I just have to know...
Page 1 of 1 [21 Posts]
Static Strobe Emitter
Audio files: 243
PostPosted: Fri Feb 25, 2005 10:39 pm    Post subject: I just have to know... Reply with quote  Mark this post and the followings unread
Am I the only one here making music (software based) without
a MIDI synth? =/
seraph
Editor
Editor
Audio files: 33
PostPosted: Sat Feb 26, 2005 2:00 am    Post subject: Re: I just have to know... Reply with quote  Mark this post and the followings unread
a MIDI synth? =/
by MIDI synth you mean hardware synth Question I use both hardware and softsynths Very Happy
PostPosted: Sat Feb 26, 2005 3:33 am    Post subject: Reply with quote  Mark this post and the followings unread
Hmm.. you actually mean a synth with no midi? Sure, I have some old crap around I love that does not have midi at all. That said, some of the synths here do have midi too, but I rarely use midi. The softsynths do however all have midi, and it is pretty amazing how my DAW can record midi performance data. Midi is promising technology. One day it will be the next hot thing!
Kassen
PostPosted: Sat Feb 26, 2005 3:48 am    Post subject: Reply with quote  Mark this post and the followings unread
I use both hardware and software, some of that hardware has midi, some doesn´t. My primary use for midi is the midi clock to sync up Live´s paterns to the Nord´s paterns. Midi has some weaknesses that make it unsuitable for my music most of the time, especially in how it deals with polyphony and controll of notes. Sometimes I´ll work purely on a sample based level for more detailed controll.
What are you using, Static Strobe?
Kassen
Ponk
PostPosted: Sat Feb 26, 2005 3:50 am    Post subject: Reply with quote  Mark this post and the followings unread
I don't know if I count as someone making music (Wink), but I don't use MIDI. I use Buzz. shakng2
Audio files: 297
PostPosted: Sat Feb 26, 2005 6:13 am    Post subject: Reply with quote  Mark this post and the followings unread
Depends.
Midi sequencing and cubase & stuff don't work for me - tools like those make me feel bored before I finish anything.
Sometiimes I just use CoolEdit and some sounds which may be as simple as a drawn wave form or as complex as a recording of something.
For noodles I don't really use midi either, midi is used just as an internal communications bus in the G2 then. Sometimes when two G2's are involved some midi might be exchanged through real cables though, controller information mosly.
Softsynths have never worked on any of my computers, except for some trivial models.
Anyway I think it's more sculpturing what I do than making music.
Jan.
Audio files: 243
PostPosted: Sat Feb 26, 2005 2:03 pm    Post subject: Okey. Reply with quote  Mark this post and the followings unread
I think i was a little diffuse in my first message,
what I meant was:
Am I the only one sitting and clicking out every single
note on the pattern sheets with my mouse? Very Happy
I thought most composers sat and played on their synths
right into their composer program instead of just clicking
them out with the mouse Razz
but maybe I was wrong ;D
PostPosted: Sat Feb 26, 2005 2:15 pm    Post subject: Reply with quote  Mark this post and the followings unread
That would be the "piano roll" interface?
I often edit small stuff in either the notation editor or in the piano roll editor in Cubase. That is quick and easy and it all depends on what I am actually trying to do. A lot of the voices I just record live, and keep doing so until the performance is OK. some of voices that are supposed to be vintage analog sequencers or digital step sequencer stuff, I just write in using the notation editor and later I edit certain stuff in the piano roll view. I still have the MSQ 100s and the 300s, the MSQ 700, the MMT8 and the MC8.. and then some Formant style sequencers and of course the old Phonosoc. I haven´t used them for years. Cubase is cool.
The notation editor is cool. You can write the sheet music in there.. and then read it while you record. That beats turning those pages manually.
PostPosted: Sat Feb 26, 2005 2:34 pm    Post subject: Reply with quote  Mark this post and the followings unread
I mainly record the lot as audio more or less directly, so I am rarely "changing the sounds" on the midi tracks. Cubase is an excellent multitrack taperecorder with built in midi and oldstyle sequencing tools. A tad more advanced than the Waveterm.
seraph
Editor
Editor
Audio files: 33
PostPosted: Sat Feb 26, 2005 2:43 pm    Post subject: Reply with quote  Mark this post and the followings unread
Am I the only one sitting and clicking out every single note on the pattern sheets with my mouse?
