Substitute SSM2220 on VC-Quad-LFO
Page 1 of 1 [2 Posts]
kindredlost
PostPosted: Tue Apr 12, 2011 10:35 am    Post subject: Substitute SSM2220 on VC-Quad-LFO Reply with quote  Mark this post and the followings unread
Here is a pdf layout of a modified PCB for the VC-Quad-LFO.
This mod uses the SSM2220 matched PNP chip (minus pins 4 & 5) in a 6 pin socket on the PCB. The pads are mirrored now instead of flipped as is the case on discreet transistors.
This is (maybe) a substitute for the matched pairs of BC557C's.
Is this a workable solution? I'd like to know before I etch a board. I'm no EE.
SSM2220 datasheet:
http://users.ece.gatech.edu/~lanterma/sdiy/datasheets/transistors/ssm2220.pdf
Quad-LFO-V3-pcb.pdf
re-route pin layout for SSM2220 matched PNP's
 Filename:  Quad-LFO-V3-pcb.pdf
 Filesize:  275.44 KB
 Downloaded:  455 Time(s)
yusynth
PostPosted: Tue Apr 12, 2011 2:48 pm    Post subject: Reply with quote  Mark this post and the followings unread
It should but probably it will be necessary to increase the value of R7 ( up to 100K I guess, this has to be tried up).
Yves
