TZFM SAW VCO
Page 18 of 22 [537 Posts]
Goto page: Previous 1, 2, 3, ..., 16, 17, 18, 19, 20, 21, 22 Next
frijitz
Audio files: 54
PostPosted: Fri Aug 27, 2010 6:01 pm    Post subject: Reply with quote  Mark this post and the followings unread
Funky40 wrote:
I never found it more interesting or musical to patch two teezers than a teezer and another highfrequenzyrange VCO.
Could you clarify that? What exactly can you do with the other VCO that you couldn't do with a second Teezer?
Ian
Luka
PostPosted: Sat Aug 28, 2010 12:55 am    Post subject: Reply with quote  Mark this post and the followings unread
frijitz wrote:
Luka wrote:
which results in that list in particular dont make sense?
u2-2: I don't see how this could be varying with the frequency control.
u2-3: I don't see how this could possibly be near -11V. (u2 is powered by +/-7V, R29 is connected to +5V, etc.)
Sorry, this is completrely crazy.
Ian
Hi Ian
Im trying to solve this problem again.
Following your procedure listed in previous pages
expo looks ok
A2-6 is steady at -3.36
U2-2 0.53
U2-3 1.11
U2-7 -6.8
U3-2 -4.3
U3-3 -4
U3-7 -5.69
do they look ok?
problemchild
melbourne australia
frijitz
Audio files: 54
PostPosted: Sat Aug 28, 2010 1:45 am    Post subject: Reply with quote  Mark this post and the followings unread
expo looks ok
U2-2 0.53
U2-3 1.11
U2-7 -6.8
U3-2 -4.3
U3-3 -4
U3-7 -5.69
Hi Luka --
A2-6 is the oscillator output. For some reason it can't ramp all the way down to -5V. Most likely is that one or both of the FETs Q4/Q5 is buzzed. These are very easy to damage with too much heat while soldering or by static. So next try replacing them both. Make sure you stay grounded, and leave the leads longish. Solder quickly, preferably with a clip on the lead to dissipate heat.
Ian
Luka
PostPosted: Sat Aug 28, 2010 2:33 am    Post subject: Reply with quote  Mark this post and the followings unread
damn guess ill have to order some more of those
i actually have the fets placed in pin sockets
they were never soldered directly
problemchild
melbourne australia
frijitz
Audio files: 54
PostPosted: Sat Aug 28, 2010 2:42 am    Post subject: Reply with quote  Mark this post and the followings unread
Well, it could be something else, but that's where I would start. At least they're not too expensive.
That's a real good idea. You could pull them and try them in a test circuit to see if they are good or not. Or try replacing them with some generic MOSFET -- you should at least get some oscillations (I think).
Ian
Luka
PostPosted: Sat Aug 28, 2010 5:20 pm    Post subject: Reply with quote  Mark this post and the followings unread
ian i swapped the mosfets from my working teezers into this one and it made no difference. what would be the next section to check?
problemchild
melbourne australia
frijitz
Audio files: 54
PostPosted: Sat Aug 28, 2010 6:09 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hmmm ... hard to know where to start.
1...Check whether A2, pin 6 changes at all as you move the Init control from end to end. Check with a scope probe to see if there are small hf oscillations there.
2...Are you using LM311's from the same supplier as on the other boards?
3...Measure the voltage at the node where D2, D6, et al come together.
Let's start with those.
Ian
Luka
PostPosted: Wed Sep 08, 2010 4:08 am    Post subject: Reply with quote  Mark this post and the followings unread
getting back to this
d2-6 node is steady on -1.6v
lm311s are from same batch
i have some from another batch i can try and will do after posting this
When measuring A2 pin 6 there is no change when turning init or tune
here is a scope shot from that node
 Filesize:  1.22 MB
 Viewed:  561 Time(s)
problemchild
melbourne australia
Luka
PostPosted: Wed Sep 08, 2010 5:10 am    Post subject: Reply with quote  Mark this post and the followings unread
well as smart as i thought i was by using pin connectors on the transistors they were my downfall in this case. the bass of the connector was shorting pin 2 to pin 3 of A2 ie to ground.
i just de-soldered the area and put it back together and it is up and running
a good way to finish a frustrating day
problemchild
melbourne australia
Funky40
G2 patch files: 5
PostPosted: Mon Sep 13, 2010 1:30 am    Post subject: Reply with quote  Mark this post and the followings unread
nothing ofcourse.
a teezer is a very fine modulationsource.
but it's in my opinin not necessary to have two Thru Zero VCOs in one package.
sorry for not being clear enough.
tomcat
PostPosted: Sat Oct 23, 2010 10:31 pm    Post subject: Re: Dual Teezer module? Reply with quote  Mark this post and the followings unread
frijitz wrote:
Well, yes! Scott at bridechamber and I are working on a dual version in euro format. I wanted to do it without changing the board layout significantly, so I just shrunk it down a bit and added the extra power connector. Scott is working on the challenge of designing mounting brackets -- it's going to be a tight squeeze.