I don't know if you are the only one but I usually play into a midi sequencer and then edit the sequence if necessary (always Rolling Eyes ). since using Live I have tried also recording directly audio playing my keyboard controller. it depends what I am looking for Very Happy
Audio files: 297
PostPosted: Sat Feb 26, 2005 11:13 pm    Post subject: Reply with quote  Mark this post and the followings unread
right ... how to write down notes ...
I don't, because writing is too hard and reading back is impossible. Just like programming a computer in C, best to avoid it.
But otoh I gues I do write notes as I do have some concept of numbers that "go together", like twelve and nineteen & some modulo five or seven stuff that will be alright then. Modulo 2, 3 and 9 are ok as well but harder to fit in when going recursive, but can give pleasant tension when not going too deep into recursion.
Sometimes I simply need 6, 8 or 10 for reasons I don't quite understand. 1 and 11 are very very hard (hardder than 4/5 or 5/4I) , 12 and especially 0 is just boring.
Sequences are usefull, like 0, 2, 4, 5, 7, 9, 11, this combines with the numbers 3 and 7 ok, less with 5. Other sequences need other combinations, its a bit like a puzzle.
I write numbers and sequences like these out into rulles, in the language the synth understands which is modules and wires & knobs and then I adjust until it works for me - others say I'm out of tune sometimes, but that doesn't really worry me.
This inumber scheme thing is easier and more flexible for me than the "traditional scribble", but I must confess that I don't have a notion of the benifits of the traditional method .... since I was ten or so people have tried to hammer it in, but it doesn't work ... and I don't care about it anymore ...
Jan.
Kassen
PostPosted: Sun Feb 27, 2005 3:52 am    Post subject: Re: Okey. Reply with quote  Mark this post and the followings unread
Nah, I click too, all of my synths are rack models and the EMU Launchpad my only midi keyboard. I usually won´t click out every single note though, I use a lot of copy/paste and other hotkeys. I just leave Live to loop untill it sounds good. From time to time I´ll programt eh behaviour of the synth out and only sequence broader gestures like timing offsets and chords.
I can´t actually play keyboard anymore with any skill. I used to play the acordeon for years and still have the inclination to want to have my scales vertically, I hold the guitar like a standup bass too. Perhaps I should get one of those strap-on keyboards, those might suit me.
Kassen
Audio files: 243
PostPosted: Sun Feb 27, 2005 3:58 am    Post subject: HEhehehee :D Reply with quote  Mark this post and the followings unread
I havent used a MIDI synth over the past 7 years,
and sadly enough im getting used to it Razz
I dont even think i can play "twinkle little star" on a synth anymore ;D
the last time i used a synth was at school were they used Cubase,
but when i finished school ive never bothered getting one, and
just continuing my tracking in Protracker, and then getting on to
the sequencers Smile
PostPosted: Sun Feb 27, 2005 6:39 am    Post subject: Reply with quote  Mark this post and the followings unread
This thread is actually touching upon issues we could discuss in the Composition forum. It seems to me that we might need some sort of clarification of current traditions in "serious music". All you guys are actually working and writing music in a way that actually does conform 100% with the serious way of doing things.
Using a term like serious in this context is of course laughable, but it has come to be an accepted term within the academic music circles for "proper music" vs. how the lesser gifted are making their music. Large parts of this is mythology and the truth about how things really are will probably be a good thing.
Audio files: 243
PostPosted: Sun Feb 27, 2005 7:22 am    Post subject: Welll.... Reply with quote  Mark this post and the followings unread
Elektro has a good point here Smile
I must say, I dont really know what to define as "unserious" music making :O
If someone clicked on a Button and a Program automatically generated
a music track for you, that might be unserious. but nothing more what
I can think of now.
