today> Various Artists September equinox Concert
thanks and adsr as modulator query
Page 1 of 1 [5 Posts]
frank discourse
PostPosted: Tue May 31, 2011 4:26 pm    Post subject:  thanks and adsr as modulator query
Subject description: basic advice
Hey everyone,
Thanks for the direction with the sndbuf question Inventor.
I have been putting in the hours and worked the problem out trial and error.
Recently I have been trying to get the ADSR or Envelope to function as a modulation source for lfo amt but despite reading the manual and looking on the web am still having no luck.
Is there a way to access the env level in a similar way to using lfo.last()
when reading a lfo level?
GrandJu
PostPosted: Fri Jun 03, 2011 7:41 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi Frank,
Theoretically you can use .last() function for all UGen.
I use ADSR to control filters frequency. So it should work for modulation too.
If you want your ADSR to output values don't forget put an input into it.
Like this:
Code:
Step target_freq =>ADSR vcf_adsr => vcf.freq_ctrl;
target_freq.next(59.0);
vcf_adsr.set(50::ms, 0::ms, 1, 100::ms);
Don't hesitate to send the piece of code that doesn't work on your side.
Ju
frank discourse
PostPosted: Mon Jun 06, 2011 9:32 pm    Post subject: thanks GrandJu Reply with quote  Mark this post and the followings unread
Appreciate the guidance, I think I was omitting the ADSR input as you suggested.I am painfully aware that my training wheels will be on for a while with ChucK but am putting in serious hours and making some headway.
Thanks again frankie_d.
flies
PostPosted: Wed Nov 30, 2011 2:25 pm    Post subject: Reply with quote  Mark this post and the followings unread
I can't find a UGen that has a freq_ctrl property. How do you do frequency modulation on a filter? (am noob.)
GrandJu
PostPosted: Fri Dec 02, 2011 9:26 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi flies,
I didn't find it too. But I think there is no way to perform it directly.
I created a class using the freq() function of the filter and udating it each sample to change cutoff frequency.
Code:
public class lpf_vcf_light {
    Gain in;
    Gain out;
    LPF lpf_filter_u;
    lpf_filter_u.freq(300);
    fun UGen connect(UGen @ u)
        int i;
        u => in => lpf_filter_u => out;
        return out;
   fun void update_freq(UGen @ freq_in) {
      while (1) {
         Std.mtof(freq_in.last()) => lpf_filter_u.freq;
           if (lpf_filter_u.freq() <1> now;
   fun void update_Q(UGen @ Q_in) {
      while (1) {
         Q_in.last()/24 => lpf_filter_u.Q;
         1::samp => now;
   fun void freq_ctrl (UGen @ freq_in) {
      freq_in => blackhole;
      spork ~ update_freq(freq_in);
   fun void Q_ctrl (UGen @ Q_in) {
      Q_in => blackhole;
      spork ~ update_Q(Q_in);
/* Examlpe, please comment when used as public class */
lpf_vcf_light vcf;
SqrOsc s => vcf.connect => dac;
s.gain(0.3);
Phasor p => vcf.freq_ctrl;
p.gain(127);
p.freq(0.5);
Phasor p2 => vcf.Q_ctrl;
p2.gain(127);
p2.freq(0.1);
while(1) {1::ms => now; <<<vcf>>>;}