We haven't talked about cross-connections yet, but it seems to me it would be easy to normalize some connections on the panel, without changing the board.
Ian
News about this project?
Terrafractyl
PostPosted: Tue Jul 12, 2011 1:06 am    Post subject: Reply with quote  Mark this post and the followings unread
Hm I thought I already posted something here and it dissapeared... strange, ah well I'll try again!
So i've just finished putting together a Teezer, and on powering it up it works(all outputs), but only as long as I have the Initial Frequency pot above 12 o'clock.
As soon as it goes below, it kind of dies and I get nothing from any of the outputs until either I, power down, turn up the initial freq pot and power up the Teezer... or if I put a signal into the sync input it also kick starts the oscillations.
I'm using a kit from bridechamber and I used Dave Browns 15v resistor/diode mod.
All the IC's seem to be getting the correct power, + - 7v on U2 and 3 and +-9v on the A4
I checked the output of A3-6 and it swings from +5 to -5v fine.
I checked A2-6 output and it mesures +2.5 when the Oscillator is giving me sound and +5.0v when it has gone silent. Also the outputs all give me +5.0v when the oscillator is silent.
I checked the node where D2, D4, D6 etc join and when the Oscillator is working I get a -6.3v but when the Oscillator has gone silent I get a 3.5v
I only have software scope, but the saw has a very sharp downward peak just before the top of the waveform, and the sinewave is round at the top and triangular on the bottom.
So I have a feeling that it might be something to with either one of the LM311's or one of the VN0104's. but any help would be greatly appreciated.
Even without the Through zero, and with the problems it has, its sounds great already, I cant wait to get it working properly!
frijitz
Audio files: 54
PostPosted: Tue Jul 12, 2011 1:36 pm    Post subject: Reply with quote  Mark this post and the followings unread
Terrafractyl wrote:
...So i've just finished putting together a Teezer, and on powering it up it works(all outputs), but only as long as I have the Initial Frequency pot above 12 o'clock.
Ouch! Sorry you are having trouble. Thanks for getting a start on the troubleshooting -- that helps a bunch.
To make sure I'm clear, you can only ever get an upramp? IOW, you can not jumpstart the downramp?
Could you please check the output voltages (pin 7) of U2 and U3 when the system is stalled?
My guess is that one of the VN0104 MOSFETs is buzzed. The are very sensitive to both heat and static -- I've buzzed a few myself. So if you have checked everything carefully (correct parts and orientation, no solder bridges) then the first thing to try would be to replace Q4 and Q5. Carefully -- leave the leads a bit longish and solder quickly.
Good. I hope the problem is simple.
Ian
emdot_ambient
PostPosted: Fri Jul 15, 2011 4:40 am    Post subject: Reply with quote  Mark this post and the followings unread
Terrafractyl wrote:
...So i've just finished putting together a Teezer...
Keeping my eye on your progress, as I've just finished stuffing the PCB on one of these as well. Haven't fired it up yet, though.
I've been working on a front panel design that includes an Oakley Looping ADSR/VCA, normalized so the VCA output goes to the Teezer's FM input (without a signal plugged into the VCA Input, the VCA Out jack passes the ADSR's signal), switchable between Linear and Exponential. (Plugging an external signal into one of the FM input jacks disconnects the VCA output to that jack.)
In my mind at least this seems like an interesting option. Without any signal plugged into the module and the ADSR in looping mode, there's an onboard modulation source. Of course, the ADSR/VCA can be used separately as well.
Will it be really useful dunno
Have to wait for the Oakley PCB to get here to find out.
Terrafractyl
PostPosted: Sat Jul 16, 2011 8:43 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi Ian Smile
thanks for getting back to me so quickly, I had a busy few days but just had another look.
So If I feed a square wave or something into the sync input I get 'something' from the oscillator when it the initial freq pot is in the negative position. but it is nothing close to a waveform, more like splutters and gurgles. As soon as I unplug the sync input it disappears again.
So when the system is stalled I get -6.7 V from U2-7 but 7.0v from U3-7.