Audio files: 225
PostPosted: Mon Feb 28, 2005 2:15 pm    Post subject: Reply with quote  Mark this post and the followings unread
I guess, stirctly speaking, I use MIDI all of the time. Even when I'm improvising on a keyboard in a blues style, I'm playing with my fingers on one keyboard and making sounds on the other using MIDI as an interconnection. I rarely record MIDI like I did in the 1980s any more.
I never compose clicking notes and events with the mousc. I work almost always in an improvised fashion, whether with notes or straight with electronic sounds from my synths.
play
PostPosted: Tue Mar 01, 2005 3:51 pm    Post subject: Reply with quote  Mark this post and the followings unread
midi is nearly unavoidable. I use buzz too but still use midi to interface with other apps. No hardware synths for me. I do probably about half of my work internally in reaktor manipulating floating point data streams. I'm a big an of reaktors samplers that allow playback by ramp oscillation (or whatever, usually whatever) controlling position in sample in milliseconds. Not a big fan of hardware synths or drum machines. I'd rather use a tracker. I do have a theremin though. Lots of fun.
diskonext
PostPosted: Wed Mar 02, 2005 6:41 am    Post subject: Reply with quote  Mark this post and the followings unread
I'm really on-offish about actually playing the keys to record stuff.
I do a lot of loop-based stuff which merely requires a lot of tweaking of parameters (in Reaktor, or Live or wherever) until it sounds right. I might add some twiddling of knobs and recording that as well.
On the other hand, to break out of the mold I sometimes improvise with beats and synthsounds via my (MIDI-)keyboard for 2-3 minutes, usually accompanied by a metronome or a simple beat+hat pattern and cut out the most promising parts, and then fine-tune those sounds. It usually ends up as a static x0x-style pattern again, however.
-diskonext
:wq
LoKi
PostPosted: Sat Mar 05, 2005 10:33 am    Post subject: Re: Okey. Reply with quote  Mark this post and the followings unread
OMG I feel for you, buddy!
I was in this exact same position not very long ago.
Manually drawing bars into piano roll with a mouse - Aaaaargh! Shocked
Luckily, a guy I met at an afterparty around Xmas had a Roland E-16 gathering dust in the corner of his studio - and after I subtly explained the position I was in he insisted I take the Roland home with me on loan!
Here's the part that works out positively for us:
Having spent more than 4 years 'playing the mouse', I am very adept in piano roll - so cleaning up those tracks I entered with the Roland is a piece of cake!
Also, not having a MIDI controller forces you to explore the capabilities of your piano roll further. (You would be surprised at what you can do mixing up some 'chop' and 'random' settings!)...
"I reject reality, and substitute my own." - Adam Savage
View user's profile Send private message Send e-mail MSN Messenger
Dovdimus Prime
Audio files: 6
PostPosted: Mon Mar 07, 2005 3:03 pm    Post subject: Reply with quote  Mark this post and the followings unread
Wow! I completely missed this thread!
Yes, I write every note with the mouse in piano roll. Other than playing an instrument, which I'm not really able to do, I don't understand what the alternatives are.
I'm perfectly happy with things the way they are. The tunes end up sounding how I want them to. What more could I want? Very Happy
This message was brought to you from Beyond The Grave.
Kassen
PostPosted: Mon Mar 07, 2005 3:18 pm    Post subject: Reply with quote  Mark this post and the followings unread
Well, the third way would be having a rules based system or a hybrid form. I´d considder some sequencers to be hybrid forms; the Serge TKB sequencer can be used as a cross between a instrument and "written music", so can Live. I think crosses between instruments and algorithems are popular in the IDM/glitch scene for live performance and of cource hardware step-sequencers are a cross between instruments and written music for techno/house/etc.
Apart from the basic which sorta come down to *playing it, *describing how to play it and *defining based on what such a description might be made we can have any amount of crossbred forms.
One of the resons I sugested this forum was that I´m realy interested in what people are actually using since I´ve started to believe the conventional (cubase, etc) ways of making electronic music have their roots in rock and blues structures and are not at as usefull for electronic music at all.
Kassen
