today> Twyndyllyngs Chez Mosc
good supplier for front panel material?
Page 1 of 1 [11 Posts]
darkomen
PostPosted: Thu May 26, 2011 3:29 pm    Post subject: good supplier for front panel material? Reply with quote  Mark this post and the followings unread
I'm looking to buy aluminum sheets to be cut for some panels. I've found this company called onlinemetals.com, and I'm wondering if anybody's bought anything from them before? They can cut to a custom size, and it seems pretty cheap, too cheap to be true kind of (which is why I ask for past experiences).
http://www.onlinemetals.com
Also, if anyone has a different company to order from that they like don't hesitate to suggest.
jumunius
PostPosted: Fri May 27, 2011 12:26 am    Post subject: Reply with quote  Mark this post and the followings unread
I'm sure they are fine. My only experience is with Metal Supermarkets -- I've had good luck with them so far.
Dave Kendall
PostPosted: Fri May 27, 2011 12:47 am    Post subject: Reply with quote  Mark this post and the followings unread
Several times, I got some great, cheap, high quality alu panels by contacting small local metal-working machine shops in the town's industrial area. They are often happy to make up panels in down time. Typical euro-sized, or even 5U is small by their standards, so using offcut alu is fine. They throw away small offcuts anyway, so for them it was money for scrap, + a wee bit of time. A bargain for both sides....
It helped to go there in person and offer cash. These guys are engineers, and can often be interested and intruiged by what you want it for.
Worked for me Smile
"Everything in moderation, including moderation"
softfin
PostPosted: Fri May 27, 2011 2:55 am    Post subject: Reply with quote  Mark this post and the followings unread
Agree. That's a good idea. I acquired almost all my front panels like that, locally. Quality is good and they cost almost nothing, like 50 panels of various sizes for ten euros.
PostPosted: Fri May 27, 2011 5:11 am    Post subject: Reply with quote  Mark this post and the followings unread
I found that some of the cuts I've ordered online where off by as much as 1/16" and if you are building something with a lot of modules the errors accumulate.
Online is ok but you want to check with the company to see if they can cut to your tolerances.
I finally broke down and bought this:
http://www.northerntool.com/shop/tools/product_200309556_200309556
(They also have a 8" model for around $89.)
darkomen
PostPosted: Fri May 27, 2011 6:53 am    Post subject: Reply with quote  Mark this post and the followings unread
Hmm, didn't even cross my mind to find someone locally.
I think I might just try onlinemetals, the price seems right.
djg
PostPosted: Fri May 27, 2011 7:23 am    Post subject: Reply with quote  Mark this post and the followings unread
Just have the tools ready to file down a couple millimeters of those panels. Some orders from OM have been worse than others for me, so I've been tempted to just get small runs in case I end up with way too many overlong panels that need reworking. But that idea gets squashed when shipping is like $20 for the smallest order.
Dave Kendall
PostPosted: Fri May 27, 2011 9:47 am    Post subject: Reply with quote  Mark this post and the followings unread
Have to say, each time I got stuff locally, it was spot on dimension-wise.
I think having personal contact with the guy doing the job may have helped too. Not just another impersonal electronic order...
I went to the same place one time in an emergency, and the guy welded up a broken keyboard stool for nothing!
I got enough panels of different widths from 6hp up to 24hp to fill six or seven 6U 19" racks for about $80. Not bad ..... Wink
RSFC
PostPosted: Tue May 31, 2011 11:26 am    Post subject: Reply with quote  Mark this post and the followings unread
My onlinemetals order was 1/4" longer than I wanted (I ordered them in eurorack sizings). They did re-do the order and the second batch was also 1/4" over... I got so many of the oversized panels I decided to just use that as a format.
I recently got some panels from metal supermarkets (who have a location somewhat near to me). Their panels were the correct size.
PostPosted: Tue May 31, 2011 11:43 am    Post subject: Reply with quote  Mark this post and the followings unread
I feel your pain... same thing happened to me. So, on my second order, I ordered the panels correspondingly short -- well, guess what? They cut them exactly to order!
That's when I ordered the cutter from Northern Tools.
diablojoy
PostPosted: Tue May 31, 2011 3:48 pm    Post subject: Reply with quote  Mark this post and the followings unread
I am lucky to have a fairly well kitted out workshop so from early on i have cut my own from half size sheets 1200 x 1200 x 3mm on a bench saw fitted with an ally blade this way i can guarantee the size is always spot on. it also happens to be the cheapest way i think Smile I buy the sheets from a local industrial ally supplier