When the system is up and running I get -6.6 or -6.7v from both, so I'm guessing this is something to do with the problem. Could It be as simple as swapping out the LM311 (U3) I dont have any lying around but that would be way easier than:
cause yeah, I 'just' did a mouser order and I don't do very many, I can't seem to find VN0104's anywhere here in Australia, so I guess I'll have to wait until I have a good excuse to order some stuff.
Thanks again for the help!
frijitz
Audio files: 54
PostPosted: Sun Jul 17, 2011 1:54 pm    Post subject: Reply with quote  Mark this post and the followings unread
OK here are some things to try. First, the values of R132 and R133 are reversed on the schematic, so you should switch them. Then make sure the output of A9-7 is always low as long as there is no Sync In connection. (This really shouldn't be the main problem.)
There are issues with LM311s from different manufacturers behaving differently, so you could try swaping out U3. But first try increasing the value of C8 slightly (not too much, though). Try values between 27 and 47pF. For example, you could parallel C8 with another 22pF part.
Also please double-check that D7 is oriented correctly.
Let us know how these ideas work out!
Ian
Terrafractyl
PostPosted: Mon Jul 18, 2011 6:58 pm    Post subject: Reply with quote  Mark this post and the followings unread
Ok so I've switched r133 and r132.
I double Checked D7, Its ok
A9-7 on the other hand seems a little odd. It is giving me -13.8V with nothing applied to the sync input. and -13.6V with a signal.
could this be a problem?
I'll go and try changing C8 right now also but I wont be able to switch out the LM311 for a few days.
thanks again for your help Ian
frijitz
Audio files: 54
PostPosted: Tue Jul 19, 2011 5:35 pm    Post subject: Reply with quote  Mark this post and the followings unread
That's fine; the sync signal is a narrow pulse, which you may not be able to see.
ian
moellhoven
PostPosted: Sun Oct 02, 2011 11:37 am    Post subject: Reply with quote  Mark this post and the followings unread
Just finished building my Teezer and fired it up.
At first glance everything seems to work fine.
When i started to calibrate the module i noticed that when the initial freq knob is turned full left or right the lowest freq i could tune in with the coarse knob is around 100hz.
Also when the coarse knob is turned fully down the VCO does not react to the signal from the V/OCT input anymore.
Please help Smile
frijitz
Audio files: 54
PostPosted: Mon Oct 03, 2011 2:55 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hmmm ... that's odd. As you reduce the coarse knob does the frequency get to 100Hz at some point and then stay there? (That would explain why the V/O input has no effect.)
Does the freq go to zero as you tune the Init pot through its midpoint.
Do the waveshapes look pretty OK?
Ian
moellhoven
PostPosted: Tue Oct 04, 2011 12:15 am    Post subject: Reply with quote  Mark this post and the followings unread
Yes, that is exactly right.
Yes.
The Saw and Tri look pretty OK when the Init pot is turned left. When turned right it looks funny at the top.
The bottom half of the sine looks good. The upper half is more like a triangle.
Thank you!
 Filesize:  44.34 KB
 Viewed:  38928 Time(s)
 Filesize:  38.6 KB
moellhoven
PostPosted: Tue Oct 04, 2011 12:19 am    Post subject: Reply with quote  Mark this post and the followings unread
I forgot to add that I used the Bridechamber kit for 15V.
frijitz
Audio files: 54
PostPosted: Tue Oct 04, 2011 10:09 am    Post subject: Reply with quote  Mark this post and the followings unread
OK, it looks like the waveshapes are OK, just out of adjustment.
The problem with the frequency range is probably in the expo converter section: A1a, A1b and the transistor pair. There must be a wiring error or a bad component or a solder bridge or something in there somewhere.
I can't say much beyond that. If you want to measure the voltage at the A1a output (pin 1) as the coarse pot is varied from end to end, that might be helpful.
Ian
moellhoven
PostPosted: Thu Oct 06, 2011 12:38 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for pointing me into the right direction. Will do some checking on the weekend.
There is one thing i am not sure of i got it right. The kit came with an SSM2220 but without an TempCo.
From the documentation i figured it is missing and i added one of my spares to R14b. Is this OK or is this maybe the problem?
emdot_ambient
PostPosted: Thu Oct 06, 2011 4:49 am    Post subject: Reply with quote  Mark this post and the followings unread
I recently built a TZFM from a Bridechamber kit (it sits untested) and they forgot the tempco on mine as well. I contacted them and they replaced it along with an apology. Apparently there was a batch of the kits where the tempcos were accidentally left out.
