ericcoleridge
Posted: Fri May 13, 2011 11:13 pm Post subject:
Japanese Parts/Chips etc Subject description: Repairing Korg SE-500 Space (Stage) Echo - Schematic attached |
I've got a non-functional Korg tape delay just sitting around waiting for repair. I've tried replacing all kinds of parts, but I can't get it working. It's an electronic problem, not mechanical.
I've wondered if maybe the western substitute parts I've used are what's keeping it from working. There's an "MSM551" and "MSM4017 which I think are both CD4017s, and there's a "MSM4066", a CD4066. But I have no way of knowing if they're exactly the same.
Anyone have any experience with this Korg, or these Japanese parts? Last edited by ericcoleridge on Mon May 23, 2011 9:41 am; edited 1 time in total |
Clack
Joined: Aug 08, 2005 Posts: 438 Location: Walthamstow - london
Posted: Sat May 14, 2011 7:16 am Post subject:
Only Datasheets will really give you a clue to how similar they are if at all and it seems like they are thin on the ground.
got a schematic?? context helps _________________ Clacktronics.co.uk |
jordroid
Joined: Jan 17, 2010 Posts: 193 Location: ithaca, new york
Posted: Mon May 16, 2011 11:04 am Post subject:
Interestingly, a buddy just dropped a korg se-500 stage echo off with me to see if i could fix it. I haven't gotten anywhere with it yet, and i'm not certain i'm up for it, but it's kind of fun that we both have them at the same time.
I have not had luck (yet) finding a schematic or much of any information on these, the owners manual is easily findable but doesn't have much information you couldn't figure out just by looking at it.
I'll keep you posted if i figure anything out, please do the same if you locate a schematic or discover anything illuminating.
I believe my problem may be with the heads or circuitry for mixing in the repeats, as one head sounds great and does what it should, while the others do something but not much, you can hear a faint repeat or two but no dramatic echo and no avalanching echo oscillation. I have so far not done much more than verify that it is indeed not working correctly.
Anyways, good luck
jordan |
ericcoleridge
Posted: Thu May 19, 2011 3:42 pm Post subject:
jordroid wrote: |
This is the same thing that was wrong with mine! It got so bad that the echo became so faint as to be inaudible. I started trying to replace some of the CMOS chips, which happen to be japanese--but I figured they'd be the same, and I made it worse. It has this CMOS switching arrangement where the different tape heads combine and mix. I didn't know what else it could be.
Now, the LED indicators don't light up when I switch between the different head positions. But the audio still passes, and everything else is the same.
Most everything works, the Motor, the tape assembly, etc. Audio passes fine, so it's super frustrating-- mine worked very well for a short period of time. It's an amazing echo chamber, maybe not quite the sound of a Roland, but only because the noise reduction system on the Korg takes a bit of the rawness out of the sound.
I have the schematic, I can try to scan it at work and then upload it here(?) |
andrewF
Posted: Thu May 19, 2011 4:16 pm Post subject:
I have some interest in this thread, my SE500 still works fine but its only a matter of time 'til something gets too old. Be good to see the schematic and between us we might be able to work out the problem.
I'm don't think the MSM551 is the same as a 4017. Its BCD rather than pulsing outputs Q0-Q9, the 4029 can be configured as a BCD decade up counter. |
billfusion
Posted: Thu May 19, 2011 7:06 pm Post subject:
Have you tried looking up a schematic for a standard tape deck, and also look at standard tape defect help list.
Also I do know of some tape heads being fixxed by a claning and remember radio shack having a minidemagtizer for old day tape decks |
ericcoleridge
Posted: Fri May 20, 2011 2:27 pm Post subject:
andrewF wrote: | I'm don't think the MSM551 is the same as a 4017. Its BCD rather than pulsing outputs Q0-Q9, the 4029 can be configured as a BCD decade up counter. |
OK, I don't have the schem in front of me, and I may be confussed about this-- but, in my SE500, although the schem specifies MSM551s, the chips that were actually in there are labeled as MSM4017. So, I tried replacing them with CD4017, HEF4017. No dice. I also tried replacing the MSM4066s with CD4066s on the main board. Replaced the 1458 Op Amps too. In doing so, I also installed sockets. I don't know if I plugged something in wrong or made a soldering error, but somewhere along the way, I lost the LED indicators as well as the echos.
I actually don't know sh!t about electronics, so maybe when I post the schematic, someone will be able to understand what might be going wrong.
Unfortunately I don't even have Internet at home, let alone a scanner. But I'll bring the document with me to work on Monday. It's a decent copy, 11 X 17. I bought it online a few years ago. |
billfusion
Posted: Fri May 20, 2011 9:36 pm Post subject:
Know what Les Pual's best invention was?
