DIY Polysynth
Page 2 of 2 [49 Posts]
Goto page: Previous 1, 2
adamstan
PostPosted: Sun Mar 27, 2011 9:42 pm    Post subject: Reply with quote  Mark this post and the followings unread
Year ago (march 2010) I've made new board.
Improvements:
+ LFOs, noise source and their VCAs are now built-in.
+ added third AVR for generating all 15 envelopes Mr. Green
+ some improvements in code - now it is much more stable
Unfortunately, I've made some mistakes during layout, so the board has many wire-jumpers and additional components Sad
Envelope generators maintain full resolution regardless of envelope amount. It is done by wiring one of the S/H outputs as switchable reference voltage for DAC.
23.03.2011 update:
I've added small board with third MAX525 DAC. So now I have 12 12-bit DAC channels, which enables me to individually tune each oscillator. I've added a "semi-autotune" routine - it performs almost like Wink autotune in Prophet-5, the only difference is that CPU doesn't measure frequency - you have to manually tune each oscillator on each octave using knobs on front panel. Then it computes values inbetween (using linear approximation) and stores that tuning table in memory.
If I can find a way of freeing (or switching) one CPU pin - which unfortunately would mean trace-cutting - I'll try to implement full autotune.
reve
PostPosted: Sun Mar 27, 2011 10:29 pm    Post subject: Reply with quote  Mark this post and the followings unread
Adamstan, I am currently gathering materials to follow you into polysynth-land. I was also thinking about using Wiltshire chips for EGs... but at the same time, I was looking at AVR datasheets knowing I could do what I wanted to do far more effectively with just a couple AVRs.
Would you have any interest in sharing your code here?
Cheers!
- r. mosquito
SynthDIY Synthpop -> http://www.reverbnation.com/photovoltaik
adamstan
PostPosted: Sun Mar 27, 2011 11:14 pm    Post subject: Reply with quote  Mark this post and the followings unread
OK. Currently I'm at work, but when I get back home, I'll post schematics for ADSR part, and code. It's written in Bascom.
It works similarly as Wiltshire's EG. The tricky part is passing parameters - I've used AVR's built-in buffered serial interface for it.
However, if you have space and funds, I'd suggest to use one chip for each envelope group, as generating 15 envelopes is really CPU intensive, and it makes passing parameters difficult, as there is little time left for it, and 15 parameters to pass (A,D,S,R and Level x3).
At 8MHz internal clock, I have envelope sample rate of about 3.5ms
reve
PostPosted: Mon Mar 28, 2011 8:02 am    Post subject: Reply with quote  Mark this post and the followings unread
Awesome!!! I'm super-excited!
This is exactly what I'd envisioned -- I was planning on groups of 8.
- r. mosquito
adamstan
PostPosted: Mon Mar 28, 2011 8:59 pm    Post subject: Reply with quote  Mark this post and the followings unread
If that's the case, just give me a little more time, and I will redraw this circuit and change the code for such task. Are you going for 8 voices? In that case - when single chip is used as one polyphonic EG - it's possible to have voltage control, which makes interfacing this circuit with the rest of the synth much easier.
reve
PostPosted: Tue Mar 29, 2011 12:14 am    Post subject: Reply with quote  Mark this post and the followings unread
Exactly right, eight voices. I was assuming I'd use voltage control.... let the chip read 0-5v off a pot and use that same reading for all the EGs. So like, eight envelopes but only one attack knob. Would it make more sense to use interrupts or just continuously poll the inputs?
- r. mosquito
adamstan
PostPosted: Tue Mar 29, 2011 1:22 am    Post subject: Reply with quote  Mark this post and the followings unread
I poll the inputs continuously and set envelope stages accordingly in main loop, and use timer interrupt to generate envelope values and put them out - just like Wiltshire. The difference is, that I've used external 8-bit dac instead of PWM.
adamstan
PostPosted: Wed Mar 30, 2011 12:21 am    Post subject: Reply with quote  Mark this post and the followings unread
Shit, these spambots get smarter and smarter....
Audio files: 316
PostPosted: Wed Mar 30, 2011 7:19 am    Post subject: Reply with quote  Mark this post and the followings unread
Anything I failed to see?
egasimus
PostPosted: Thu Mar 31, 2011 10:56 pm    Post subject: Reply with quote  Mark this post and the followings unread
God, that's brilliant. And it's a heck of a gesture just sharing all the schematics with the community like that. A million thanks!
Before I delve into the schematics, however, a superficial question: how is patch storage/retrieval achieved? I mean the part where the microcontroller interfaces with the analog circuits. Does it involve digital potentiometer ICs at some point, or is it somehow entirely achieved with control voltages?
adamstan
PostPosted: Fri Apr 01, 2011 1:16 am    Post subject: Reply with quote  Mark this post and the followings unread
It's done just like everyone was doing it in 80's. Voltages from pots are read by ADC (built in CPU), and control voltages are put out by DAC.
