Shocked
I designed this ergonomic table for a Google competition (which I also won a prize for too), using a 4'x8' piece of ply. It was meant to be lasercut and as cheap as chips to make.
ACHTUNG!
mighty mouse
PostPosted: Mon Mar 14, 2011 10:20 am    Post subject: Reply with quote  Mark this post and the followings unread
I would like to see that of your buchla case Very Happy
PostPosted: Mon Mar 14, 2011 10:28 am    Post subject: Reply with quote  Mark this post and the followings unread
PM me if interested
I think it's best if I go away and think about this properly, and do a proper job. I'll sell the plans like Thomas Henry does. I think that'll be the best way to go.
It's a really complex design, despite it looking fairly simple. It just goes to show what a genius Buchla is. I don't want to copy Don, because that's not on, but I'll do a frac-rack version. It won't be as pretty though, as the design makes it look more like a sewing machine! Laughing
but it will also take a little time (yes sorry- the usual drill) as I'm very busy working on a school project (I gotta take action, to help change the future you know! Wink Very Happy )
ACHTUNG!
droffset
PostPosted: Mon Mar 14, 2011 2:04 pm    Post subject: Reply with quote  Mark this post and the followings unread
You should have Ponoko laser but the pieces for that desk, it looks great. Smile
I'll play around with some ideas for portable cases too.
mighty mouse
PostPosted: Mon Mar 14, 2011 2:40 pm    Post subject: Reply with quote  Mark this post and the followings unread
Lets do this together in here Wink
droffset
PostPosted: Mon Mar 14, 2011 3:01 pm    Post subject: Reply with quote  Mark this post and the followings unread
http://www.electro-music.com/forum/topic-25735-25.html
http://www.synthi.se/bcab/
http://electro-music.com/forum/topic-25787.html
PostPosted: Mon Mar 14, 2011 3:37 pm    Post subject: Reply with quote  Mark this post and the followings unread
You found my original drawings. Well done!
It's so funny looking at them now. You can tell I was in the last year of my degree!! Laughing
I almost terminated my life getting that 2.1 Shocked I'd never been so run down in my life. Shocked
Come to think of it, I owe ericcolleridge one. Embarassed
ACHTUNG!
