Roland Kuit
Joined: Sep 29, 2003 Posts: 1090 Location: The Netherlands/Sweden
G2 patch files: 127
Posted: Mon Apr 25, 2011 6:03 am Post subject:
G2Demo not working Subject description: G2Demo not working |
Hello,
after replacement of my laptop motherboard,
the G2Demo is not working anymore.
I get the error message: not enough memory to perform requested action.
It has to do something with my realtek audio driver? Strange, because all vst's and daws are working.
Processor speed: P4800@2.26GHz 2.27GHz.
Mem. 4 GB
32 Bits.
Vist Home edition.
Is there a solution for this? |
BobTheDog
Audio files: 32
Posted: Mon Apr 25, 2011 1:14 pm Post subject:
| Have you tried a re-install? |
Roland Kuit
G2 patch files: 127
Posted: Mon Apr 25, 2011 3:21 pm Post subject:
Hi Bob,
Thank you for asking. I tried it several times with the same result.
I can't put my finger on the problem. |
BobTheDog
Audio files: 32
Posted: Mon Apr 25, 2011 11:55 pm Post subject:
I have a vague memory of this happening to me before but for the life of me cannot remember it fully!
What OS are you using? |
sneakthief
Roland Kuit
G2 patch files: 127
Posted: Tue Apr 26, 2011 4:35 am Post subject:
@Bob, Vista Home
@Sneakthief, I have done that too, but no luck. |
Posted: Tue Apr 26, 2011 4:55 am Post subject:
Wout told me, when he stayed here that the G2 demo was based on Flash. Perhaps this is a Flash update thing that is no longer supported? _________________ ACHTUNG!
BobTheDog
Audio files: 32
Posted: Tue Apr 26, 2011 5:09 am Post subject:
Ah Vista!
I'm surprised anything works  |
Roland Kuit
G2 patch files: 127
Posted: Tue Apr 26, 2011 10:33 am Post subject:
I have the latest adobe flash.
It worked on Vista with my old board.
I heard, some people have the same problem with Win 7 too. |
Posted: Tue Apr 26, 2011 10:42 am Post subject:
| roland kuit wrote: | I have the latest adobe flash.
Flash 10.2 came out recently. I've just updated flash on my W7 PC, but I do know that the demo was working before the update. I'll check now that I've got the update later tonight (the PC is our kids' "television"! ) _________________ ACHTUNG!
Roland Kuit
G2 patch files: 127
Posted: Tue Apr 26, 2011 11:33 am Post subject:
it was working with the old board and flash. When Win 7 just came out, some users experienced problems with the G2 Demo.
The Demo starts up. Than I click ok. I see immediately the error about memory. If I click audio/midi the message comes up again. |
Joined: Apr 03, 2004 Posts: 24670 Location: The Netherlands, Enschede
Posted: Tue Apr 26, 2011 11:50 am Post subject:
G2 demo using flash i don't think so guys  _________________ Jan
Posted: Tue Apr 26, 2011 1:24 pm Post subject:
Erm, I'm only going on what Wout told me. _________________ ACHTUNG!
Wout Blommers
Audio files: 123
G2 patch files: 12
Posted: Tue Apr 26, 2011 6:02 pm Post subject:
I can only say: Are you sure I told you?
To be honest, I haven't the faintest idea how the G2 Demo is working
Mostly I keep away from topics like this…
At the other hand: How many Wout’s do you know?
Wout |
Posted: Wed Apr 27, 2011 7:50 am Post subject:
| Wout Blommers wrote: | I can only say: Are you sure I told you?
Yes, 100%!! I was pretty shocked myself when you explained it to me.
It must have been the cheese's fault  _________________ ACHTUNG!
Posted: Wed Apr 27, 2011 8:05 am Post subject:
Good, glad that got solved
Roland, can you start the demo at all?
If not, it likely is not a driver issue, as when you start it for the first time it is not configured yet for any audio output. Unless ofcourse you just connected your old HD to your new MOBO .... but erm .. that'd be tough to fix then.
If you can start it: did you try to select another sound card and or audio format? _________________ Jan
Roland Kuit
G2 patch files: 127
Posted: Wed Apr 27, 2011 9:00 am Post subject:
there is no cheese in my laptop;)
@Jan, yes, I can start the Demo. But when I click ok on the first Clavia screen, I immediately get the out of memory message.
When I go to the audio/midi select menu, I get the same message.
My Real Tek High Audio Def driver is working correct. |
dorremifasol
Joined: Sep 28, 2006 Posts: 823 Location: Barcelona, Spain
G2 patch files: 49
Posted: Wed Apr 27, 2011 10:21 am Post subject:
Have you tried using ASIO4ALL instead of the default audio driver? _________________ Cheers,
Albert |
Roland Kuit
G2 patch files: 127
Posted: Wed Apr 27, 2011 1:32 pm Post subject:
| I can not get into the audio/midi set up. I get the out of memory screen again. I can load patches, but not hear them. The Asio driver is of no use for the Demo version. The Demo has no audio in. But thanks |
dorremifasol
G2 patch files: 49
Posted: Wed Apr 27, 2011 2:07 pm Post subject:
The demo can use an ASIO driver to work, even if it doesn't have any inputs. It runs with much lower latency.
Anyway, I just saw that it doesn't work in my computer either. I have Windows 7 64 bit. Must be a "vista" and "windows 7" incompatibility.
If you really need it you can run it inside a virtual machine. It works perfect in a virtual environment, only with some added latency (just tried it). I use Oracle VM VirtualBox, which is totally free and regularly updated, running a small windows installation ("TinyXP", or "Windows Fundamentals" for example). _________________ Cheers,
Albert |
Roland Kuit
G2 patch files: 127
Posted: Wed Apr 27, 2011 2:22 pm Post subject:
it has run always on my Vista with the Real Tek. But after my new motherboard, I can't reach/change audio drivers in the audio setup menu.
That memory problem keeps popping up.
And it is strange, can use a Daw with a lot of vst's. All working.
But I will try that, thnx. |
dorremifasol
G2 patch files: 49
Posted: Wed Apr 27, 2011 2:29 pm Post subject:
It's not a memory problem, I have 16 giga!
But guess what, based on what you said, I disabled the Realtek device on my computer, and now it works! through my Fireface, using ASIO even at 96khz.
So, to me it's clearly a realtek driver thing... _________________ Cheers,
Albert |
Roland Kuit
G2 patch files: 127
Posted: Tue May 03, 2011 5:35 am Post subject:
| No luck here guy's but thanks for looking in to it. Back to the store I guess. My other laptop(Sony) handels it now. B.t.w. also Vista with Teak. |
Symatic Star
Posted: Tue May 03, 2011 10:37 am Post subject:
Hi Roland, I also had this problem with vista and the demo I never solved it. The full editor worked instantly and is perfect on vista though.
Symatic
Roland Kuit
G2 patch files: 127
Posted: Tue May 03, 2011 12:43 pm Post subject:
| No problem with the hardware editor though:) |
