 Forum index » Instruments and Equipment » Strings and things
Serial to Parallel FX loop pedal thingy
Post new topic   Reply to topic Moderators: BobTheDog
Page 1 of 1 [6 Posts]
BobTheDog
Audio files: 32
PostPosted: Fri Dec 16, 2011 8:10 am    Post subject: Serial to Parallel FX loop pedal thingy Reply with quote  Mark this post and the followings unread
Hi Guys,
Does anyone know if you can get such a thing as a serial FX loop to parallel FX loop pedal with a stereo to mono return?
I need it to be line level, hopefully switchable between -10/+4
Buggered if I can find anything, the closest I could find would be http://www.pigtronix.com/products/keymaster/ but this is for guitar level fx.
Andy
GovernorSilver
PostPosted: Fri Dec 16, 2011 4:46 pm    Post subject: Reply with quote  Mark this post and the followings unread
How something like a Whirlwind line splitter to split one signal into 2 isolated outputs and one direct output?
Then a line mixer to mix the parallel signals back into one?
Some old stuff on VIRB
GovernorSilver
PostPosted: Fri Dec 16, 2011 4:52 pm    Post subject: Reply with quote  Mark this post and the followings unread
Lehle makes a lovely line mixer pedal for use with effects loops. It is said to handle line level signals as well as guitar level.
http://www.lehle.com/frameset.php?country=us&lang=en
This store has a listing more other options to look at:
http://www.pedalspluseffectswarehouse.com/ABY_Switching_and_Loops_s/59.htm
Oskar
PostPosted: Sat Dec 17, 2011 12:16 pm    Post subject: Reply with quote  Mark this post and the followings unread
Me, I've got a Lehle 1@3 selector, the old discontinued one. It works as either a 1 into 3 output selector, or the 3rd switch can be used to control an fx loop on ch 2. Very nice, I've never felt it coloured my instruments' sound in any way. Here's the link to the current model:
http://www.lehle.com/frameset.php?country=gb&lang=en
Where there are too many policemen, there is no liberty. Where there are too many soldiers, there is no peace. Where there are too many lawyers, there is no justice.
Lin Yutang (1895-1976)
BobTheDog
Audio files: 32
PostPosted: Mon Dec 19, 2011 1:43 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi Guys,
Thanks for the pointers.
Lehle do some interesting stuff!
Andy
GovernorSilver
PostPosted: Tue Dec 20, 2011 4:59 pm    Post subject: Reply with quote  Mark this post and the followings unread
I neglected to mention I use a Voodoo Lab Amp Selector, which is one of the products listed on that Pedal Plus Effects website. It splits either of 2 inputs into 4 outputs plus a tuner output, which is always active. It can be set to parallel mode (0-4 outputs active in parallel) or only one output active at a time.
There are individual level controls per output.
Actually, I haven't used it for a while. I was using it to send a dry output to the power amp input of my tube guitar amp, output #2 to the Nord Modular G2 for effects processing, and output #3 to my EHX HOG->Damage Control Timeline pedal chain. The G2 and the effects pedals went to a little mixer, then the PA or powered speaker.
