ARP FILTER trimming
Page 1 of 1 [9 Posts]
roman_f
PostPosted: Thu Oct 06, 2011 1:33 pm    Post subject: ARP FILTER trimming
Subject description: 0V?
could you please tell me how can i apply 0V to trim T1
where can i get that 0V?
Ali M
PostPosted: Thu Oct 06, 2011 2:42 pm    Post subject: Reply with quote  Mark this post and the followings unread
you have to measure from the base of the transistor and adjust T1 so the voltage reads 0v.
you don't apply 0v to T1.
yusynth
PostPosted: Fri Oct 07, 2011 12:15 am    Post subject: Reply with quote  Mark this post and the followings unread
Very simple, you can do that by shortening the input to ground.
Yves
roman_f
PostPosted: Fri Oct 07, 2011 6:57 am    Post subject: Reply with quote  Mark this post and the followings unread
thank you yves :) now i need to find a 1V source
yusynth
PostPosted: Fri Oct 07, 2011 7:16 am    Post subject: Reply with quote  Mark this post and the followings unread
roman_f wrote:
thank you yves Smile now i need to find a 1V source
If you have a CV/GATE keyboard or a MIDI keyboard and a MIDI2CV converter you can simply use then to generate the various steeped voltages 0V, 1V, 2V and so on by pressing the C keys at different octaves.
Yves
roman_f
PostPosted: Fri Oct 07, 2011 8:22 am    Post subject: Reply with quote  Mark this post and the followings unread
perfect, thank you :) the last question - is the basis located on down right leg?
 Filesize:  17.86 KB
 Viewed:  6072 Time(s)
yusynth
PostPosted: Fri Oct 07, 2011 8:31 am    Post subject: Reply with quote  Mark this post and the followings unread
No the bases of the dual transistors are leftmost and rightmost pins. For trimming you must do the testing on the right most : the pin that is in connection the CV input resitors.
Yves
roman_f
PostPosted: Fri Oct 07, 2011 8:45 am    Post subject: Reply with quote  Mark this post and the followings unread
so the input where i apply 0V and 1V is a 1V/Oct input? not the audio one?
yusynth
PostPosted: Fri Oct 07, 2011 9:56 am    Post subject: Reply with quote  Mark this post and the followings unread
Yes and that's exactly what is written in the trimming instructions :
Turn the frequency knob to 0, turn all the control knobs to 0 (fully counter clockwise)
Apply 0V to the V/Oct input
Measure the voltage at the basis of Q6 (2SA798) (node between R46, R30 to R34), adjust T1 in order to obtain 0V at this very node.
Apply 1V to the V/Oct input
Adjust T2 in order to measure 18.7mV at the previous node.
Adjust T1 in order to measure -187mV at this very node.
Yves