Regarding the schematics, there are unfortunately some errors in the drawings. If somebody made that synth according EXACTLY to these drawings, it won't work Sad
Also, the patch memory circuitry has major design flaw - the 74LS154 which works as address decoder isn't strobed during transitions, which makes big noise in the ground - even power decoupling doesn't help. I can't fix it 'cause I've ran out of CPU pins Wink
I can post updated version, but I need some time to redraw and sort them - and I don't seem to have too much of it.
egasimus
PostPosted: Fri Apr 01, 2011 1:29 am    Post subject: Reply with quote  Mark this post and the followings unread
Yeah, I know but how is voltage control achieved for things outside the VCO/VCF frequencies and the like? For example, how do you control a VCF's resonance, or an envelope generator's settings using a voltage? Maybe with OTAs or JFETs?
adamstan
PostPosted: Fri Apr 01, 2011 1:51 am    Post subject: Reply with quote  Mark this post and the followings unread
I use Moog filter, so I adjust resonance by putting VCA (OTA-based, indeed) in filters feedback loop (instead of pot). Envelope generator is digital, and may be controlled with CV. But in current version, when all 15 (5x3) envelopes are generated by single ATMEGA32 chip, it is controlled digitally, using serial interface.
I'll try to post more about these envelopes, as I promised few posts above.
reve
PostPosted: Mon Apr 04, 2011 5:33 pm    Post subject: Reply with quote  Mark this post and the followings unread
[quote="adamstan"
I'll try to post more about these envelopes, as I promised few posts above.[/quote]
Yeah even just the code would be awesome. Smile
- r. mosquito
adamstan
PostPosted: Sun Apr 10, 2011 8:05 am    Post subject: Reply with quote  Mark this post and the followings unread
Here is scematic diagram for AVR-based voltage controlled ADSR envelope generator. I don't have the firmware for this version (single 8-channel EG) ready yet, but will upload it as soon as it's done.
WARNING: pin numbers are for SMD (TQFP44) version of ATMEGA32. For another package - consult your datasheet before soldering!
 Filesize:  175.97 KB
 Viewed:  613 Time(s)
reve
PostPosted: Wed Apr 13, 2011 12:21 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hey adamstan, thanks for posting this!
The S+H is just a regular opamp, or some special s+h IC?
And maybe I should just wait for the code, but... what does the V9 switchable reference do?
- r. mosquito
adamstan
PostPosted: Wed Apr 13, 2011 1:02 pm    Post subject: Reply with quote  Mark this post and the followings unread
1. Yes, S&H uses regular op-amp
2. V9 allows to adjust envelope level while maintaining full 8-bit resolution. It works like this:
1. 5V reference voltage is connected to DAC via U39A
2. Write "level" voltage to V9
3. Disconnect 5V reference
4. Connect V9 as reference
5. Update envelope outputs
6. Repeat Smile
I just realised that with single envelope group, like in the schematics above, it is not needed at all - you can just wire Level CV directly as DAC reference voltage. Remove U39A, U39B and U37B and connect your envelope LevelCV to the R31. I had to use this arrangement with switchable reference because in my case single circuit is responsible for three envelope groups (5 voices each), each group with its own level setting, and EG parameters are controlled digitally.
reve
PostPosted: Thu Apr 14, 2011 9:04 am    Post subject: Reply with quote  Mark this post and the followings unread
Oh this is clever. That's going to save me a stack of VCAs!
- r. mosquito
Obsoletetechnology
PostPosted: Fri Apr 29, 2011 6:38 am    Post subject: Reply with quote  Mark this post and the followings unread
hi,
adamstan, this is a fantastic job you did here!
I'm in the middle of developing my own Synth CPU board for polyphonic synthesizers, very similar to what you've done but based on a single PIC uC and a flexible firmware.
I was also going to develop my own voice boards, but before I do so I would like to ask what lessons you've learned from designing your own boards, which changes you would implement and what other considerations you might have. I am also wondering what CV voltage levels you are using on your boards, is everything +-10V control voltages ?
thanks,
Obsoletetechnology
adamstan
PostPosted: Thu May 05, 2011 1:14 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi
I've learned that indeed making interconnections in polysynth is nightmare. If I had more money to spend on PCBs when I was designing this, I'd probably do as somebody said in your topic about voicecards - include local CPU and DAC on each voice and some kind of serial interface - instead of multiwire ribbon cables. It may be more expensive, but is also more reliable and makes it possible to do multitimbrality.
My CV levels are in 0-5V range, so I can switch them directly with TTL signals.
robinkle
PostPosted: Sun Jul 10, 2011 8:06 am    Post subject: Reply with quote  Mark this post and the followings unread
how did you implement MOD Wheels? Are they transmitting midi?
adamstan
PostPosted: Tue Jul 12, 2011 9:39 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yes. They are implemented just like every other knob - they're read by ADC built into AVR.
YashN
PostPosted: Mon Aug 01, 2011 9:39 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thoroughly impressive.
I wish I can do that someday too.
patchdub
PostPosted: Mon Aug 01, 2011 10:06 pm    Post subject: Reply with quote  Mark this post and the followings unread
Shocked
very very inspiring!!
www.patchdub.com
