Lead won't store...and is it upgraded?
Page 1 of 1 [2 Posts]
757driver
PostPosted: Fri Mar 11, 2011 7:09 pm    Post subject: Lead won't store...and is it upgraded? Reply with quote  Mark this post and the followings unread
I bought a Nord Lead on ebay. I'm tweaking my own sounds, but whenever I try to store a program (1-40) my editions don't store. For example, I'll take prog 8, make some changes, and hit store. The 8 starts flashing. I hit store again, and it stops flashing. Good, right? Nope. As soon as I turn it off and back on, it reverts to the original program 8.
Also, when I turn on my Lead, I see a "2.7" in the program window. Any idea what this means. I'm wonding if the guy I bought it from upgraded to a pcmcia card. I've got 2"x3" memorix card that reads:
Static RAM
Memory Card 256KB
on the back it reads:
PC-CARD
Warranty void if removed.
Hmmmm...
And finally, does my first problem have anything to do with the second piece of info?? Thanks guys!
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Sat Mar 12, 2011 5:09 am    Post subject: Reply with quote  Mark this post and the followings unread
welcome 757driver
2.7 is the latest update to the NordLead(1).
When the PCMCIA card isn't right to the OS it want to be format. You will lose all saved Programs...
About the saving matter...
You are sure you aren't saving to the PCMCIA card, which is write protected, by any chance?
Wout