I am an electronics tech and one problem that affect some circuits is flux, so be sure to usew some ispropol acholl to clean area after doing re-work.
you would be surprised how many boards i have fixxed doing that. Plus I do know older circuit boards used a heavy rosin core flux, nice but it leaches ans have fix some old stuff by reflowing and clean |
ericcoleridge
Posted: Mon May 23, 2011 9:39 am Post subject:
Korg SE500 Schematic, part 1 and 2.
If there's a better place for me to post these, let me know, and I'll move them.
Description: |
Filesize: |
576.47 KB |
Viewed: |
699 Time(s) |
Description: |
Filesize: |
556.05 KB |
Viewed: |
579 Time(s) |
jordroid
Posted: Tue May 24, 2011 6:02 am Post subject:
Thanks Eric, much appreciated.
I seem to have "fixed" mine by simply taking it apart and putting it back together, and cleaning the heads a bit. I'm not super confident that it will stay fixed but it is sounding much better, for now.
thanks and good luck,
jordan |
monotron
Posted: Wed Aug 24, 2011 3:37 am Post subject:
I seem to have a similar problem with my SE500.
I can hear a little bit of echo, but the volume is very low, the sound is very dull and I can hear maybe two or three taps of echo.
Ít could be the tape that needs replacement, or demagnatising the heads.
Anyway, if you solved your problems, i'd like to hear wath your solution was.
I disassembled mine yesterday, but that didnt do the trick. It actually made it worse. The motor is not running now, so i hope thats a losse connector or something.
Thanks
Walter |
monotron
Posted: Wed Aug 24, 2011 3:47 pm Post subject:
Update;
I checked for loose connectors and indeed, the connector to the motor was loose, so that was an easy fix.
I demagnetised the heads and other metal parts along the tape path. I also cleaned the heads again with 97% alcohol.
I have a somewhat normal echo right now. The feedback is still not at its maximum potential, but the tape is really old and thus crap. I have to order or make a new tape and i guess that will solve the rest of the problems. |
ericcoleridge
Posted: Wed Aug 24, 2011 5:43 pm Post subject:
I basically did the same thing with mine when I first got it; cleaned the heads, sort of adjusted their positions for maximum volume and clarity, changed the tape, fooled around with the repeat gain a little. It all helped a lot briefly, but then the echos started losing volume again. It was incredibly annoying.
I keep meaning to bring it in to a shop, but I live in NYC, and rent is out of control, I never have the extra money. But when I do, I'll ask the repair person what the problem was and hopefully shed some light on this machine.
monotron wrote: | Update;
monotron
Posted: Thu Aug 25, 2011 1:10 am Post subject:
That must be annoying, assuming all is ok after some cleaning and maintenance, but later the same problems rise up again.
I hope you´re able to find a good repairman and fix your Korg asap!
I also hope mine stays good now. It was a really big difference in sound by only demagnetising. I didnt expect the difference to be that big.
I´ll have look at your schems, to see where the feedback trimpots are, maybe i can crank it up a bit. |
monotron
Posted: Fri Aug 26, 2011 8:59 am Post subject:
I inserted a new tape today. It's not new, but it looked like it was unused. It's a RE-201 rt1l tape. Bu somehow the korg has less echo again.
I tested a sound on sound loop, but the volume faded away. I took about 5 loops of the sound to totally disappear. I have to look into this.
It might be the erase head, who's erasing the tape slowly, but i'm not sure an erase head can 'partly' erase the tape so volume is less. I'd guess an erase head either erases the tape totally or it doesn't erase at all.
It might be the Korg is somehow magnetizing itself and thus erasing the tape slowly with each loop of the tape being played.
I'll try and demagnetize it tonight again and do the test immediately afterwards. If volume is back to normal I think the machine is magnetizing itself....
DAMN!! |
ericcoleridge
Posted: Fri Aug 26, 2011 12:57 pm Post subject:
I think that I remember the Korg asks for a different kind of tape from the Roland. But, I wouldn't think that it would make a drastic difference were one to use the "wrong" kind of tape-- I think it would be more subtle.
monotron wrote: | I inserted a new tape today. It's not new, but it looked like it was unused. It's a RE-201 rt1l tape. Bu somehow the korg has less echo again.
DAMN!! |
monotron
Posted: Sun Aug 28, 2011 7:04 am Post subject:
ericcoleridge wrote: | I basically did the same thing with mine when I first got it; cleaned the heads, sort of adjusted their positions for maximum volume and clarity, changed the tape, fooled around with the repeat gain a little.
Hi Eric,
How did you fool around with the repeat gain?
I want to adjust the trimpot for the feedback/repeat, but i cant find a trimpot inside the SE-500 to adjust it?
Can you tell me how you adjusted your feedback?
Thanks
Walter |
